Question about Samsung Office Equipment & Supplies
Samsung CLX 3180 - characters repeated vertically
When printing the printer prints the page well but on the left side of the page there is vertical repetitions beneath one another of what I'm printing. These repetitions are in blue, magenta, and yellow. Help!
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 150 Answers
REPLACE TRANSFER BELT OR WIPPER BLADE
Posted on May 08, 2014
jtuminaro
  • 56 Answers
SOURCE: BROTHER MFC 7420 PRINTER SOLID VERTICAL LINE...
Open te lid and look at the glass. You have dirt or white-out or something on the thin strip of glass to the left. Clean that glass!
Posted on Jan 15, 2009
  • 32 Answers
SOURCE: Xerox Phaser 8560 Color not correct
the problem is not with the printer but it is with the ink that might be damaged, this is located inside the printer
Posted on Dec 01, 2009
  • 670 Answers
SOURCE: Samsung CLX-3160FN Vertical lines when printing black
This is a very common problem with Samsung CLX-3160 and CLP-300 printers. The real problem is that the developer blades get dirty with the toner. Buying a new imaging unit will only fix the problem for a short period of time then it starts to get buildup on the developer blades.
You need to clean the developer blades. If there are streaking on any color, then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Posted on Dec 24, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: vertical lines printing on one side of the page
9 times out of 10 this is coming from one of the two drum (photoconductor) units. Just open the right side door, release the waste toner box, and remove the 2 drum units. The larger one is the color drum unit and the smaller one is the black. Look down thru the slot in the top of the unit (3 slots in the color drum) and look at the green colored drum surface. On one end or the other you should be able to see the same lines on the drum surface that you are seeing on the paper. One of the 2 drum units should have the lines and that will tell you which one will need to be replaced. Hopefully it will be the black drum unit as they are relatively cheap. The color ones are $350 to $400
Good Luck and Thank You for using Fixya.
Posted on May 12, 2010
SOURCE: Printer LCD "Replace/Install Toner Waste Bin
I have just now, taken the waste toner bin out, squirted in some hand soap and water. Shook vigorously and rinsed it out. the CLX-3175 is working a treat again !
Posted on Jul 31, 2010
My samsung scx-4200 printer prints very faint on the left hand side
removed the toner and shaken it and then replace it.then it prints normally. or problem not solved you have to replace new toner.
Aug 05, 2012 | Samsung SCX 4200 All-In-One Laser Printer
Samsung clx-3180 printer is showing printer offline and will not print from pc.
CHECK
Printer is connected and power ON
In panel contro
go to Printers
choose Samsung Clx rigth click
unmark the check Use printer offline
Try printing a test page
rigth click Properties
click on
Print test page
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | Samsung CLX-3160 All-In-One Laser Printer
I have a Samsung CLX-316N multi function colour laser printer. I am getting very poor print quality when trying to print photographs, using laser photo paper. The printed photos have vertical streaks of...
Dear This is the Quality issue.
can be solved by replacing black developer in imaging unit.(better solution)
Alternate is change the Imaging unit(costly solution).
Dec 06, 2010 | Samsung CLX 3160fn All-In-One Printer
Sep 07, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Faded vertical section on a printed page.
this problem occurs due to dust particles in the paper feeder belt (steel rod with rubber ) clean it and print
Sep 06, 2009 | Samsung CLX 3160fn All-In-One Printer
Vertical line on page when scanning/faxing
Clean the scanner glass. You probably have some dirt or whiteout on it. Open up the top feeder and look at the narrow glass and you'll probably find it.
Mar 17, 2009 | Samsung CLX 3160fn All-In-One Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Jan 14, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung ml-2010 printer prints vertical lines on the page
it may due to scearch on roller. check the roller for any scearch mark.
Dec 23, 2008 | Samsung ML 2010 Laser Printer
Poor quality printing
It looks like the scanner unit having fault, get it replaced.
Feb 19, 2008 | Samsung CLX 3160fn All-In-One Printer
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
