Question about Dell LATITUDE Computers & Internet
Bios blocked i can not acces my bios because its blocked how to reset to factory settings please help best regards sailor61@online.nl
    Novelist:
  • 100 Answers
Hi peter,
Some motherboards get back to default BIOS settings just by removing and replacing the CMOS battery. But in most of the motherboards, you need to reset it using jumper pins (those 3 pins are labelled in most of the MBs).
For resetting, there are 3 pins provided on the motherboard with 2 pins always coupled (or shorted) using a small cap. Say the cap is shorting pins 2 and 3. You have to now remove the cap and put it on to short pins 1 and 2 for about 10-15 seconds. Then revert back the cap to pins 2 and 3.
Make sure the CMOS battery is not removed during this process.
Power on the system, BIOS should now be resetted back to its default settings.Hope this solves your problem and rate my solution if it helps you.Have a good day.
Regards,
bonefirediv.
Posted on Apr 18, 2014
  • 3 Answers
SOURCE: how to reset the bios password on MPC transport x1000 laptop
the best way to remove a bios password is to have the bios reset by a program called "winternals" this can be done by any pc repair shop
Posted on Apr 05, 2009
  • 679 Answers
SOURCE: Hi, I have NEC Versa E6300
Hi Prajeet
To reset your BIOS password you need to call the NEC to give you a reset code. Most Computer manufacturers like DELL, HP do have password reset tool from their end. you just need to call them to ask for a reset code but expect to answer all security questions before they gave you the reset code.
Thanks for using Fixya.
Posted on Apr 09, 2011
  • 1288 Answers
SOURCE: After flashing bios, the laptop
I was unable to find the model of this on Acers site, but think it has the phoenix bios, This guide may help you reset your bios, sorry I can't help further
http://www.edugeek.net/forums/hardware/23287-acer-laptops-repair-failed-bios-update.html
Posted on Jul 26, 2011
SOURCE: How do i reset my lenovo t410 to factory settings?
Read the manual and it will tell you the process.
Get online and got to www.google.com In the google search box type: "IBM Support" or "Lenovo" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals and search them for Factory Restore or System Recovery.
Why not consider another option?
System Restore will allow you to select a Restore Point (date and time) to set your system back to when it was working ok. It does not delete any of your data, documents, music, pictures, videos or programs (unless the program was installed after the Restore Date you selected).
System Recovery (sometimes referred to as Factory Restore) will set your system back to when you first purchased it. It Deletes Everything. Most times the System Recovery does not work unless there is a recovery partition on your hard drive created by the manufacturer. If you are trying to recover from a set of cd's most times it does not work.
Instead of doing a System Recovery it's much easier to just Reinstall Windows. Look on your computer for the Certificate of Authentication (COA) Sticker. It will tell you what operating system is on your computer and it will give you the Product Key Code (a series of 5 letters and numbers) that you will need to activate windows. If you don't have an operating system disk, borrow one from a neighbor, friend, relative or co-worker. Just make sure it is the same as your COA Sticker's operating system or it will never activate. Also make sure you get the COA Product Key Code for the disk you borrow because sometimes the system will ask for the one that is on your system and sometimes it will ask for the one from the installation disk.
Posted on Jun 07, 2012
SOURCE: crack bios password on my lg x110 - forgot bios password - can not get factory reset - help please
A password is required for access to the BIOS and I do not know the password. I have had this problem for quite some time now but luckily I've managed to get access to the BIOS now. I used lots of different programs to crack the password but I failed in vain. I removed the little battery that sat on the motherboard but nothing happened, I ran Hirens bootcd 15.1 and it did not help either. Eventually I got hold of a new system BIOS for my LG X110 and then flashed my BIOS. No password is needed now :) Download LG Notebook (X110/XD110) System BIOS here -> http://download.notebook-driver.com/driver/LG/X110/BIOS_Setup_X110.zip and run the program. That should solve your problem, because it did for me :)
Posted on Jun 25, 2012
Testimonial: "how to flahing bios my lg x 110 laptop.i dont pls help me how to flashid bios lg x 110.thank you"
DELL E6520 DELL
you will have to remove motherboard battery to unlock bios password I believe. first, earth yourself.
remove main laptop battery.
remove keyboard screws and then keyboard.
undo top cover and detach the battery connector from the motherboard.
