Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
Ge pfs22sisbss fridge. temp display went out a while ago. now fridge does not run. only light comes on inside when open door. any tips?
  • 27 Answers
SOURCE: Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Posted on Feb 02, 2008
  • 74 Answers
SOURCE: I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Posted on Feb 26, 2009
bobicehouse
  • 1524 Answers
SOURCE: my fridge seems to have stopped cooling;there is condensation on the inside and the temp is lukewarm....however, the freezer is working fine, very cold.
You have a problem with the defrost timer.
Posted on Apr 26, 2009
  • 28 Answers
SOURCE: Our GE unit pfs22sisbss over
Try switch off the unit and leave it for a day with the doors open, that will defrost the unit fully and switch it on again. Remember not to open the door for at least 12 hrs. to let the unit time to cool down.
Posted on May 24, 2009
aasc
  • 1606 Answers
SOURCE: GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Posted on Nov 20, 2009
Testimonial: "Thanks for the information on the main control board. I replaced it and its working great. I checked the warranty info but mine wasn't covered."
Fridge Won't Cool
First off that "condenser fan motor" needs to be replaced. It is not running near the speed it needs to. (I replace those all the time on the job) Here is the replacement to order.Also, based on the information you provided, it sounds like the main control board is sticking in defrost and you will need to replace the main control board on the unit. GE has an updated control board that address's this problem along with some other issues the original control board had.Here is the updated board to order.
All the parts come with a 365 day, any part, any reason return.
Keep me posted!
Nov 01, 2012 | Refrigerators
GE Profile refrigerator Model PFS22SISBSS is not cooling, the digital temp control is at 74 when I try to lower it will go to 34 then immediately back to 74. The fan and freezer are both working. A repair...
The problem is damper assembly.In the damper assembly there is a door.This door opens and close with the help of motor.The damper is located between freezer and fridge section.The cold air from freezer section enters to fridge section via this damper door.---------- What repairmen did was proper, but may be that door is not properly got open, it got closed again.Or there is ice got collected between the freezer and freezer section, so this is not letting the cool air to pass from freezer to fridge.----------- ---------- This damper assembly needs to be replaced.Actually this door functions correctly with motor.He open the damper door manually and thought, the cool air will enter the fridge section non stop, but that door is again got closed, by some how.--------- You will have to get the damper assembly part replaced, to get the air flow work properly.------- As the repair man has already ordered the part, otherwise you can get this parts from online sites like www.repairclinic.com or from sears parts direct site.-------- Getting the damper door assembly, replaced will help.Thanks.Helpmech.
Sep 08, 2011 | GE Profile Stainless Bottom-Freezer...
My ge profile PFS22SISBSS FRIDE IS NOT STAYING COOL WHAT COULD BE THE PROBLEM?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 21, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
ICE MAKER NOT WORKING ON GE PFS22SISBSS
Lets try this first. Unplug and then wait 10 minutes and then replug. That should reset the memory for the motherboard. If that does not work contact me asap, Sea Breeze
Mar 13, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
Temp light does not light up and temp does not get cold. inside door latch is broken model #pfs22sisbss
The main control board could solve the display problem . May also solve the cooling problem , but would need to know , if frost build up on back wall inside freezer , are both fans working (freezer and compressor cooling fan) , is the compressor running ,are the coils clean in back of refrig ? Unsure about a "door latch" . The freezer door ,rides on glides , and the magnetic gasket should hold it closed .
Jul 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Our GE unit pfs22sisbss over under stainless steel refrigerator is not cooling...in both areas. This happened once before and we believed it could have been from the kids leaving the door open. We...
May 24, 2009 | Refrigerators
Feb 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
53 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
