Question about Refrigerators
I want to know what numbers I should use for admiral refrigerator and freezer setting
What numbers should fridge and freezer be set at
    Novelist:
  • 150 Answers
Typically the halfway point of each dial/indicator is recommended/satifactory, IE: (5) 12 to 24 hours is needed for the unit to stabilize after making changes. Pleazer Appliance...
Posted on Apr 20, 2014
I have an Admiral LTF2112ARW refrigerator. The refrigerator is working but the freezer won't stay cold even though the thermostat is on the coldest setting. Any suggestions about what is wrong?
ITS NOT A GOOD IDEA TO USE THE COLDEST SETTING CUZ WHAT U WILL GET IS EXACTLY THE OPPOSITE A MORE WARM SETTING. A HIGH SETTING CAUSES THE COMPRESSOR TO OVER WORK IT SELF CREATING TO MUCH COLD IN ONE SECTION TO THE NEGLECT OF THE OTHER SECTION. UR PROBLEM IS NORMALLY THE OTHER WAY AROUND TO MUCH FREEZER AND NOT COLD IN FRIDGE.? BUT i WOULD CHECK THE THERMISTORS IN THE FREEZER. AND ALSO TRY ADJUSTING UR SETTINGS TO MED AND CHECK UR AIR FLOW CONTROL VENT AKA COLD CONTROL THERMOSTAT.
Feb 23, 2015 | Admiral Refrigerators
We have a Admiral Top Freezer Refrigerator Model#
sounds like a defrost problem. if the freezer section gets too much frost build up then it wont be able to move air into the refr section. check to see if you have "heavy" frost in the freezer and if so then a defrost thermostat or a defrost control board may be you problem.
Nov 02, 2013 | Admiral Refrigerators
Admiral american fridge freezer constantly blowing cold air into fridge compartment.
Changing the freezer settings won't really make a difference because regardless its still going to be freezing. The way the machine works is the freezer cools the fridge, and there should be a control in the fridge that operates the baffles in the airway between the freezer and fridge and reduces the amount of air that enters into the fresh food section.
Jun 17, 2012 | Admiral 26 cu. ft. Side-By-Side...
Maytag admiral fridge freezer not cooling
Hello there,
If the refrigerators fridge and freezer is not cooling. You need to check if the temperature is set to the highest. Then you check if the thermostat is still working.
Then you check if the compressor and fan are running. If they are, then it simply means all you need is to refill the gas tank with some freon or refrigerant as you may know it by.
All the best Elect_Comp
Oct 09, 2011 | Refrigerators
I have an admiral sal2027gbb and the alarm keeps sounding. there is ice building up on the back of the freezer. we have dad the sensor replaced and heating element but has not solved the problem. can you...
Could be the temp is set too low that would cause the ice build-up, thus causing the alarm to set off. Try defrosting the freezer, and run the fridge again.
Feb 03, 2010 | Admiral 26 cu. ft. Side-By-Side...
Freezer and fridge not cool enough
Check if the syrofoam pieces block air inlet. If so then this may be the problem.
May 08, 2017 | Admiral Refrigerators
Everything in fridge freezes intermittently
Your vent has and electronic vent controlled by a setting on the control board. The electronic vent or circuit board are most likely the reason for the problem.
I will help you if you want, Sea Breeze
Jun 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral fridge, freezer won't stay cold
Check the condenser fan, listen and see if it kicks on, if it doesn't then find someone that know how to take it apart and change them.
Jan 31, 2009 | Maytag Admiral Top-Freezer Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