Leave it of for a good ten minutes.
Re attach and reverse dis assembly procedures
Hopefully this should allow you to access bios.
Dell has some very informative forums, visiting them might be helpful
May 28, 2015 | Dell Computers & Internet
How do I reset to factory settings
Please give more details as to which factory settings you would like to reset to. Do you mean BIOS factory settings or windows defaults? Or would you like to restore your laptop to its original condition?
The procedure in each case is different, so if you could provide more information (also about the make and model of your laptop), I could guide you through the process.
Regards
May 24, 2011 | Computers & Internet
I forgot my family settings acces code so i cant go online the console is block
Ok, here you go:
1. On the 360 dashboard, scroll over to the "System" tab.
2. On the System tab, click "Console Settings".
3. Scroll down in console settings and click "System Info".
4. When the system i
nfo box comes up type in this sequence:
LT RT X Y LB RB Y "Left Stick in" (press it in) Y Y
A box should come up and say, "Would you like to reset the console to the factory defaults?"
Click Reset and you're done!
May 02, 2011 | Microsoft Xbox 360 Console
Forgot my password for my acer aspire 5720z series need an empowered technology password to format my c:drive and my d: drive as the c: drive is full 32.5 g memory how do i restore this to my factory...
google for remove bios paswoord http://www.tech-faq.com/reset-bios-password.shtml
and download also the drivers for laptop on the site acer.nl select service&suport/ drivers befor you begin instal with the windows disk and format and fdisk hd (remove partitions)
Oct 26, 2009 | Acer Computers & Internet
Crack bios password on compaq nc6320 - please
You can crack dell bios password with Windows Password Recovery Tool 3.o . Here is a good post to help you:
http://www.windowspasswordsrecovery.com/crack-dell-laptop-password.htm
Oct 09, 2009 | HP Compaq nc6320 Notebook
Black screen after factory BIOS reset
Have u connected signal cable to the monitor? Is it ON?Try with different monitor
May 07, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
I have dell inspiron 1525 model and it not working in its actual bios setting but it start to work , when i make some change in bios setting and i want to know that how my system should work in its actual...
Best thing to do is to just reset the BIOS Defaults. This will make sure that your BIOS is setup just like it was from the factory. This also will help cause if your having other hardware problems you know that its something inside of the laptop instead of a setting in the BIOS.
Apr 20, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Nokia E71 factory reset code
e71 reset lock code-try 12345 it works for most e71
Apr 03, 2009 | Nokia E71 Smartphone
Reset to factory settings
Get your Recovery CD, and just completely reformat the hard drive, These discs should guide you threw this. If you do not have the Recovery CD's Then you may have to order them from Dell.
Nov 25, 2008 | Dell Dimension 3000 PC Desktop
Rebbot to factory settings
Hi bgreenejr,
Are you referring to the BIOS or OS?
If you’re referring to the BIOS settings, you can do this by accessing it and selecting "set to factory default" from the menu. The most common way to access it is by pressing the DEL button upon boot up; there are however, a lot of branded PC and laptops may use a different button like F2 or F12, etc; if you’re BIOS is locked, of course you’ll need the password to log-in.
Another and common method of resetting it to factory default is by shorting the CMOS reset jumper located in your motherboard, usually it’s the closest jumper to the battery or the CMOS chip. This does not require any password, actually this is the method used if you forget your BIOS password. I would suggest that you consult your motherboard or computer’s documentation on how to locate the CMOS reset jumper on it.
If you are referring you your operating system, the only sure way to reset it to default settings is if you do a clean install, that means re-formatting your pc and re-doing everything again, kinda messy, unless you can do a system restore that would revert it back to the original date and time when you first install the system, . Hope this helps
Cheers and best regards,
May 06, 2008 | Computers & Internet
Computers & Internet Logo
96 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
