Question about D-Link Computers & Internet
Forgot the password of dlink A11 wifi adapter
    Genius:
  • D-Link Master
  • 1,552 Answers
Reset the router to "factory" settings.
Then, set a new SSID and a new password.
Posted on Feb 02, 2015
2 Suggested Answers
  • 53 Answers
SOURCE: dlink wifi adapter dwa 125
No lights means no power, so that's not a good sign.
Can you check that it's plugged in?
Is the transformer plugged in properly?
(Obvious one: is the plug switched on?)
Can you try another power supply to see if that's the problem?
Can you try another electrical socket to see if that's the problem?
Have you another router to try with your existing power supply to see if its a dead router?
Posted on Jul 27, 2011
Forgot password
If you forgot the d-link configuration password - the default user id is admin and password is admin
If that does not work then below the router there is a reset button use a paper clip to push and hold it down for 20 seconds it will reset the password to default ( NOTE : YOUR ROUTER CONFIGURATION WILL BE LOST IF YOU RESET THE ROUTER)
If you need the wifi password Click on the icon, which is usually next to the clock, and then right-click your connection. choose the wifi connection and right click right click and Select Properties and then check the Show Characters box. Doing this will display the password.
Oct 10, 2013 | D-Link D Link Xtreme N Dwa 552 Desktop...
Dlink wbr 2310
change the password with a new one (not the default), then change the ssid with a new one (not the default). then reconnect
Aug 25, 2013 | Computers & Internet
I forgot to set up my password to my dlink wireless router how am i going to do?
I presume you mean the login and password to configure the router.
Connect a LAN cable from your computer to the LAN port on the wireless router.
Open a browser and enter the router's configuration URL.
The D-Link configuration URL is
http://192.168.0.1
and the default login = admin
the default password = blank (just press enter)
To secure your wireless router from unauthorized access and to configure the wireless card in your computer to connect to the wireless router, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Sep 03, 2010 | D-Link FREE DLink DWL-G510 802.11g...
HOW TO ACCESS DLINK WIFI ROUTER BECAUSE OF FORGOTEN PASSWORD
You reset the D-Link back to the factory default by - Press the RESET button at the back of the wireless router when it is powered up. Holt the RESET button foe at least 5 secs until the LEDs flash and then release the RESET button.
You can then configure the D-Link as follows ;-
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 19, 2009 | D-Link DI 514 Wireless Router (DI-514)
I want to put password on my router
just open your dlink ip page and type the username as admin and leave the part of password.
it will open a page where there is a palce to add a wifi password
sagar
May 15, 2009 | Directed Electronics Dlink DP-301U PRINT...
Forgot my password for WBR-1310
http://www.broadbandreports.com/forum/r19086676-DLink-WBR1310-Forgot-UserPass
If you have tried the default password and it doesn't work, I think your only alternative will be to reset the router to the factory defaults
Jan 27, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I forgot the username of dlink wbr-1310 wireless router
As an initial info try to do a hard reset on the unit, this process will restore the system into a original settings. you can find the reset switch on either on the left of right sight of your router.
or
you may visit this SITE to recover again your current password without erasing or removing the current settings made.
Reset Password.
Hope this idea helps you.
Thank you for using fixya.
Nov 20, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Verification and signal problems
Hi Sir F,
You don't need to do a re-install of the DLink WiFi adaptor since I believe it is running as it should (as you posted). All that is needed is to configure it to exclusively select only your NetGear WiFi Router. This could be done in the DLInk Wizard (Start/All Programs/DLink.../) set the DLInk to connect only to the SSID of your NetGear. Though it may pick up your neighbors WiFi, the DLink will only acknowledge the presence of the other WiFi but connect only and always to the NetGear.
A couple of other things that may help improve your WiFi connection. Use static IP add in your PC to match that of the NetGear, disable wireless security (WEP or WPA) but rather enable MAC filter and input that of your PC's WiFi Networking Card.
Should you need a more detailed instructions, pls post back the model of your router and the make/model of your PC as well as your OS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 07, 2008 | D-Link Air DWL-122 802.11b Wireless...
Computers & Internet Logo
56 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
