Question about Coffee Makers & Espresso Machines
Watersystem fault miele cva 620 - Coffee Makers & Espresso Machines
SOURCE: miele coffee maker cva 4070
OK. Here's the deal. I struggled with this CVA 4070 (F 73) problem also recently, and even posted a questions in the cyber world about it. I jiggled, re-cleaned the machine, re-read the Miele manual, and scoured the internet for schematic drawings of this brewing unit's insides. No luck. Finally after finding out I'd have to pay $199 just for a service clown to walk in my front door, I said NYET!!!  I must solve by myself. If I can take apart & fix my Dyson, etc, etc, I WILL DO THIS TOO!!  (MUST HAVE COFFEE>>>)
Pull out the brewer, turn it a quarter-turn to your right, and look at the spot where that small black plastic piece -- shaped like a block "M" or block "W" -- should be situated. Pull it out, if it isn't out already. Don't worry about yanking it out or harming these parts, said the Miele troubleshooter guy in New Jersey on the phone. They're "made from the same plastic used in football helmets."  Okey-dokey.
This approx. 1.5" wide, blocky plastic piece is part of the "slide" that takes the brewed coffee grounds into the waste container. When positioned correctly, it looks like a block "W,"  with the "wings" ointing up, and slides in just under a brown 1.5" flat piece. A small, down-facing tab on the brown piece clicks into the "W" piece and holds it in place. The "W" should feel fairly solid, although it is not rigidly in place, as the entire mechanism is a movable system to deposit the grounds in the waste receptacle.
Put everything back inside your CVA 4070 "love" machine, hit "on," and wait for it to go through its warm-up.  No F73 message?  Yeah!  Mission Accomplished. You, like I, have fixed your Miele, saved your family relationships, and saved yourself a bundle from unnecessary service calls.
Posted on Apr 09, 2009
reverendrave
  • 24 Answers
SOURCE: Miele coffee machine shows
Hello Wiesiek1,
The water system fault means that there is too much water on the bottom drip pan and it has tripped the sensor at the bottom of the machine. Usually removing the bottom grate where the cups sit and taking some paper towels and soaking up the water/spillage will fix this problem
Posted on Sep 15, 2009
SOURCE: display message - brewunit block - can not undo to
YOu must turn the machine off...hold both the small coffee and hot water button...tunr the machine on to light...let go of the buttons..then hold in the large coffee button for a few secinds andletgo ..if that doesn't work hold in the medium coffee button for a few seconds and letgo..that shouldreset the brew unit.
good luck
Posted on Jan 21, 2010
SOURCE: My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
Posted on Mar 15, 2010
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
Posted on Jun 03, 2010
Miele CVA5065 coffee machine has fault 77
I am not familiar with a CVA 5065 - but most of the other Miele coffee systems fault 77 is the ceramic valve initialization or the switch (S51) associated with it.
Apr 20, 2014 | Miele Coffee Makers & Espresso Machines
Miele coffee machine cva 620 saying water system fault
Wow, I used a shop vac as someone else had posted. I realised that there are actually two valves where the water tank rests so I vaccuumed from the valve closest to me and a lot of water was sifoned out. Then my CVA620 coffee maker reset itself. Make sure you go through the coffee making process as the first coffee was not up to standard.
Apr 14, 2012 | Miele Coffee Makers & Espresso Machines
Miele 4070 watersystem fault but the catch tray has no water so it's not overflowing. What might this be?
it is leaking internally. When the drip tray is full, it tells you to empty the drip tray. when the machine has a problem and develops a leak, it locks up and displays watersystem fault. contact miele at 800 843 7231 and they can put you in contact with a service center in your area.
May 25, 2011 | Miele CVA4070 Coffee Maker
Parts list and drawing for a miele CVA 620 coffie machine
you would have to contact Miele spare parts for this information it is not readily available on the internet.
Nov 19, 2009 | Miele CVA610
Miele coffee machine shows"watersystem fault"
Hello Wiesiek1,
Aug 29, 2009 | Miele CVA4070 Coffee Maker
Jul 05, 2009 | Miele Coffee Makers & Espresso Machines
No program mode in Miele CVA620 espresso machine
my miele cva 620 coffee machine not working only the LED screen lit up and nothing else? any ideas.
Apr 10, 2009 | Miele CVA2650 Stainless Steel Espresso...
Watersystem fault
Thanks for the solution . I fixed my "Watersystem fault" . The wet switch in the unit is activated when water gets into the base of the machine to prevent water damage to the cabinetry .
Sep 08, 2007 | Miele CVA615 Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
