Question about Samsung GT-S6102 Galaxy Y Duos Dual SIM Smartphone with Bluetooth, Wi-Fi, Android OS, HSDPA 850 / 2100 - Unlocked Phone - No Warranty - White
How to unlock screen pattern due to many attempt
Too many attempt pattern
    Producer:
    Uploaded 30 video answers.
  • Samsung Expert
  • 309 Answers
Let's start with the most common Hard Reset methods and go from there:
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlightsFACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release thePower key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and theCamera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press theVolume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both theVolume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap thePower button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and thePower button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Important Note: On some Sharp models (such as the Sharp FX Plus ADS1) if holding the Sym button and Power key simultaneously doesn't take you directly to the Android system recovery screen you might have to do one additional step. If using this hard reset key combination takes you to a screen which shows an exclamation mark within a triangle, then press the Home key (while on that exclamation mark screen) and this should take you to your Sharps Android system recovery options.
Posted on Jul 04, 2014
4 Suggested Answers
  • 4 Answers
SOURCE: how to unlock forgot the pattern or password
hi
your mobile need a complete software update , please contact the mobile service expert for this problem
Posted on Mar 06, 2013
  • 83 Answers
SOURCE: describe how to unlock my
easy as pie download android sdk from google install it on your c drive under android sdk then download and install the usb drivers for your phone then right-click on "my computer" on your pc select properties select environmental variables highlight path select edit and ad in c:\androidsdk/adb/tools then plug in your phone to the pc open a command prompt via the run function on your start window and enter: command then type in "adb" press enter then type in "adb" devices then press enter at this point you can unlock your phone via an adb command listed in the command promps once you type "adb" then press enter ill link a youtube video its not as hard as it sounds its just not the easyest thing to walk a person through with a written discription. if you still dont feel upto it pay someone on craigslist 10 or 20 bucks to do it for you they will offer you the option to root your device witch is awsome but more dangerious or annoying than 90% of android users. sorry for the long explanation. here is your youtube link
Posted on Mar 11, 2011
SOURCE: I can't open my samsung galaxy 5 due to over attempted of different patterns.
too many pattern attempts so how to clear this problem
Posted on Jun 05, 2013
How to unlock ,after many pattern attempts.
go to your gmail you should be able to do it from there
May 17, 2013 | HTC Wildfire A3333 Cell Phone
Forget the pattern lock
  1. On the unlock screen, attempt to enter your unlock pattern five times.
  2. When prompted to wait for 30 seconds, tap OK.
  3. If the display goes off, press the POWER button to turn the display back on and then press the bar on the lock screen and slide your finger down to unlock the screen.
  4. Tap the Forgot Pattern button in the lower right corner when it appears.
  5. Enter your Google Account name and password, and then tap Sign in.
You are then prompted to create a new screen unlock pattern. If you no longer want to use a screen unlock pattern to secure your phone, tap Cancel.
Mar 25, 2013 | Samsung Galaxy Ace Gt-s5830i - Black...
I need to unlock my phone.. It says use a pattern but i never put one in there and also when i have the option to log into my gmail to fix ot.. Ot says invalid. How do i get the screen unlocked
If you have forgotten the screen unlock pattern, you have up to five attempts to try and unlock your phone. If this fails, you can unlock HTC Inspire 4G by entering your Google Account user name and password.
  3. If the display goes off, press the POWER button to turn the display back on, and then press the bar on the lock screen and slide your finger down to unlock the screen.
Follow that instruction step by step and if you success you get your HTC unlocked, remember read that instruction carefully, if you did wrong step you will not allowed to enter your google account.
Sep 05, 2011 | HTC Inspire 4G Smartphone
I put a new password lock on my phone ( HTC desire ) when drunk and have now forgotten it
If you have forgotten the screen unlock pattern, you have up to five attempts to try and unlock your phone. If this fails, you can unlock your phone by entering your Google Account user name and password.
Jun 17, 2011 | HTC Desire Cell Phone
Pettern lock
To unlock the pattern screen lock without signing in with your Google account You need to repair the software of the phone.
The steps to repair the phone are the following:
1. On the computer: Start PC Companion™.
2. On thecomputer: In the Support Zone™ descriptor, in the Software Updatesection click Start > (Repair) and follow the instructions on the PCmonitor screen.
3. Turn off the phone.
4. Connect the USB cable to your computer.
5. On the phone: Press and hold down Back key and connect the USB cable to the phone.
6. Follow the instructions on the screen.
Note : The software in your phone will be replaced. All personal data stored in your phone will be lost.
There is also a way to unlock the pattern screen lock by signing in with your Google account.
1. After 30 seconds, tap Forgot pattern?
2. You need to log in with the primary gmail.com e-mail address and not the alternative email address connected to the Google account.
3. Tap the username field and enter the primary Google account user name.
4. Tap the password field and enter the primary Google account password.
5. Draw a new unlock pattern and tap Continue .
6. Draw the new unlock pattern again and tap Continue .
If these options are not available to you, please describe preciselywhat you see when attempting to connect to your PC and use PCCompanion.
Jun 05, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Please i need to unlock my T-Mobile G1 mobile phone. How can you help me with remote unlock if i provide IMEI number.
Exactly how are you locked out? If you're stuck on the lock-out screen with a lockout pattern that you've forgotten? If that's the case, the G1 manual indicates the following:
"When you fail to draw the correct unlock pattern on the screen after five attempts, you will be prompted to wait for 30 seconds before you can try again. If you forgot your screen unlock pattern, touch Forgot pattern. You will be prompted to sign in using your Google Account name and password, and create a new screen unlock pattern before the Home screen displays."
Aug 21, 2009 | HTC G1 Smartphone
Samsung GT-S6102 Galaxy Y Duos Dual SIM Smartphone with Bluetooth, Wi-Fi, Android OS, HSDPA 850 / 2100 - Unlocked Phone - No Warranty - White Logo
85 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
