Question about Sega Mega-CD Console
Sega cd 2 gears not working
The gear motor does not move the lens
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
If the laser is bad the disc wont spin
Posted on Sep 04, 2015
5 Suggested Answers
SOURCE: Sega Game Gear
try adjusting the brightness knob on the system. i once had that same problem with mine. The ccfl tube (the main battery drain problem in most portables) might be burnt out or something. You can replace it with LED's i think.
Posted on Jan 26, 2008
Trippynet
  • 47 Answers
SOURCE: my sega game gear sound has no sound how can i fix it!
might need a new headphone jack due to rough handling or a new volume pot. try plugging in headphones and wriggling them gently to see if you get sound, if that does not work try fiddling the volume knob, whichever gives a burst of sound will show you which needs to be replaced.
Posted on Feb 19, 2008
  • 52 Answers
SOURCE: Sega genesis CD console
put a disc in
press button b several times
the game should not start (if it does then press the reset butoon and try again)
you should get the green and blue screen
there is a button called memory
select the button by pressin A
this should give you the status of your memory
then press A again to get into the Memory menu where you can format, move or erase your data
enjoy!
Posted on Aug 07, 2008
  • 32 Answers
SOURCE: how to fix the sound on a sega game gear 2110
Hi Jeremy,
This is an easy repair, if you are used to working with a 15 watt solderin iron, and have a little experience with solderin small parts.
The sound board needs new capacitors, it is a common failure. I believe there are 6 of them, and the cost should be under $10.
This repair works well, but the capacitors that are in the display secton can go out too, at a later time. If you get to the oint where you must tilt the display at an angle to view, the caps are probably failing. Again, it is a matter of just replacing the caps.
Here are two videos that detail the repairs.
Posted on Apr 21, 2010
I have Rowe AMI 100 CD jukebox. I replaced CDPRO2 Optical Laser-lens and sound still cuts in and out. At times it can't pick up the sound and the cd stops and tries again.
Watch the motor that moves the lens assembly while a CD is playing. It doesn't take much movement to stall the optics so if a gear is slightly binding, that would be enough to cause your problem. Sometimes using a very light machine oil like that is used on a sewing machine on the pivot points will help the gears. A lithium type grease on the rails that the optics moves on may have dried a little, so be sure to check that area too.
May 28, 2016 | Audio Players & Recorders
Really?
the original earthworm jim did NOT come out for PS1, it was only on these systems: Sega Mega Drive/Genesis, SNES, Sega Mega-CD, Game Boy, Sega Game Gear, PC, Sega Master System, Game Boy Advance, Virtual Console
Feb 06, 2009 | Take 2 Interactive Earthworm Jim 3D
Will play CD's but not DVD's or Games
You have to take the box apart and clean the lens.Ok !
  1. The white plastic gear that moves the laser must make contact with the "motor". A bad contact here can cause disk read errors. Sometimes it looks Ok, but you may need to remove the lens and bend the white gear for good contact.
  2. The two rails on which the lens move must be very slippery - which can be lubricated with cooking or motor oil. Usually the holes where the rail is (on the right side of the lens) are dirty or you have to bore then out slightly, making the holes bigger.
  3. The lens uses little torx screw (black) that move the lens up and down on the rail. Usually the lens is too high and requires adjustment.
  4. Take the lens off these 2 rails and take the black plastic cover off. Turn the lense upside-down and you'll find there are 2 screws (silver, phillips or torx) that you have to remove to take the upper little lens off.
  5. Then you'll see a larger lens that is usually very dirty (this lens is a mirror to light). If that's dirty, it will give a disk read error. You'll have to take the little electric board off that you see on the other side of the big lens-mirror. It's probably dirty too, so clean it. Alcohol should work OK for this task.
  6. The lens bottom has 2 + 2 screws. You move the upper "little" lens up-down-left-right (this may require a special screwdriver)
  7. The motor "rail" that moves the lens must be very clean and oiled and the 2 rails too.
Jun 06, 2008 | Sony PlayStation 2 (PS2) Console
Unable to load playstation dics or any other discs for that matter
Jun 05, 2008 | Sony PlayStation 2 (PS2) Console
CD player skips on early tracks
The lens assembly in a CD player glides along on a two rail track, kinda like a railroad track except tubular. The lens carriage is moved over this track by a small motor driving a worm gear. (Think long, tubular and spiral). If the rail tracks or the worm gear dry up or have dust accumulating on them, this could be the cause. Normally they have a light gear oil or lithium grease on them to keep them lubricated.
Mar 08, 2008 | Audio Players & Recorders
Disc reading sound ps2 slim
Check around where the laser connects to the worm gear that moves it up and down. You may have some lint wrapped around the worm gear. Also check the disc spindle motor for Lint trapped under it. It could be your laser lens getting dirty.
Clean the Slims lens with a Q-tip and Window Glass Cleaner.
  1. Lightly Dampen one of the tips of the Q-tip with Glass Cleaner
  2. Swab the laser lens with the dampened Q-tip.
  3. Clean and dry of the laser lens with the dry tip of the Q-tip
Good luck
Nov 08, 2007 | Sony PlayStation 2 (PS2) Console
Lens motor
You are nearly right or even has stripped gears. Check out Olympus for a possible repair I do not think you will be jumping for joy at the price though.
Aug 21, 2007 | Olympus Camedia C-4000 Zoom Digital Camera
Problem with my copier
Mesin Saya 6035 Error 224 gimana atasinya
Jun 27, 2007 | Canon NP 6035 Copier
Lens motor
check the gear box, maybe one of them is broken. Look carefully every gear this is a very common problem in this camera
May 03, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Message 'no CD' always appears, but I can see the CD in proper position, but not spinning.
if you shut cd draw with no cd in, does the laser lens move up or down at all. if it does suspect dead laser pickup. it is very common for lasers to fail
Jan 11, 2007 | Teac AD-600 3-Disc CD Changer
Sega Mega-CD Console Logo
48 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
