Question about Tally Line Matrix T6100 Printer
Platen open - Tally Line Matrix T6100 Printer
Louding lables
You shouldn't have to open the back of the printer. You may be having problems with the platen being too tight to allow you to load labels.
If included a picture to help describe the loading process:
Pulling the lever forward (3) releases the Platen tension. Feeding the labels from the bottom of the roll (4) into the slot shown. With the tension off the Platen you should be able to insert the label all the way through the printer
Apr 04, 2014 | Seiko Smart Label 240 Thermal Printer
Solution to platen is open problem
this is how to open the platen.
usually there is paper jam under the platen or cartridge (black)
Feb 21, 2013 | Canon imageCLASS D761 Copier
A customer's ImageClass D880 fax/printer's display reads PLATEN IS OPEN / PLEASE CLOSE PLATEN. At the left rear of the platen is a black vane that rotates into an optical interrupter in the...
I was ever have that problem.
the solution is I moving slide the scanner section more hard then usually.
and I think that is the lock of scanner not fit.
May 31, 2011 | Canon ImageClass D880 Copier
How do i clean underside of platen glass Canon MP160
for mp160, flip the cover open, the one that you open to gain access to the ink cartridge. you will see two screws at the underside of the scanner base. unscrew both. gently pull down at the front control panel and pop up the front lip of the plastic that holds the platen glass. then, at the back of the printer, adjacent to the paper loading tray, just below the platen glass cover, you will see two clip like stuff. remove the tray by pulling it upwards vigorously but firmly. then, get a flat screw driver to pry these up to release the lock. then, facing the printer, gently pull the whole of the platen glass, together with its plastic frame, towards you. do this while gently rocking the platen glass up and down, or left and right. to return the platen glass, reverse the process.
Jan 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Platen Cover is open
if you open the platen cover, on the rear middle there is a little opening, that is where a little actuator sensor sit, and it is sticking... take a little flat screw driver and kinda flicker it.... that should take care of your problem
Jun 20, 2009 | Panasonic PanaFax DF-1100 Laser Printer
Canon image class 620
the platen moves to the left side ,for changing the cartridge,move the platen to the right.if you have a flat cable broken rear of the machine.
Dec 27, 2008 | Canon imageCLASS D761 Copier
Platen opeo error
CLEAN THE PLATEN SENSOR IF NOT SOLVED CHANGED THE PLATEN SENSOR.
Sep 15, 2008 | Tally T6218 Matrix Printer
Platen is open message, What is the platen?
Platen is usually referred to as the Copy glass ( Platen Glass) this is where you lift the top to put it onto the glass to make a copy.
Never heard of this message , was it serviced? usually the techs open it to clean the Optics (mirrors) inside.There should be a metal plate with 2-4 screws that hold it.
Aug 28, 2008 | Canon imageCLASS D761 Copier
Close platen signal
When you open and close the platen lever you will notice micro switch that should be engaged... When the lever is down to A - C. looks like this... only 2 other things it could be besides the switch... 152417-001.jpg&w=70&h=39 152417-001 P5000 Platen Interlock Switch
If anybody has been in the printer where PCBA's are, check the two cable connectors holders... seated good... worst case,it would be very rare if its CMX Board(main logic)...
Apr 16, 2008 | Printronix Line Matrix P5010 Printer
Tally Line Matrix T6100 Printer Logo
35 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
