Question about Garment Steamers & Presses
Switch problem not power on
Eurolab steam press is switching on but stays cold. Even on highest setting.
Not an answer, but a note to say this same thing has just happened with mine in Sydney. Its only three months old. I have contacted Deals Direct, and they don't have any repair options. They won't replace it becuase they model they have in stock is a newer one to the one I have, so a return seems to be the only option. Pity, because I loved this thing. It really made ironing easier.
Apr 15, 2015 | Garment Steamers & Presses
Eurosteam iron no power
try it in another power point , otherwise have it repaired at a service center . not suitable for home repair.
Nov 13, 2014 | EuroSteam Steam Iron w/Boiler Tank & Lint...
Parts
Almost any service center could get you one
Oct 14, 2014 | Singer csp-1 magic steam press
Why is there no steam?
Plugged in? Add water? Check the fuse on the power cable.
Jul 20, 2014 | Haan Complete Multipurpose Steamer MS-30R
My steamer is no longer producing steam, how do I fix?
To troubleshoot something like this.
1. make sure it's plugged and the outlet is working.
2. Is it getting hot? If not, either the heating element is burned out or not getting power.
3. If it is getting hot check the steam ports for calcium build up (run straight vinegar through it)
Jul 14, 2014 | Garment Steamers & Presses
My hand held little steamer will not get hot. switch comes on, but that is all it does
If the switch isworking then the only possible fact is that the heating element has failed and it might be too costly for a change.
Jun 10, 2013 | Ingenious Designs, Llc My Little Steamer...
Garment Steamers & Presses Logo
121 people viewed this question
Top Garment Steamers & Presses Experts
Tom Chichester
Bill Boyd
ray gallant
Are you a Garment Steamer and Press Expert? Answer questions, earn points and help others
