Question about Ricoh Aficio MP 2851
Sc792 i have in the left corner error sc792 and no finisher
  • Bryn Hughes Jun 26, 2014
    has the machine got a bridge unit fitted?
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
How to remove code sc792 ricoh MP5000b no finisher?
The machine does not recognize the finisher, but recognizes the bridge unit.
• Defective connector
• Defective harness
• Incorrect installation
• Defective harness
Mar 24, 2016 | Ricoh Office Equipment & Supplies
Ricoh Aficio mp 2510 touch screen not working
Were you able to resolve the problem; as I have the same problem with the touch screen.
Nov 20, 2012 | Ricoh FT5832 Copier
Hello i have ricoh aficio 1224c color . but the is have problem error sc792 . please help me best regards Salar
SC 792 :Finisher error .
The machine does not recognize the finisher , but recognizes the relay unit .
Possible causes :Defective connector
defective cable
incorrect installation
Aug 10, 2011 | Ricoh Aficio 1224C Black and White Copier
When i turn the power on and the copier start it gave me a message error of number sc792 and it always appear when i start
Is this a ricoh machine? If so you need to eathier put the finisher back on the machine or remove the bridge unit. The bridge unit is the section in the middle of the copier where the paper comes out. Make sure you turn off the machine and unplug it while removing the bridge unit or while connecting the finisher. Let me know if you need more help.
Jan 17, 2011 | Office Equipment & Supplies
Need a copy of page on setting up the Craftman miter saw model 113235120. There is one page in there with the set up to cut compound miters.
Make all cuts with molding flat on the table and bevel at 33.8 for ALL cuts ...to cut left inside corner, set miter at 31.6 degrees right. top of molding against the fence left side is finished piece... right inside corner set miter at 31.6 left with bottom of molding against the fence.left side is finished piece...left outside corner same setting, bottom of molding against fence right side is finished piece...right outside corner set miter at 31.6 right with top of molding against fence. right side is finished piece. hope this helps
Sep 01, 2009 | Craftsman Saws
Water left in bottom of machine when cycle finished.
you must check filter,it is full of dirt.
it must be on front side,down left or right corner,
May 21, 2009 | Dishwashers
Ricoh Aficio 1224C/1232C problem code SC 792
Hello sir; try to turn off and back on the machine to reset, if don't work next few steps need to follow;
1, press "clear mode" then enter 107 then press and hold "clear/stop" key until SP mode show up.
2, turn power off and back on .
Jan 09, 2009 | Office Equipment & Supplies
RICOH 2027 SC792 ERORR CODE
This seems to be a finisher communication error. If you unit has a finisher on it check the connector.
May 26, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh Aficio MP 2851 Logo
71 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
