Question about Bosch SHU9922UC Built-in Dishwasher
SHU9922UC doesn't get rid of water
I own a SHU9922UC, recently we started to have a bad smell coming from the unit. I went ahead and pulled it out, there is one hose on the back of the unit that was stuffed with mucus looking goo and it smelt horrible! Any idea what could cause this or what I can do to stop this? All help is greatly appreciated!
  • 6,784 Answers
HI, check the following areas to address this poor draining issue.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Posted on Jun 19, 2009
How can we get rid of the occasional sewer smell in our house?
When you next get the smell, check the traps to see if there is enough water in there to fill the trap, if one is less then it looks like water is getting sucked out when toilet is flushed or that trap (usually bath or shower) hasn't had water going in (lack of use) and water has partially evaporated.
Sep 06, 2014 | Plumbing
Hi I have an LG fridge freezer model number GR L206CPQA and there is a horrible smell coming from the water from the dispenser, the filter has been changed and the ice seems to be fine but the fans on the...
Sorry but your model number doesn't register with me in the USA.
My experience tells me that the plastic water line from the filter to the water tank to the dispenser outlet is your problem. Replace those parts and you should be ok.
Hope this helps.
Nov 14, 2011 | LG Refrigerators
My machine smells damp and musty in between uses. it smells like there is stale smelly water in it, it`s so bad that we can`t leave the door open. This is only a recent thing, we have pulled it out and...
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Washing Machines
Bad smell from motor
You need to remove any spoiled food from the refrigerator and clean the interiors with hot water added with baking soda. You need to clean the door seals and remove the breaker strips. Also check for unusual wet insulation.
Hope this work
Jul 28, 2010 | Amana ABB1927DE Bottom Freezer...
My wife and I are renting a house. The landlord told us that the water heater was recently replaced. The hot water smells pretty bad. The landlord says that the fowl smell is due to the anode rod in the...
Hi. Your landlord is correct. Anode rod can produce rotten-egg smell. Ask him if he can replace the "sacrificial" anode rod with "Power" anode rod or zinc/aluminum rod to get rid of the smell. However, you need to decide whether you tolerate the bad smell produced by anode rod or the minimal toxin produced by zinc/aluminum rod.
You can also try to drain/clean the tank first then add peroxide treatment and see if the smell goes away. If you do this method, the smell is more likely to come back if you go on vacation and left the heater unused for several days.
This article explains it better: Why Does My Water Smell Like Rotten Eggs (scroll down to page 2)
Let me know if you need further assistance. Thanks.
Jun 18, 2010 | Kitchen Ranges
1- machine operates with the door open. 2 - water
So if I fixed it you want me to give that info to you for free but otherwise you want to charge me for an answer?
Oct 29, 2009 | Bosch SHU9922UC Built-in Dishwasher
Gas smell in my water filler tube kneck? bad intake gasket?
Carry out sa compression check wet and dry. Then i'm affraid its head off time.
May 27, 2009 | 1998 Chrysler Cirrus
Had standing gray water under house got the water out and fixed the drain problem but still have the smell How do we get rid of the smell of the stagnent water its bad. Thanks
Many commercial cleansers are good for neutralizing odors, but several common household products can be used as well. Vinegar is an extremely versatile grocery item that neutralizes many odors, including those left behind by pet accidents and skunk sprays.
Baking soda, whether applied dry to an area or mixed and sprayed with warm water, is another effective way to absorb and neutralize household odors. Baking soda carries the added benefit of absorbing moisture, so it often makes a good secondary application for a moist stubborn stain causing an odor. Citrus fruits like lemon and oranges deodorize and leave a pleasant smell behind. Using citrus juice on fabrics is not usually recommended, but they are good for things like running through garbage disposals.
May 11, 2009 | Dishwashers
Smelly refrigerator
HI.
i guess u will benifit from this link
plz rate this post
click here
BEST REGARDS
Aug 13, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
1 year old LG washer
Greetings rh48192,
Are you using HE (High Efficiency) detergent in the unit? Most times the odor found in the units is because owners use regular laundry detergent instead of the low sudsing HE type. It is imperative that you use the proper detergent to avoid odor in your unit. Some of the fixes are to run an all bleach cycle with no clothes in the unit. Also, to leave the door to your unit open when not using it or at least cracked to allow the unit to dry out. Make sure to wipe out the gasket of the washer, sometimes trapped water there can also smell over time. Finally, there are some commercial products you can use to lessen or eliminate the smell. Here is a link to one product you can purchase at your local Best Buy™ store. http://www.bestbuy.com/site/olspage.jsp?skuId=8550249&type=product&id=1188560830483
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 24, 2008 | Washing Machines
Bosch SHU9922UC Built-in Dishwasher Logo
205 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
