My bra wire has vanished into my indesit washing machine and it is now making a strange ticking and scraping noise how do I retrieve it.
  • b_murray68 Jun 19, 2009
    Thankyou for your reply, I would remove it if I knew where the agitator was situated lol
    Sergeant:
  • 249 Answers
Shoul be up under your agitator,remove the agitator dont think it could get to the pump
Posted on Jun 19, 2009
GE washer making scraping noise as it agitates, but clothes are clean and spin is normal
remove the agitator and check underneath for bra wire , coins , and any othering that are left in pockets
Aug 20, 2016 | GE Washing Machines
Hoover WDM120 scraping noise heard when drum spinning with a load in washing machine.
have come across this prob before the noise you describe sounds like an underwire from a bra or the condencer on the back of the mach some had a baffle plate fitted just where it goes onto the backof your mach on some this came loose and caused it to scrape of the back of the drum hope this helps .
Jun 07, 2011 | Hoover H120M Front Load Washer / Dryer
Indesit 1600 WIE167 washing machine
locate element and remove you should then be able to remove bra wire they normally get caught around element
Jul 01, 2009 | Washing Machines
Indesit WG1234T washer drum not turning
hi there..by the sound of things,the brushes on the motor are worn out.easy to replace,each brush is secured by two screws at the rear of the motor,and will be black in colour,or a reddish colour.it may be easier to remove the motor to gain access.buy a cheap set from ebay,as generally speaking a repair and spares shop will ask four times the going rate.anyhow,once removed there should be at least 7mm of carbon left to make contact with the commutator(the part of the motor that turns)
hope this helps,steve.ps.the belt could have snapped or come off also....
Apr 13, 2009 | Indesit W 123 Front Load Washer
Washing machine
sounds like you have something stuck in your pump. I know it sounds strange that it more than likly does not make any noise in the drain. But i garrenty you there is a problem within your pump. Tilt the unit back and prop against the wall. DO NOT TIP ALL THE WAY OVER! you will see the pump it has 2 clips unclip them take the 2 hoses off and remove the pump. water will come out so be prepaired with towels. look inside the pump there will either be money in there or a bra wire. MAKE SURE YOU TURN THE POWER OFF FIRST. Let me know how it goes
Jan 03, 2009 | Kenmore 22622 Top Load Washer
Lost bra bone in washing machine
I happen to find these in the water pump or just bellow the drain hose from the tub. If not carefull, these can puncture the door boot, if front loader.
Oct 22, 2008 | Washing Machines
Indesit washing machine w1235
could be the bearings or heater/heater may of lifted or spider sometimes a coin can get trapped
May 20, 2008 | Indesit W 123 Front Load Washer
Terrible scraping noise from drum,what is it?
more likely there is a bra wire caught between the inner drum and outer tub, possibly wrapping itself around the element in the bottom.
Jun 01, 2007 | Creda W100FW Front Load Washer
Washing Machines Logo
136 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
