Question about MSI 945GM2-F (945GM2HF) Motherboard
No USB keyboard identified
Not booting to windows. halt halfway
Keyboard doesn't work after boot
Try booting up with the ps2 keyboard.Once in Win 8.1, unplug ps2 and plug in usb keyboard. See if windows will recognize the usb keyboard and if so it should install software and drivers
Nov 19, 2013 | Gigabyte Computers & Internet
Every time I boot up my computer I get a pop up telling me ASUS keyboard has experienced a problem.... How do I fix this?
You will need to enter the BIOS and turn off, or disable Keyboard Errors. It should be on the first page, but varies on some models.
On the first page, there should be an option Halt on: All errors, change that to Halt on: All but keyboard or Halt on: None.
The options may vary depending on your BIOS version, but should be very similar if not the same.
Feb 16, 2011 | ASUS Computers & Internet
Asus P5RD-2-UM acpi bios revision 0811. Press del to run setup Press F8 for BBS popup initializing usb controllers..done. 992mb =32 mb shared memory avto detecting pri master ide hard disk pri master...
no keyboard detected. fatal error... system halted = your keyboard is dead, replace it. If you get the same message after a new keyboard then the PS2 connector is dead, you will have to use an USB keyboard.
Dec 20, 2010 | ASUS P5RD2-VM Motherboard
Acer laptop gets hanged every time it is opened. on dignosis it shows code 0211= key board error.pl advise
Try this:
  • open BIOS
  • Look for HALT settings
  • Change settings of HALT ON ALL ERRORS to HALT ON ALL ERRORS EXCEPT KEYBOARD
  • Wait for windows to boot then try your keyboard again
Oct 19, 2010 | Acer Computers & Internet
How do I run a Fujitsu PC headless?
while booting press F2 to enter to bios setup.
in the main tab go to Boot Features.
the first point in Boot Features is POET Errors will be "Halt On All Errors" then you have to change it to "No halt On Any Errors"
May 13, 2010 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
When i boot up my pc i have to hit the f1 key. it says something about the keyboard
This happens when the BIOS does not recognize your USB keyboard.
To clear this error:
upon start up Enter BIOS Setup by pressing F2 or F12 (whichever BIOS software it is running). On the main BIOS window change the "Halt On.." value to "No Errors". Press F10(Save & Exit) then hit Enter key to restart.
Hope this helps.
Jan 22, 2010 | Dell Computers & Internet
I have an IBM 300 pl desktop and when I start it I get "Keyboard Error"
If you want it to go aheand and boot with the bad keyboard or PS2 socket, go to the BIOS and change the "Halt on All Errors" to not halt on keyboard errors. Otherwise, you need to replace your keyboard and/or make sure it's not your PS2/keyboard socket on your mobo.
Dec 31, 2009 | IBM Aptiva E 805 (2170-805) PC Desktop
USB MOUSE x PC BOOT
Could be a problem with your system BIOS, enter the setup while your computer is booting (before it gets to windows) by hitting the F12 key probably. Make sure that the boot order is HDD first, not something else.
Aug 31, 2009 | Laser LX710 Keyboard and Mouse
I have an ei system 103a desktop i have had to sytem restore now when i turn pc on it tells me to press f1 to start windows i have tried going into the bios and boot from hardisk but still have the problem...
The 'Press F1 to continue" message is a result of an error caused as the BIOS does its hardware checks during the boot process.
The BIOS boot process (bootstrap) preceeds the loading of the operating system.
The most amusing example of this occurs if you unplug a ps2 keyboard,
1, it generates the error
2, pressing F1 does no good because the keyboard is not plugged in.
3, if its ps2, you will need to do a hardware reset after plugging the keyboard in again.
The bios can be set to 'halt on'
'no errors' which will stop the error message appearing.
'keyboard errors' see above
'all errors' any hardware failure detected by the bios will halt the boot process and give the above message.
Mar 11, 2009 | Computers & Internet
Keyboard failure message on boot
if you can access your bios .... it's the first choice on that menu after you are in that section scroll down the page... you will see "halt on errors" or similar... change that to none.
Feb 23, 2009 | Logitech Computers & Internet
MSI 945GM2-F (945GM2HF) Motherboard Logo
18 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
