Question about Ray-Ban RB 3323 Sunglasses
Rayban screw lost 1 screw - where can I get replacement.
Broke one lens
I believe that you can send these right back to RayBan and they will fix or replace these. Don't send them in without checking first but it is worth checking into.
Oct 08, 2012 | Ray-Ban RB 3403 Sunglasses
My rayban rb2113 hinges are not sitting flush.
Normally an Hair dryer would bo the job. Just hold the lens with a soft cloth and force a bit the arm while warming it a bit with the air dryer. Hope it will work. good luck
May 20, 2012 | Ray-Ban RB 2113 Sunglasses
The viewfinder on my Panasonic PV-DV200 needs to be cleaned. I have the instruction manual but I cannot get it to turn the 1/8 turn recommended to remove
Hi, My PV-DV200's viewfinder needed cleaned too. Try, try and try again. The entire viewfinder assembly will turn, but if it's never been removed before, it will be on extremely tight. My viewfinder has a small notch at about 1 'o' clock on top. That notch needs to be turned to about 11 'o' clock. Once there, the viewfinder slips off easily. It will come off much easier from then on.
However, simply cleaning the removed viewfinder may not be enough. You may also need to remove the two small screws on the underside of the piece that's still attached to the camera in order to get inside there and clean that too. I removed the small rectangular glass and cleaned that and behind there as well. I used a Rayban cloth (needs to be lint-free) and some Plexus, along with a dull pencil in order to get everything cleaned all along the sides of each lens.
Just double check and make sure all parts of the viewfinder are clean by slipping everything back into place prior to screwing it all back on. This will save you some time because you will probably not get everything cleaned on your first attempt.
Hope this helps!
Nov 16, 2011 | Panasonic PV-DV200 Mini DV Digital...
I lost my screws that goes to my tv stand the base Toshiba 40 inch tv were can find the screw
1 PointsProblem with Toshiba TV Accessories I lost my screws that goes to my tv stand the base I lost my screws that goes to my tv stand the base Toshiba 40 inch tv were can find the screw
Nov 02, 2011 | Toshiba Televison & Video
My sunglasses, a Rayban wayferes is loose. Its arms has loosen and is not a snug fit anymore like when i first got it. How do i adjust it so that it will return to its original fit? Hope someone can give...
Hi if you take you sunglasses into any opticians and explain your problem, they are more than likely to tighten the arm for you for free as it is only twisting a screw that attatches the arm to the frame or if you have a tiny screwdriver you will be able to tighten it yourself,
hope this helps
Feb 20, 2011 | Clothing Accessories
Hi All!! I've been disparately looking for a specific pair of Rayban after they have been stolen. The model is the one I'm wearing in these photos:...
Hi,First of all I am sorry to hear about your sunglasses.
It is most likely that they have been discontiued. Here is a similar pair;
Ray-Ban 3183.
Nov 07, 2010 | Clothing Accessories
What are G-15 XLT lenses on rayban sunglasses?
Asked the same question. This is the answer recevied from rayban customer service: "The B15 is a brown lens and the G15 is a grey/green lens. Both lenses allow 15% light through the lens. It also blocks the UV reds and UVB rays".
Replacement Screws needed
if cant find in u.s , means probably metric screws, here in canada we can buy both and any screw made can be found at home depot. finding a screw at hardware store still easier than buying screws from a manufacturer. try to find store that carries metric screws.
Aug 12, 2009 | Simplicity for Children Ellis 4 in 1 Sleep...
Lost screw for ellis 4 in 1 sleeo system
Please call Simplicity Customer Service to order replacement parts.
Before you call you need to have the model number of the product and be able to describe the part you need. Please refer to the instruction manual that came with your product. If you do not have the instruction manual, please locate your product's model prior to calling.
You need:
  1. Product name
  2. Model number
  3. Part name or description
There may be a charge for the part and shipping. We accept Visa or Mastercard.
Customer Service is open from:
Monday-Friday
9:00am - 5:00pm (Eastern)
1-800-858-8323
May 02, 2009 | Simplicity for Children Ellis 4 in 1 Sleep...
I NEED SCREWS!!
Ace hardware carries these metric screws. I lost one screw & this was the closest thing I found.. The allen key part is not the same but the thread & the length are perfect- they are about 0.75 each. : )
Feb 04, 2009 | Simplicity for Children 4 in 1 Ellis Honey...
Ray-Ban RB 3323 Sunglasses Logo
Top Ray-Ban Clothing Accessories Experts
Da Doc
ray gallant
Are you a Ray-Ban Clothing Accessory Expert? Answer questions, earn points and help others
