Question about Siemens Kitchen Ranges
Schott ceran 9000142412
During the last 3 months I have observed problems in turning on the Ceran using the Power On (point in a circle). So far I have solved the problem by turning off the main switch in my house, let it stay off for a minute and then turning the main switch on. After this short procedure the Ceran could be powered on - but not today ! Can you please help me ? Viggo Elmetofte Denmark viggo@elmetofte.dk +45 3020 0004
5 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: My ceramic hob "ceran (schott)
The only thing you is to default factory setting so it will unlocked..
Posted on Jun 19, 2008
redkcir
  • 36 Answers
SOURCE: schott ceran stove top from Sears, all burners are
Check here...
http://www.schottceran.com/
Also try and find a product called "KickIT" of get it here.
http://www.muleheadbrand.com/pdf/degrease-it-etc--web.pdf
This is an industrial degreaser I used at work. Be careful with it as it will peel paint! But is does a great job cleaning the oven top. Spray, let it set a few and spray again. You may still need the scraper, but it will come clean much easier.
Added TIP: Got one of those reusable filters in your window AC unit?
Take it outside and spray it down with this full strength. Hose it off when you are done and it will look like new. I also use it to clean smoke residue and crud off of computers (caeses) for a fairly new look.
Posted on Jan 04, 2010
ginko
  • 19396 Answers
SOURCE: I have Whirlpool Schott Ceran
Hi.
F3 E2 is a temperature runaway error. It means that the control board detected that the oven is too hot. If there is no effective overheating the error occurs because the temperature sensor is shorted.
here the explanation from manual:
F3 E2 : Oven too hot, over heating
Solution:
Test and replace oven temperature sensor.
Before replacement the temperature sensor must be tested. A good sensor will read about 1080 Ohms at room temperature. If the sensor is shorted will only read a couple of Ohms or zero.
If the sensor is good the problem can be the control board, wiring to temperature sensor, or in sporadic cases an heating element that stays always on because of a wiring contact. The last case is quite uncommon.
The most common fault is a defective temperature sensor. The sensor is a probe located inside the oven cavity. The sensor is attached to a two wires connector and held by one or two screws. Disconnect power. Remove the sensor. Undo connector and read Ohms at connector. If there is low impedance replace the probe.
Here a tip explaining how to find parts and diagrams for most aplliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Posted on Sep 07, 2011
bilbiljim
SOURCE: Schott Ceran stove top not working
Sell it! We had one and it was a constant nightmare, seemed to have a life of its own, one minute functioning, next not. We actually gave it away to friends and bought an old-style hob instead! 4 months later THEY got rid of it too!!!!!!!
Posted on Dec 07, 2012
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
Just purchased Ilve Ceran ceramic cooktop. Is V364X the cooktop model number?The outer are of the left front burner does not heat up
You may already be aware of this but ... If our ilve ceran cooktop is the same as yours turn the knob past the 12 setting till you feel pressure and it springs back. This is the switch to fire up the marked outer elements.
Mar 11, 2012 | Cooktops
I'm using Nokia E63, my battery was gone a month before, so i bought a new BP-4L from Nokia point, it only gives 2 days standby back up, which my old one gaves me 5 to 6 days. is there something i
I will tell you what! I own 3 Nokia phones. And I know how to extend battery life (before recharge is needed) by UNloading the battery! Turn off location services, wifi, cellular data, and automatic updates, and only use them when you NEED them ... then, OFF they go!
During the Obama administration, they started TRACKING every citizen (and perhaps non-citizens too), 24/7/365.25! That is a terrible waste of battery power on all cell phones. Without all those TRACKING services on, my batteries (one per phone) can go for WEEKS without a recharge!
May 12, 2017 | Nokia BP-4L Battery
My keyboard says it is out of batteries after only 1 week. I have tried putting brand new batteries in and the same thing happened - this time, they only lasted 3 days! During this time the keyboard lost...
There is something definitely wrong with your keyboard. My batteries last 4-6 months or more.Even with real cheap junk batteries and a lot of use the batteries would last a month or more.
The first and about only thing you can check for and fix is a stuck key. If the key is stuck down the keyboard uses far more power (about 20x) as it is transmitting. That is about the only thing I can think of that will drain the battery that fast. The problem is it sounds like is actually working normally when its working. The disconnecting is going to be either internal or the antenna placement. With it connecting and disconnecting it would use more power but not that much.
I would check for stuck keys, but after that I'm afraid a replacement keyboard. There just isn't that much to fix inside or out of these things so you have very few options on what to do. If you have warranty get it exchanged asap.
Sep 03, 2010 | Apple Wireless Keyboard
Maytag side by side refrigerator/freezer
the drain is frozen, needs to be cleared, hose on lower back of cabinet
Jul 09, 2010 | Maytag MSD2756G Side by Side Refrigerator
Philips brilliance 200w monitor no video
nice anecdote, fixing things from far is not easy, a t.v.-technician right in front of the actual screen could tell more- but they don't come for free, alas. hope that people's idea about problem solving lead up to you fixing a problem yourself - hey this here is for free - to sort wxperts, one needs feedback! thx alot
Jul 22, 2009 | Philips Computers & Internet
When igniting, the Jandy 2 lite has tremdous flameout from unit.
I suspect that dust or debris of some type accumulates inside of the heater during months of nonuse. Store the unit in a box or a plastic bag and see if this solves the problem. good luck with it.
Feb 08, 2009 | Jandy Lite2 LG400 Ceramic Compact Heater
Focusing Issue
The screws should be short enough not to stop the primary's travel, but pull them out and try it again. Good luck! George.
Jun 25, 2008 | Celestron NexStar 11 GPS (660 x 279mm)...
Kitchen Ranges Logo
116 people viewed this question
Top Siemens Kitchen Ranges Experts
isaac johny
isaac johny
Timllfixit
rpar
Are you a Siemens Kitchen Range Expert? Answer questions, earn points and help others
