Question about Whirlpool WMH31017AD 1.7 cu. ft. Over-the-Range Microwave Oven with
Microwave wont start display keeps showing door
    Problem Solver:
  • 5 Answers
Most likely its the door sensor... this stops the microwave from turning on if the door is not properly closed (so YOU don't get cooked). Usually on over the range microwaves people tend to pull the door down as they open it. over time it can become bend out of proper position. Try firmly lifting the door up as you close it... if it runs now than you have your answer.
Posted on Aug 05, 2014
Microwave wont start shows door on display
When it shows a door error and won't start, that's usually a door switch or door switch mount. My help file on door switches is here.
BUT - assuming your model is the KEMS308SSS01,02,03,04, or 05, it is probably the type that has the overdesigned door sensor circuit, as shown in the diagram below:
In this case, the other likely culprits (besides the door switch) are the 20A fuse, the 15A fuse, the "cavity TOD ("thermal overload device" - thermal cutout / thermostat) and the magnetron TOD.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
It also contains the diagram above.
There's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes. mini_manual_behind_grille_small.jpgdee77f7.jpg
Accessing the oven cavity TOD for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Kitchenaid / Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 27, 2012 | KitchenAid Kems308Sss 30" Microwave...
I have a Maytag OTR Microwave oven that doesn't work. After I close the door and set the time and start, I see the time countdown, but I don't see the microwave starting. I can get the microwave to start,...
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
See our file on door switches here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 30, 2010 | Maytag Appliances Over-the-Range Microwave...
Our Microwave, Jet343g shows display but wont work, also our oven
I am in desparate need of either a GE Jet343G oven with a manufacture date before May of 1989 - or a manual or some documentation that shows this oven was made before than.
Sep 06, 2009 | GE Microwave Ovens
KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Dec 20, 2008 | Ovens
Display shows nothing, microwave cuts off
You need a couple of cheap microswithes that the door latches hit when you close the door and a new control for your display problem which sharp has had a problem with
Oct 30, 2007 | Sharp R-1405 / R-140 Microwave Oven
Whirlpool WMH31017AD 1.7 cu. ft. Over-the-Range Microwave Oven with Logo
132 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
