Question about HP LaserJet 4700 Printer
Hp Color Laserjet 4700 Printer Shows Processing
Either the job you are sending over is very large and the printer does not have enough memory to accommodate the print job or you are not using the correct driver. If you will go to the printer under "devices an Printer" and right click on the printer icon, select "printer Properties", and navigate to the advanced tab, you will see which driver your computer is using. The three most common drivers are PCL5, PCL6, and Post Script (PS). try using a different flavor as some printers like some better than others.
Each type of software installed in your system has to coincide with other softwares. A driver is a type of software that allows the hardware connected to your PC to communicate with the system. A sudo language so to speak. If the hardware is having a tough time with the communication you can try a new dialect and see if it improves.
Here is a link where you can download the various drivers for your system based on your flavor of OS for the printer you specified Drivers Software Firmware for HP Color LaserJet 4700 Printer series
Posted on Apr 17, 2014
    Scholar:
  • 66 Answers
The first thing you need to do is easy stuff, do this:
1. Unplug all cables except the power cord. Turn you printer on and see if it comes ready and says ready on the screen. Does it? If not your printer is at fault and needs repaired.
2. If it comes ready and says ready on the display then press menu, scroll to information scroll to configuration and press enter. Does it print anything out? If it does your printer is most likely ok and the problem is with something you are trying to print it doesn't understand or you are using the wrong driver which is the thing you click on when you want to print, download a new driver from hp support and install. Make sure it is specific to this machine and your operating system of your computer.
3.Save your project to another form like word or word pad or pdf and try it then and see if it works. If not and you have tried the new driver then replace the jet direct card if you are using a network cable. The jet direct card is the device that protrudes where the network cable plugs into. It is attached by two screws that have knurling on them. Change it to at least a Jet Direct 620N. If you are using USB cable to print to the printer and after you have tried the all the above, excluding the jet direct card as you dont need it to print USB and it says processing then your formatter board is bad. Best to have someone that knows fix it.
4. If you are using a network cable to print to your printer, try using a USB cable and see if it works. If it does then your formatter board is most likely ok, and the problem is the jet direct card.
5. There are a few ways to determine the problem, so best you give it a try what I talked about and return back with more info after you have tried these things or click on my answer as the best if it resolves the problem.
Posted on Apr 21, 2014
SOURCE: HP Color laserjet 4700 is printing in landscape
check paper settings in paper handling to set
at plain paper/ letter. or reset factory defaults.
check paper size on tray if app, set to standard or
letter ,not custom
do cold reset . must reinstall network info afterwards.
Posted on Jan 20, 2009
leroyal
  • 2120 Answers
SOURCE: HP Laserjet Printer 4700 Fuser Error
Try unplugging the printer for 30 mins. You may still have a defective fuser.
Posted on Mar 12, 2009
  • 117 Answers
SOURCE: HP Laserjet 2420 printer says processing job but
You will have to follow the some steps for it.
  1. Unplug the printer cable from computer.
  2. Delete the pending document from queue.
  3. Delete the printer icon and remove the printer driver completely from add\remove program or using disk.
  4. Restart the computer and download the driver from “ http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=412123&taskId=135&prodTypeId=18972&prodSeriesId=416419&lang=en&cc=us”.
  5. For download the driver choose the operating system which you have installed in your computer and download it on the desktop.
  6. Tried to installed the printer driver and when it ask for plug the printer cable , plug the printer cable and turn on the printer power and follow the instruction.
  7. Once when installation get finish, restart the computer.
Now it should be work for you.
Posted on Oct 30, 2009
SOURCE: My Printer HP 1600 Laserjet error 10.1001
Did you fix your problem? I have the same one. With Hp 2600N
All cartridge are new, and i removed the orange tab from each one.
I even tryed a second new cyan.
Did you remove All the orange tab from cartridge?
Posted on Feb 12, 2010
  • 202 Answers
SOURCE: i have hp printer 4700 color laserjet .i installed
What I recommend you to do is turn off the printer, disconnect it from main power for a couple of minutes and then connect back and then turn on and counter suppose to reset by itself.
Posted on Apr 01, 2010
Error code 59.90 on color laserjet 470
59.9 is SCANNER MOTOR ERROR.
It is a rather tough part to service.
The entire scanning assembly would have to be replaced.
see
HP Color LaserJet 4700 Series Printer Numerical Control Panel Error...
Nov 01, 2016 | HP LaserJet 4700 Printer
Error code 59.90 on color laserjet 4700
Transfer belt motor error, either a bad motor or a bad transfer belt.
Hp color laserjet 4700 will not print in color
do self test - configuration print, if ok check your print driver settings
Jun 02, 2014 | HP LaserJet 4700 Printer
Need only black to print from HP Color Laserjet 4700 printer
on the print page just before printing , go to properties and make black the default color
Jun 04, 2017 | Office Equipment & Supplies
Color Laserjet 5550dn code d'erreur 54.15
54.15 PRINTER ERROR Description There is a problem with the Yellow CPR sensor. Action
  1. Turn the printer off, and turn it on again.
  2. Clean the color registration detection sensor above the black print cartridge if the error does not clear.
  3. If this message persists, contact HP.
Jan 05, 2011 | HP LaserJet 4700 Printer
I have hp printer 4700 color laserjet .i installed new image transfer kit but counter not reset automaticaly .plz help me how i can reset manually . thanks
Feb 27, 2010 | HP Color LaserJet 2600n Printer
How to replace image fuser kit for hp laserjet 4700n
turn off the machine. open upper front cover. remove the old fuser and insert the new one. turn on the machine and enjoy your printer with new fuser kit.
Jan 20, 2010 | HP LaserJet 4700 Printer
HP Color LaserJet 4700 Not Booting
Check if fuser and toner cartridge and image transfer belt are properly installed. Also check if covers are properly closed. One more thing, disconnect printer from main power for a couple of minutes and then turn it back on. Hope this helps. Maybe you can tell me what happened before this started(ex. paper jam).
Oct 24, 2007 | HP LaserJet color laser printer
HP LaserJet 4700 Printer Logo
74 people viewed this question
Seeker5211
Seeker5211
