Question about Bosch Saws
Jig saw revs but blade doesn't move - Bosch Saws
  • 12 Answers
SOURCE: Blade won't stay in jigsaw
It sounds like you need to replace the shaft.
Posted on Feb 25, 2009
joboo1
  • 257 Answers
SOURCE: Problems with Bosch T101BR 4 Inch 10 Tooth Jig Saw Blades
Hi, The reason for a down cutting blade is to see your cut on the finished side of laminates ( which include veneers, plywoods, plastics, formica . When using an upcutting blade on laminates the smooth cut is on the bottom, which you can not see till you are done and turn the work over. Reversing the teeth allows that smooth cut to be on the top. This is usually done on smooth flat surfaces as you have found out and does not work with orbital or tight scrolls. As far as the pushing or pulling, smooth cuts in laminates require the saw doing the work at a speed that allows the teeth to cut and remove material with biting. So if you are biting, (This is a much slower process than pushing your jigsaw through regular wood) check that you are not pushing too hard and that your blade is still sharp. Good Luck to you, this should Fixya!
Posted on Mar 08, 2009
  • 3 Answers
SOURCE: blade wont stay in Bosch 1882VS jig saw
From your description I cannot say for certain, but it sounds as though you are not locking the blade correctly, or the blade lock mechanism is broken. You can tell if the blade-lock is working by clicking it. It should make an audible "click" that you can feel. Also, you can pull on the blade ( with the saw UN-plugged of course!) and feel if it is properly seated. If you are operating the blade-lock according to the instructions and it still doesn't lock positively, see a service center before you use the tool again. A broken blade-lock could be dangerous.
Posted on Apr 10, 2009
rowdy45176
  • 2176 Answers
SOURCE: change blade 1587 Bosch avs
are you using the "T" shank blades and also are you loosening the spindle enough to allow the blade to turn, sometimes you have to push up a little to turn it and also pull away from the roller guide. Let me know and also there is a TINY spring in the top of the spindle that has a nasty habit of breaking and winding around itself not allowing proper operation.
Posted on Oct 10, 2009
FixYaSteve
  • 57 Answers
SOURCE: How do I change the blade on a Bosch pst 54E Jig
There's an exploded diagram of a similar model here. Don't let it confuse you though. I mention it, because it shows the clamp screw which hold the blade in place (35 on the diagram).
Unplug the saw before you change the blade.
In the handle directly over the blade there is a hole with a clamp screw at the bottom. Use a long thin blade screw driver to loosen the clamp screw.
Once the clamp screw is loosened, twist the blade about 90 deg and you should be able to pull it out (don't cut yourself, by accident)
Put the new blade in with the same orientation and twist so the blades are facing the front of the saw.
Tighten up the clamp screw and you're good to go.
Be careful not to tip your saw over while the screw is loose. If it falls out and you lose it they're a bit of a nuisance to come by.
Posted on Jun 14, 2010
Dewalt 331k jig saw blade falls out
Dewalt Jig Saw
DeWalt Jig Saw MANUAL ManualsOnline com
Blade catch wears out too fast
I loved this tool when it was working but after not that much use the teeth that hold the blade under pressure no longer hold hard enough to prevent the blade from coming out. The mechanism that holds the blade has no catch hole, it uses a few serated teeth to pressure hold the blade in place. Unfortunately, once the pressure starts to lessen you can't tighten it down...
Aug 24, 2014 | Dewalt 331K 6.5 Amp Top Handle Jig-Saw
Jig saw b4300 blade replacement
This tool has no mechanism for the fixating ot the saw but only a short ***** part 53 its a fault in the manual , it simply replace the saw with a screwdriver. or simply the clamp ***** to release turn it loose and from the top you can replace the clamp *****
Bosch B4300 0601582535 Jig Saw Parts
Sep 05, 2013 | Bosch 1581AVSK Top Handle Jig Saw Kit
Hi I have a Black and Decker Jig Saw 7588 Type One that works fine but I can not find replacement blades for it here in San Diego, California. Where can I find the blades?
I have the blades and the 7588 jigsaw. thinking about selling on ebay. search for black & decker jigsaw w/ blades in next couple days if interested in buying saw with 6 blades. thankyou, makthriftsales
Jan 14, 2013 | Black & Decker Single Speed Jig Saw
Jig saw catching and jumping using new vermont american blades
try one with more teeth and do not force it into the wood
May 14, 2012 | Vermont American Tool Company Saws
My saw blade isnt moving up and down. The jig saw sounds like its running just the blade isnt moving at all..... how do i fix it?
Unplug and Take the case apart. You will probably see that the gear moving the blade collet is stripped. Or, the gear fell out of place. Try putting it back together and see if it works.
Jul 08, 2011 | Saws
Jigsaw dc330 blades keep poping out when used
Hi Paul,
When inserting the blade, turn the saw upside down to prevent the blade from moving while tightening.
Before inserting a new blade, check the receiver for obstruction or debris that may prevent the blade from properly registering with the tightening screw.
Make sure the blade is fully seated in the receiver before tightening.
The tightening screws that secure blades on any type of reciprocating saws (Jig, Scroll, Sawzall, etc.) are constantly under stress and do wear out. If the problem continues, it may need to be replaced.
Best regards
Mike
Oct 29, 2009 | Dewalt Saws
I have a milwaukee jig saw, 6268-21 that I cannot load blades.
Yes the Milwaukee 6268-21 does require the use of certain jigsaw blades. You have to use T-shank type blades. You push the tension lever hold it while putting the blade in as far as it will go, then you release the tension lever slowly and it will engage the blade. You should then check by pulling on the blade to make sure it is seated properly and will not come out.
Oct 20, 2009 | Milwaukee Tool Milwaukee Orbital Jig Saw...
Task-force-4-amp-jig-saw
how do i change blade on task force jig saw. i am un able to pull it out after pressing button for it
Aug 04, 2009 | Saws
What is the process to change a saw blade on Bosch GST 2000 jig saw SDS system
There is a lever on the handle, you have to pull it up and rotate it counter clockwise about 3 times (shouldn't take any more than that. The blade will be loose now,put in the new blade and turn the back lever clockwise until it clicks. The blade should be tight,push the lever down and move it into the slot in the handle.
I hope this helps
Apr 06, 2009 | Bosch Saws
Saws Logo
53 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Craig Butler
Craig Butler
Are you a Bosch Saw Expert? Answer questions, earn points and help others
