Question about George Foreman Kitchen Appliances - Others
Thermal fuse problem
Not producing heat
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My Gas Dryer has stopped heating. I've checked
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 10, 2010
Wed6400sbo dryer wouldnt heat now start button wont work
check thermal fuse. Testing a thermal fuse
Note: Disconnect the power source to your dryer before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel. Testing a dryer's thermal fuse is much like testing its thermostats. Follow these steps to replace your dryer's thermal fuse.
The wires leading to the thermal fuse are connected using metal slip on connectors. Remove the wires by pulling on the connectors, and not the wires themselves. It may be a good idea to use a pair of needle nosed pliers to help you.
Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermal fuse should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. We strongly recommend that you test your thermostat at room temperature.
If the test you conduct with your thermostat does not produce these results, then you should replace the component.
Dec 09, 2011 | Whirlpool Dryers
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    My dryer will not produce any heat ? it is only air drying. Is there an element I need to replace or a fuse ?
    The Most common problem is a bad thermal fuse.
    1 the thermal fuses are located in the cabinet of the dryer under the drum
    they can also be located on the front of the blower wheel housing. on the back wall of the dryer or along the heating element can.
    2. some kenmore, whirlpool machines have these fuses located in the rear of the machine.especially when the lint filter is located in the top of the dryer.
    3. the heating element can also be bad.
    4. if you have an ohm meter you can check the continuity of the thermal fuses,as well as the heating element.if there is no continuity on any of the above mentioned parts. Replace the faulty parts
    Jan 08, 2011 | Whirlpool LER4634J Electric Dryer
    Turned heat on but only blows cold air
    Any product that produce heat have a thermal breaker, a thermal fuse, or both. Thermal breaker usually look like short cylindrical shaped device, while a thermal fuse look like a fuse in which one end is pointed, and it is rated by how many degrees it will go bad. It would say it on the fuse. Thermal breakers will open the circuit when it reaches certain temperature, then closes again as the device cool down. This process keeps repeating to limit the temperature of a heating device.
    Nov 27, 2009 | Intertherm P3RA-048K Air Conditioner
    No heat (replaced heating element and another
    It sounds like you replaced the heating element and the small thing you refer to was most likely the thermal fuse. If these are the components that you replaced, and if they are indeed good, the next thing to look at if the dryer is not heating up is the high limit thermostat. It is most likely faulty if the element and thermal fuse are good. Hope this helped and best wishes. Here is a picture of a thermal fuse and high limit thermostat to help you figure out what is what.
    Jul 30, 2009 | Dryers
    Dryer will not heat
    Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your dryer will run like new. Happy to help, Tim.
    Jun 07, 2009 | Kenmore 64902 Electric Dryer
    Clothes dryer not producing heat
    Check voltage at the receptacle first. The motor and timer operate on 120VAC. The heating element requires 208/240VAC to operate. Remove power from the unit. You can check the heating element, thermostats and thermal fuses using an ohm meter across each components terminals with one wire removed. The thermal fuses and thermostats should read zero ohms. The heating element will read low ohms (20 to 40). Successful heater operation still depends on the motor centrifugal switch being closed. Depending on the model, you need the heat circuit in the timer or electronic control to be closed.
    I hope this helps you.
    Apr 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
    Dryer is not heating up
    CHECK THERMAL FUSE ON BLOWER HOUSING IF OPEN (BLOWN) ALSO CHANGE HEATING ELEMENT THERMAL CUT-OFF (THERMAL FUSE) 309 DEGREES AND HIGH-LIMIT THERMOSTAT 250 DEGREES. GO TO www.repairclinic.com ENTER MODEL NUMBER AND LOOK FOR PARTS 2986 AND 2651 OR 2924. ALSO LOOK AT PART 2895. WHEN YU GET THERE SCROLL ALL THE WAY DOWN AND CLICK THE RED 100 AND LOOK FOR THESE PARTS ONE OR MORE IS YOUR PROBLEM GOOD LUCK
    Apr 08, 2009 | Dryers
    Gas dryer not heating
    So, your clothes dryer won't produce heat. There are a number of possibilities for this problem. The first thing we must determine is the type of dryer we are servicing. There are only two types; Gas or electric.
    If your dryer is electric, meaning it uses electricity instead of flame to produce heat, step one is to verify that the breaker to the dryer's electrical circuit is fully on. Since electric dryers require 240 volts to run, their circuit is run through a dual breaker switch. Sometimes only one half of the breaker switch will be off or fail which will supply enough power to make your dryer tumble but not enough for it to produce heat. Pop the breaker to your dryer off and on again and then see if the dryer will now produce heat. If it does, then have the breaker replaced. If it doesn't, you can verify that the dryer outlet is fully powered by testing it with a volt meter, You can learn how to use a volt meter here. If the outlet is fully powered then the problem definitely rests within the dryer.
    Let's next deal with the failure common to both types.
    You will need a continuity tester for this process. Directions for how to use a continuity tester can be found here.
    After you have removed the power from your dryer and shut off the gas, you will also need to access the internal workings of your dryer. Directions for achieving access, specific to your brand, can be found here.
    Most dryers have a thermal fuse located in the exhaust path. Depending on your dryer, the fuse will be found toward the front or the rear of your unit. Generally, if there is a removable back on your dryer then that is where you will find the fuse.
    The two most commons thermal fuses you might find are shown in Figure 1. They are each roughly 1" in size. You will notice that the contact points are easily spotted for a continuity test.
    In older units and some electrically heated units you will find a series of thermal fuses, looking like small tin cans, at various points along the heater assembly. These will also need to be tested before you can rule out thermal fuses as your problem. If any of the thermal fuses fails the continuity test, then it needs to be replaced. You can find reputable parts dealers at the top of this page.
    Dec 15, 2008 | Dryers
    Kitchen Appliances - Others Logo
    Top George Foreman Kitchen Appliances - Others Experts
    Mike
    Gerry Harvey
    Gerry Harvey
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
