Micromega stage 1 cd player, right channel out failure, bad signal
2 Suggested Answers
  • 3 Answers
SOURCE: Stanton S -650
Make sure that the "line/phono" switch on the back of the unit is set to "line", or your output signal will sound distorted.
Posted on Jul 15, 2008
Not receiving STEREO output when toggle switch for mixer is in the STEREO position
Here are a couple of steps you can do first before opening up the mixer & I'll word this so that it covers every potential item, (Turntables, CDJ's, Rack Mount CD Players, External Player, PC, Laptop, etc.) Obviously there are a multitude of items that could be the cause of you only receiving your RIGHT MASTER OUT since you didnt specify what item this occurs with if not all. So here's a quick legend for you to follow my references regarding the NUMARK 5000FX Mixer so here we go:
MIC/Line Phono/CD Phono/CD Phono/CD LA/LB Zone/Booth/Rec/MSTR
LO LO LO LO LO LO LO LO LO LO LOLOLO LO
RO RO RO RO RO RO RO RO RO RO RORORORO
1. Turntables - A) If being used make sure the little black switch on the back is set to Phono instead of CD. Plug just one table in, play the record & see if there's only one side of your MASTER output jumping and make note of it. Then repeat the exact same steps for all Phono inputs (total 3) & again make note of your MASTER output signal Left or Right or Both sides jumping. This will help you identify if its just a specific channell that only works on R or L.
B) Now do the exact steps above for the other turntable & this will confirm whether or not the Phono cables went bad on the turntable or if a specific channell is has gone bad while in Phono mode.
2. CDJ's/Rack Mount CD Player - A) Now just use your CDJ's/Rack Mount CD PLayer for the next test & be sure to now change the little black switch on the back from Phono to CD. Just as the steps with the turntable perform the same for this item in all possible RCA's (total 6) & note your MASTER channell output signals L & R.
B) Now do the same for the other CDJ/Rack Mount CD Player & this will confirm whether or not the RCA cables went bad on the CDJ's/Rack Mount Player or if a specific channell has gone bad while in CD mode.
3. Audio Cables OUT - A) There are a host of ways to have your audio come OUT & multiple configurations depending on how you record &/or bounce your audio OUT. Now since you say your MASTER OUT digital meter is only jumping on the R side depending on if you're going with RCA MASTER OUT or XLR BALANCED MASTER OUT either or is what'll show the digital reader bouncing with audio so check both. It could very well have been a cable going bad on you simple as that & you can check that by pluging your cable that works on the R side into the L side. If it starts showing a reading on the digital meter than you've solved the problem being a bad cable. Also don't forget to check your ZONE, BOOTH & RECORD OUTS as well however these will not show on your digital meter so open up your audio recording software to confirm that L & R sides are working for these.
B) Last but not least double check that your BALANCE knob is set directly at 12 o'clock, this could sometimes be the culpret.
Well I hope this helps & good luck.
WesTCo@sT
Sep 21, 2012 | Numark Industries Numark 5000FX 5 Channel...
I have a Kenwood KR-V9030 and the right channel is crackling and will not provide increased output when the volume is turned up. 1) Swaped speakers from left to right and the problem is in left speakers...
There is a chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
If it still doesn't work you might want to prove if its a low-level signal loss or a high level amp failure.
One way would be to run an RCA cable pair from the Tape Out to any other device (even a TV with speakers) you might have that accepts an audio input. If IT can't detect receive the DEAD Channel you're losing it in the preamplifying or source selection stages.
If it CAN be played externally, the receiver is losing it on its way to or at the amplification stage. Further isolation would require hands-on technical expertise.
Apr 16, 2011 | Audio Players & Recorders
Lose signal and when signal comes back in, it changes the channel to channel 1 preview.
Is it possible that you antennae if faulty. Please check if the insulatiion is weak or the antennae is shorting to ground. This can make the signals go bad and make the set hunting and go back to search mode .If the antennae is fine then the problem could be in the front end stage of the tuner. You will require an expert probe to look for signal weaking in this stage but if you can open the set and cean and solder the areas closer to the antennae output. hope this helps. Good day
Jul 14, 2010 | Audiovox Car Audio & Video
I bought a Behringer Eurorack UB2222FX-PRO at a garage sale. I am getting no signal at all through the channels and no levels appear on the LED VU meter. What could be wrong?
It is quite possible that you have bought a set that has a faulty preamplifier. The equaliser needs many such mixing preampflifer IC's mostly coupled together and it could be that there is a failure in one or several of the channels, the stages of the preamplifier. You must use a signal test to identify the faulty stage. You will need some help to go through these circuits and identify the op amps that are faulty. Try to check for voltage on the op amp stages and test with an audio signal for the section in fault. Hope you try. Good day.
Jun 02, 2010 | Behringer Audio Players & Recorders
Cybernet CB Radio does not receive or transmit. Switches on OK and lights up. ?? Can anyone advise how I can fix this ? (UK)
Several areas to check, Squelch should be all the way rotated to the left, Microphone may have a bad wire, bad audio amp.... Deeper problem could be a bad switching diode or bad relay if it is an older rig. Since the mic is the first thing to go bad, that is where you should focus...
Mar 20, 2010 | Radio Communications
Left channel faiure - no sound
If you have sound from one channel it is probably not a catastrophic failure of the output stages.
First isolate the problem. Does it occur with all inputs? If so, it is at a common stage after the input switch. Otherwise, it is before the input switch.
Do you have  anything patched into the signal path between the pre-amp and amplifier, such as a recorder or equalizer? If so, bypass it or remove it and see if that solves the problem.
Also, sometimes the metal contact surfaces in switches oxidize and collect contaminents, causing and interuption to the signal path. Make sure the volume isn't cranked, and then work the controls back and forth - if the channel comes back, even briefly, there's a good chance you can either clean it sufficiently by working the control or better, getting a can of contact cleaner from Radio Shack or the equivalent, removing the covers of the receiver (after pulling the plug), and spray the cleaner into each control before working the control back and forth a half-dozen times. With really bad controls, this can even cause the sound quality to improve.
If this doesn't isolate the problem, its time to take it to a qualified tech.
Nov 01, 2009 | Onkyo TX-DS656 Receiver
Channel 2 Distorted/Clip light comes on
It sounds like the final amplification section is OK now. I'd be looking for a noisy transistor or transistor pair at the "front end" of the unit. There may also be a shorted coupling cap between the stages. If you can Email me the schematics, I can provide more details.
Dan
May 27, 2009 | Behringer EUROPOWER EP2500 Amplifier
CD Player Skipping And Spinning Backwards!
Clean laser first. Near the laser there will 2 / 3 adjustable pots. Mark location on them all first. Pick one (then another) move a little left or right and see if you can get it working. If all fails return them to original positions nothing but time lost.
Apr 01, 2017 | Yamaha CDC-502 5-Disc CD Changer
I have a micromega stage 5 and the disc is jittering in the drive, i.e not spinning any idea's?
Had the same problem I think. When I would load a disc after a few seconds the unit would read no disc. I opened the unit and removed the transport and there is a board under the laser unit, on that board there is an adjustable pot so I plugged the module to the main board and powered the unit up. I adjusted the pot then sat a cd on it until I found a setting that worked. I hope this helps. I am not sure of your ability. Something to remmember is you can only fix it or break it.
Oct 20, 2008 | Audio Players & Recorders
Stanton S -650
May 22, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
 Grubhead
Grubhead
