The fuel pump is located inside the gas tank, the gas tank is held in place by 2 steel straps, fule lines, wiring and the filler nect must be disconnected as well, also u MUST replace the fuel filter and the the fuel pump connector at the tank connector, this is the part number for the fuel pump connector.VERY IMPORTANT!
AIRTEX Part # WH3008 {Wiring Harness} PRICE $10.61, SOURCE www.rockauto.com
lowest prices on the internet i have found.
It will almost certainly be inside the gas tank. Pick up a Haynes manual, you'll be glad you did as this is not a simple job. You'll have to drain the fuel tank at least most of the way, lower it, remove the pump sending unit from the top of the tank, replace it and put it all back together.
You'll need to check the circuit from the fuel pump relay back to the pump. The computer grounds the relay. If the pump is running the filter could be clogged.
have you checked to see if engine is firing? ignition module can go bad and you would loose fire and fuel at the same time. i replaced one on a chevy truck last week and it was located beside the ignition coil.
i have an 03 yukon and i just replaced the fuel pump and it ran for 2 hours then it just died on the highway. it turns over but will not start. whats wrong with it???
The problem is with the fuel level sensor, it's attached with the fuel pump and located inside the fuel tank, sometimes the water and other impurities inside the fuel causes this problem, solution is to get the fuel pump opened by a professional and the problem might be solved by some simple cleanup.
Hope it helps and comment if you need more advice.
Please don't forget to rate the answer, it helps me, thanks!
On a NO Power to FUEL Pump Problem One Must ALWAYS Start from the Begining of the THAT CURCIUT, This Being the Fuse , Then The FUEL PUMP Relay , And Then WIRING , and LAST Is The PUMP Itself. Here is Info on the RELAY. rejakwilsoin @ aol.com < is my Email Address if you want More info Feel free to Contact me.
The Fuel Pump Relay is located in Underhood Fuse Relay Center. The Underhood Fuse Relay Center is located on the LH rear of engine compartment, on fender.
REMOVE OR DISCONNECT
Protective cover.
Retainer, if installed.
Electrical connector.
Relay by depressing bracket clip at rear of relay, or removing bolts from retaining bracket.
just fixed this problem, change your fuel pump module, fuel sending unit shorts out on fuel level swing arm blue wire... unfortinately you must replace it as unit because of the design, fuel pump and tank guage fuel level sending unit are a one peice item, fuel tank has to come out to change unit, about a $ 700.00 repair too... fuel pump module runs about 350 to 700 $ depending on aftermarket or factory, try to find one with a lifetime warranty even if it is $ 50.00 more worth it..labor is about $ 250 to $ 400 depending on shop labor rate... definate problem though I ahve no doubt, common problem on GM... please rate my help, thanks...
