Question about Dell Studio 1537 Laptop
Forgot password at startup - Dell Studio 1537 Laptop
How to access startup forgot password?
Hi
If you mean your BIOS password you will need to remove the battery and then remove the case from your laptop to access the main board, there will be a battery on there that holds the setting when powered off, remove this leave out for 2 mins replace and then put back together and power up, your BIOS should now have no password so you can access the settings again.
Cliff Cook
MCP
Jul 30, 2014 | Lenovo ThinkPad Computers & Internet
Forgot startup password for vizio desktop
Hi Karra, Start your mac. Insert the install disc that came with the mac and press Restart. As soon as the window goes black push and hold the c-key untill the Apple sign appears. Loading could take a couple of minutes so be patient.
After a while a screen to choose your language. After that the Installer appears to install the Operating System. Avoid this. On top you see several pop-up menu's. Click the far right one and you'll see Change password You can reset a new password here. Hope this works. Good luck.
Dec 01, 2013 | Vizio All-in-One CA24-A2 24-Inch Desktop
Forgot window password
Start up in safe mode (hold F8 at startup) and login as administrator. Go to start menu, settings or control panels, users and remove the password on the account you are wanting to access.. Then restart.
May 15, 2010 | Toshiba Satellite Pro L300-EZ1501 Notebook
Forgot password
Dear please enter code 12345 or 1122 if both are not accepted then please reinstall its software. Problem will be quickly solved. Thanks
Feb 24, 2010 | i-mate JAQ Pocket PC
Can't get passed micron electronics screen.
is ur password displayed during startup (POST) or in windows ? if it is display during POST, remove the CMOS battery for while and back on. And if it is in windows, start the computer in safe mode (by pressing F8 key during startup) and change the logon password. hope it works.
May 03, 2009 | Computers & Internet
Forgot password
On the Thinkpad's, it's a fairly easy process to reset the passwords. Try the following steps and you should be able to access the computer...
1. Power off the lpatop.
2. Flip the laptop over and open the Memory cover. It should have the diagram of a Dimm on it.
3. Short-circuit the two password pads or put a jumper on the contacts to short the circuit.
4. Remove the jumper, or whatever you used to short the password pads and put the cover back on the bottom of the laptop.
5. Power on the laptop and you should be fine.
Kerry L
Apr 07, 2009 | IBM ThinkPad T21 2648 Notebook
For the Windows password you will need to reformat your hard drive. If that would not be done or if there is another way of removing the password without removing and reinstalling the operating system or of using your laptop by working around, windows password does not make sense at all. Hope this helps. Thank you.
Oct 01, 2008 | IBM ThinkPad T22 2647 Notebook
For got user name an password at window startup
restart computer and before the XP Logo screen comes on, hit F8.
select safe mode and then select Administrator at Welcome Screen
open Control Panel and then select User Accounts. change/add user account. Remember to write password on paper.
Jun 03, 2008 | Compaq Presario 1200 Notebook
Witch password do u mean???
Windows password???
Bios Password???
Let me know if u want help!!!
Dec 08, 2007 | Microsoft Windows XP Professional With...
Dell Studio 1537 Laptop Logo
16 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
