Question about Whirlpool LER4634J Electric Dryer
Whirlpool gas (Propane) dryer
Dryer turns on and runs but will not ignite the gas (Propane)
    Sergeant:
  • 249 Answers
Sounds like the part that causes the spark, igniter is bad
Posted on Jun 19, 2009
    President:
  • 1,136 Answers
Hi, Remove the small plastic cover on the front lower right hand corner. Start the dryer and see id=f the ignitor glows. If the ignitor glows and shuts down before igniting the flame, follow these instructions. UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Convert dryer to propane. We have the Whirlpool converter for Maytag dryer.
If this is natural gas dryer, you need a certified gas technician to do the work. You can't do it yourself as it is too dangerous. The gas air mixture and the gas pressure has to be set with a tool called a manometer.
If the dryer was electric, and you want to convert it to propane, that is impossible and can't be done.
Feb 07, 2017 | Whirlpool Dryers
How to perform LP conversion for DLG5002 dryer I
you first need to turn the screw on the gas valve clockwise to close it,then replace the l.p. orfice to the propane orfice on the burner tube and put the enclosed sticker on the gas valve that it is now set for propane gas operation
Jun 12, 2011 | Whirlpool LGR5636L Gas Dryer
I have a propane dryer and it ignites but wont heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 25, 2010 | Whirlpool Dryers
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
A friend gave me one kitchenaid dryer , i don't understand. canI use eletric power and propane, or only propane. I don't have the propane pipes conections, can you please help me understand it?
Your propane dryer only dries with propanr. The electrical cord is for the motor that turns the dryer and for the controls. If you don't have gas piped into your house then your gas dryer is useless. Either get an electric dryer or pipe gas into the house. If you have Natural gas in your home, then you need to get a conversion kit to make your dryer run on Natural gas.
Jun 17, 2010 | KitchenAid KHEV01RSS Dryer
Igniter won't glow
I am assuming that everything works OK except you have no heat?
When you turn on dryer listen for gas valve to click(this may take a few seconds).If you don't have a click then the gas valve my be bad or it is not getting power.
Dryer has to be running to check for power only experienced persons should perform machine running power tests.
Let me know If I can do anything else to help.
Mar 20, 2010 | Whirlpool LGR5636L Gas Dryer
My dryer doesn't produce heat. the coil ignites
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. In your machine, it appears Amana doesn't sell the coils as a separate item and the whole valve needs to be replaced. The part number is Y504091.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
At front, remove 2 screws near floor at the bottom of the lower front panel. Pull bottom of panel toward you and down. The gas valve should now be accessible on the left. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Reverse process to re-assemble.
Sep 17, 2009 | Amana ALG331RAW Gas Dryer
Convert propane dryer to natual gas
You need the NAT gas orifice and the stem under the cap on the burner needs flipped over
Jun 08, 2009 | Whirlpool GGX9868J Gas Dryer
Whirlpool LGR4634JQ1 Ignites the first time, then will not ignite
Hi, You will need to change the coils on the top of the gas valve. They are a plug in coil. This is a very common problem. If you need assistance on how to change them or the part#, I can help you. I would need you model#.
Thanks
Vic
May 13, 2009 | Whirlpool LER4634J Electric Dryer
Convert Whirlpool dryer from propane to gas
You must purchase a conversion kit from your appliance parts store.
Mar 21, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool LER4634J Electric Dryer Logo
90 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
