Question about Sewing Machines
Stitch problems my Juki hzl-27z will only do reverse stitch. I can,t get it to normal stitch and the reserve hold down is loose.
SewTechWayne
  • 186 Answers
SOURCE: The Reverse stitch button
The feed mechanism needs to be oiled. Take off the bottom cover and look for any place where two parts move against each other. Some binds can be very difficult to remove. Try spraying everything with a light weight oil (I like Tri-Flow) and let them soak over night. Then manually try to move the feed dogs with your hand. Hopefully it will break loose.
Posted on Jan 30, 2009
sew dutch
  • 24 Answers
SOURCE: Juki HZL-E61: cannot get tension right on straight stitch
Loops on the bottom of the fabric direct the problem to the top thread. Rethread again and make sure the thread goes through the tension discs. Lift the foot, because this is what opens the discs. When sewing and the foot is down, the discs should be closed and thus giving the upper thread the tension it needs.
Posted on May 25, 2009
  • 3 Answers
SOURCE: double needle use on Juki HZL-E80
if the machine regular needle threads front to back NOT side to side, you can use a double needle. simply pass both threads thru all the same slots (thread one at a time so they don't get twisted up) then just before the needles, leave one out of the thread guide just above the needle. you may have to loosen the top tension SLIGHTLY, like a half number. and do NOT use a zig zag stitch without first hand cranking it thru the cycle to be sure the needles clear, or you'll make a 5.00 mistake (the cost of the double needles!)
Posted on Jun 16, 2009
  • 47 Answers
SOURCE: Manual Guide for Juki Frou Frou HZL-11
Visit us at www.ifixmachine.com
Posted on Jul 24, 2009
madelinesalo
  • 59 Answers
SOURCE: i need to know how and where to oil my juki
your machine is not a self oiling machine, you should put the oil on the needle bar, and to the bobbin.
Posted on Mar 26, 2010
Why is it seizing up and clocking after doing basic sewing?
Juki HZL F300 Exceed Sewing Machine at Ken's Sewing ...
www.kenssewingcenter.com/juki-hzl-f300-exceed-sewing-machine-p-30...
The Juki HZL F300 Exceed Sewing Machine is a classroom model and will exceed ...High speed sewing up to 900 spm, stitches per minute; Power at low speed ...
Juki HZL F300 Exceed 106 Stitch Computer Sewing and ...
www.allbrands.com/products/22395
$749.00 - ‎In stock
Juki HZL F300 Exceed 106 Stitch Computer Sewing and Quilting Machine +$50 Knee Lift Lever + $50 ... High speed sewing up to 900 spm, stitches per minute
Juki Exceed HZL F300 Home Deco Computerized Sewing ...
Dec 01, 2015 | Juki HZLF300 Sewing Machine
Fabric won't move doing straight stitch.
Be sure that the stitch length is set to a higher number. The closer to zero it is set, the closer the stitches will be until zero when it will actually be sewing in one place.
Nov 10, 2015 | Juki America, Inc Juki HZL-27Z 22-Stitch...
User Manual
JUKI SERVICE MANUAL
dixiesewingmachine.tzo.com/JUKI%20SERVICE.htm
APW-231,232,235,236,239,240 ENGINEER MANUAL.pdf, File, 3.07 MB. APW-297&298EM01_e. ... .pdf, File, 1.08 MB. DMN-530-4 Instruction Manual (No.02) BE5304S0B0A.pdf, File, 777 KB ... DP-2100 EM00_e.doc, File, 67.8 KB. DP-2100
[PDF]HZL-F series - JUKI
https://www.juki.co.jp/household_en/hsm/pdf/f-series_en1209.pdf
any other user servicing adjustments mentioned in the instruction manual. 11. ... can be used on sewing machine model HZL-F300, HZL-F400, or HZL-600.
Oct 27, 2015 | Juki Sewing Machines
User manual of juki hzl-7700
Is this a home machine? There are many of the manuals online at Jukihome.com
I didn't see this model #. They have one for an HZL-272 that might be similar
Jul 02, 2015 | Juki Sewing Machines
Requesting support: juki HZL F6000 suddenly stopped sewing straight stitching in a straight line. Also stopped automatic treading.
the machine may need to be serviced, the needle bar may need adjusting, also could be something wrong with the motherboard
Dec 08, 2014 | Juki Sewing Machines
Does This model have a reverse stitch option?
hello there
depended on model , the all JUKI LOCKSTITCH MODEL have a reverse stitch but normal model was by hand and with control box was both automatic and manual.
DDL-8700 was manual reverse stitch.
best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Aug 12, 2014 | Juki DDL-8700
How do i stop juki ddl from top skipping stitches?
Hi. Skipped stitches are usually caused by a mismatch in your thread and needle. Wrong thread type, wrong needle size, or even old thread can cause skipped stitches. If all else fails, change the needle. If that doesn't work, clean the machine. Sometimes just getting rid of all the lint and giving her a good oiling does a world of good.
Let me know if this works.
Robbie
Jan 10, 2010 | Juki HZL-E80 Computerized Sewing Machine
Double needle use on Juki HZL-E80
Jun 16, 2009 | Juki HZL-E80 Computerized Sewing Machine
May 25, 2009 | Juki HZL-E61 Computerized Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
