Question about Epson Stylus CX3200 All-In-One InkJet Printer
Need replacement flexible flat cables
The flexible flat cables that fit into the print head have become damaged and need replacing.
  • 1 more comment
  • 1911A1 Apr 17, 2014
    On the Epson Stylus CX3200 print head are two flexible flat cables that just push in to make their connections, the ends of these two cables have become distorted. (probably because I took them out and had problems pushing them back in.
    Add a CommentSo I need either two new cables or a way to repair the ends so that they are stiff enough to enable me to push them into the connection slots!
  • Yogi B Apr 17, 2014
    You could give it a try with a long, but small pair of pliers. I'm not sure about how the exact connectors look like to receive the cables, but if I got your story right, they should be able to open partially on one side to help you insert the flat cables. If you're not sure about what you're doing, don't force anything and bring it to a certified repair shop (contact Epson customer support to help find the nearest place in your area).
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
I would buy a new printer, most likely cheaper than the ribbon cables.
Posted on Apr 29, 2014
Testimonial: "Fixed. Thanks all."
What kind of glue do i need to replace the water pan gasket?
A nice weather stripping glue that remains flexible / does not become rock hard. If the glue is not flexible and gets hard it may become brittle or damage the housing and make the screws impossible to get out years later. We use this Glue.
Aug 06, 2014 | Rainbow Vacuums
I have an ESP2150 with an error message of printhead loose or missing. I checked print cartridges, I replaced print cartridges, I re-installed software and drivers.....I still receive the same error...
Unfortunately, trying to diagnose a printer without actually looking at the printer is a little like trying to diagnose a car engine over the phone. But, from the sound of it, the problem you are having is not exactly pertaining to the print "cartridges" but the print "head" which is the part of the printer that actually introduces the ink to the paper, and is actually part of the tray the ink cartridges fit into. Here is a picture of it:
This print head is able to be removed and replaced if needed. It may be something as trivial as being loose. You can remove it from the printer and reinstall it to make sure it is seated correctly. Here is a link for instructions on Kodak's website on how to uninstall and replace the print head:
Installing and replacing print head.
If the print head is either damaged or worn out (which can happen) you can replace the print head, which I just did a search online for one and it appears the print head is only around $35.00 to replace it. Here is a link to where I found a replacement print head:
Kodak Print Head Replacement for ESP2150
I hope this helps.
-Nathan
Sep 26, 2013 | Kodak ESP Office 2150 All-in-one Printer
Unable print 49
Error 49 relates to the print head drive voltage. It may just need the flat ribbon cables that connect the head to the main pcb reseating, but equally it may need the print head replacing (most likely).
An outside chance that the main pcb will need replacing.
In theory, all of these jobs are a task for an engineer.
Sep 23, 2013 | Brother DCPJ125 All-In-One Inkjet Printer
I tried printing text including elaborate colorful artwork on the pages. Some of it printed but the text became increasingly smeared. Finally it would not print any more. Hours later I tried copying a...
2 possible causes: 1 - the ink has started to dry in the cartridges, it has become too thick for the heads to project on the paper correctly and in the end it has clogged the printing heads - replace the cartridges and run several deep cleaning cycles. 2 - hardware fault: either the data cable (the ribbon that connects the print head carrier to the mainboard) has been damaged and it will have to be replaced at a repair shop or the processor of the printer has just failed - this is terminal since it will be cheaper to buy a new one than to replace the mainboard. To make a pretty exact diagnose of the situation take out the cartridges and see if the printer recognizes the situation when you try to print something. If you get an error message then it's the data cable, if the printer is unresponsive then it's the processor - time for a new one.
Aug 23, 2011 | HP DeskJet 6540 InkJet Printer
HP Deskjet f4435 will print, but won't scan. Orange light blinks
When I press the scanner button the top power button starts blinking but the machine does not scan. I have not used the scanning function on this machine before. Please help...you may need to reinstall your ..
Aug 16, 2011 | HP DeskJet F380 All-In-One Printer
When power is turned on the machine acts like it is supposed to. The carrier repositions itself and the motor is heard running. However, when I type, the carriage (with the disk) moves to the right with...
its a printer right?
and it dot matrix type right?
if yes. try this
check flexible cable from main PCB to print head. if its torn. maybe the initial sensor is ok but not the data line.
replace flexible cable.
Mar 04, 2011 | Computers & Internet
Will not eject disc and when i push the power button it turns off on its own
hello,
Could be a few reasons for this. If it's been dropped, the cogs could be misaligned, you will need to take the CD unit apart and reassemble correctly. If someone has attempted to fit a mod chip there could be damage around the part of the board where the wires for pins 5 & 6 are soldered. Check for damage to tracks and excess solder, it is also possible that the BA8510 or BA8515 chip has been damaged. Also it could be the flat flexible cable that connects the power/reset & eject buttons to the main board. Check for physical damage and replace if need be.
May 29, 2010 | Sony Playstation 3 (PS3) Console
Print head
That is a strange message unless you have changed the print head recently (or it has become defective). The first thing I would do is try reseating the print head.
Unplug the printer.
1) Remove the 5 ink cartridges.
2) Lift the lever that is just to the left of where the ink cartridges sit. This is the print head lock level.
3) The print head is located under the ink cartridges (if they were still there) lift it out carefully.
4) Inspect for damage but do not touch anything or it can cause problems.
5) Carefully replace print head and lower level until it clicks
6) Replace ink cartridges
Plug in the printer and test.
If you still have a problem -
Call 1 (800) 828-4040 for warranty part replacement or to order a part out of warranty.
Oct 06, 2008 | Canon MP830 All-In-One Printer
Print head failures HP 1050c
the tube system has an air leak causing a dryfire situation. air + printheads = damaged printheads. most users replace the black printhead more often than the colors. the seal where the printhead feed pin fits into the carriage is the end of the tube system. the hole in the seal becomes to large and doesn't properly seal the air out. order the tube system. complete and concise instructions are included in the box for tube replacement. this is considered an end user replaceable part. good luck! please rate this!
Sep 23, 2008 | HP DesignJet 1050c plus InkJet Printer
BROTHER DCP-315N
Have you had this machine apart/head removed?
error 48 = Head flat cables or carriage-head flat cable broken or not connected.......or main P.C.B.
Are you serious, I have never seen this on any inkjet, ........"Try to get temperature of room.. warming up"
Do you live in a igloo?
Nov 05, 2007 | Brother DCP-110C All-In-One InkJet Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
