My ir3300 copy setting for elction card and ration card
How to connect this ir3300 xerox machine to computer plz tell me sir i request u
you need to have a driver installed on each P.C
http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/imagerunner_2200_2220i_2220n_2800_3300_3300i_3300e_3300en_3320i_3320n/imagerunner_3300#DriversAndSoftware
You need an ethernet network of computers
You need to set up the ip addess and subnet mask in the printer via its setup menu . At the very least a ethernet network Switch with static ip addesses for each device , or A router with DHCP server to dynamically assign ip addresses.
you need an rj45 socket on the ir3300 which it should have 802.3 ethernet 10/100 tbase ethernet according to ir3300 specs if it is missing you need a network card to be added to ir3300 by Xerox / Cannon
Sep 05, 2015 | Xerox Office Equipment & Supplies
How can I better the print quality of Cannon IR3300
How many copies drum made?Maybe you have to change it.Clean the optic mirrors platten glass,transfer roller...
Jul 31, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Ir3300 black page coming how to rectified this problem plzz help
True multi-functionality means you get more for your money in less space with the iR3300 black and white office photocopier. Handling the work of many in one compact solution, the iR3300 provides a cost-effective solution to your printing needs.
Features of the iR3300:
  • Provides copying, printing, scanning and faxing all in one unit.
  • Has a print speed of 33 pages per minute .
  • High capacity paper supply
  • Double-sided printing as standard.
  • Compact and reliable design.
  • Productive and space saving finishing options.
Jul 22, 2012 | Canon imageRUNNER 3300 All-In-One Laser...
I have lost my voter Id so pls give me sollution, i live in orissa ,dist-ganjam,town -berhampur,pin-760001
The first thing that you need to do is to file an FIR in the local police station. After filing an FIR, you need to to take a copy of the FIR. Along with the form 002 the copy of the FIR must be attached. One needs to submit Rs. 25 to the local Electoral Registration Office as penalty.Other than the FIR copy of the missing voter ID card there are other documents that need to be carried like the passport, ration card, driving license, pan card etc.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 24, 2011 | Facebook Apps
In my ir3300 xerox in very light
That means that you have to clean copy glass , lenses, ccd,...maybe even laser unit if you know how.
On digital machines dirty optics means light copy, on analog oposite, dirty optics dark copies.
Just one more question how do you mean " charge toner"?
Jun 07, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
How to reset factory setting for Canon ir3300 copier?
Could try MMI clear to reset user settings to factory default. In Service Mode go to Copier > Function > Clear > MMI Then press ok.
To get into Service Mode Additional Functions (has * on it) > 2, 8 > Additional Functions.
Jul 26, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Need user's manual for imagerunner ir3300
Here's a link for your manual. Good luck. If this helps you plz rate this as 'fixya'. If you need more help leave a comment & I'll be happy to help. Thank you kindly.
http://ris-systech2.its.yale.edu/ris/driverdownload/CanonIrSeries/Manual/Rui_g.pdf
Mar 06, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
131 people viewed this question
jasbo
jasbo
