Question about Xerox Phaser 3635MFP/X Multifunction Copier/Email/Fax/LAN Fax//Scanner Laser Printer
Meter reading for a 3635 - Xerox Phaser 3635MFP/X Multifunction Copier/Email/Fax/LAN Fax//Scanner Laser Printer
Where may I find a manual for sportline watch 3635?
Try Googling (sportline)(3635)(without parens.
Jun 27, 2017 | Sportline Watches
How to change the time on a phaser 3635
To Set Date & Time on a Xerox 3635
Press: Machine Status (hard button)
Press: Tools (on touch screen)
Press: Device Settings (on touch screen)
Press: Set Date & Time (on touch screen)
The machine will have tabs at the top
Press: Set Date
Press: Month
Enter the Month: (Using the hard buttons)
Do the same for Day and Year
Press: Save
Press: Time
Same procedure as above setting the Date
Press Save
Turn the machine off and back on for settings to take effect.
Dec 20, 2012 | Xerox Phaser 3635MFP/X Multifunction...
Vivitar camera
The 3635 takes MMC and SD cards, up to 2GB in size. Larger SDHC cards will not work.
Feb 17, 2012 | Vivitar ViviCam 3635 Digital Camera
I found my old Vivitar ViviCam 3635. What cord do I need to connect to PC? Is there specific software I need to manage photos?
You don't need a cord, or any specific software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program you wish.
Mar 19, 2009 | Vivitar ViviCam 3635 Digital Camera
KX FM 131 มีคำว่า paper jummed
 I HAVE A BROTHER FAX MACHINE.  I CAN NOT HOOK UP TO MY FAXES GOING OUT
Feb 15, 2009 | Panasonic KX-FM131 Fax
Dario Grade O Meter Instruction manual needed
Hi Tracy,
I have the book, the address in the book is Dario Grad-O-Meter 12660 Lull St. North Hollywood, CA 91605 ph (818) 765-3635
Oct 25, 2008 | Measuring Tools & Sensors
Xerox Phaser 3635MFP/X Multifunction Copier/Email/Fax/LAN Fax//Scanner Laser Printer Logo
22 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
