Question about Kyocera FS-1118MFP Laser Printer
If i make more than one copy on a km fs1118 the print moves up and down on the page
I am having a problem with a Kyocera fs1118 if i make more than one copy the print moves up and down on the page I have already cleaned the registration clutch
krizanto81
  • 65 Answers
SOURCE: how to clean waste toner bottle
Disposal Tank is on the Process Unit... you will have to remove the screw on the left side then pour it out on the bag...
Posted on Oct 14, 2008
Cogz
  • 1326 Answers
SOURCE: Kyocera Mita 1635 Copier Printing Very Light Copies
Is one side lighter then the other side of the copy? Meaning uneven copy darkness? If so, I believe the problem is that one or both sides of the drum cartridge and the developer are not connected correctly. The two parts need to be close togather to make a nice dark copy. This model has a very wierd drum unit and has a defect that one or both side of the drum unit locking tabs break and you get very light or blank copies. It's some what coastly to replace the whole unit... That would be a worse case.... If it is just on one side you might be able to push on the cover on the side that is light. If the copies come out better. One side is broken..I would fold up some paper and make a wedge to push the catridges closer. Good Luck
Posted on Apr 16, 2009
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Posted on May 25, 2009
cbtmaya
  • 84 Answers
SOURCE: error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Posted on Aug 31, 2009
n25an
  • 622 Answers
SOURCE: Kyocera FS1118 mfp gives error code CF 040 after start up
do a google search for the service manual and then lookup the error code in the service manual
Posted on Dec 24, 2009
Kyocera KM 4050 Working properly. but sometimes its it's creating lots of problem. some times the part of machines are not available,and the distributors are too rude. they are not help for queries.
Push the unit out the window and buy a different machine, if you are constantly having problems and the vendor cannot resolve them, it is time to move on. If you are under any sort of service contract, threaten legal action if they do not fix the machine.
Dec 17, 2016 | Kyocera Km-4050 With Feed, Finisher, Bank,...
Kyocera Mita 2050 there are streaks of toner appearing on the pages printed.
If you send a print job or print a report from the copier and there is no streaks then the problem is most likely the thin **** glass to the left of the large glass. It just needs to be claened.
If the streaks are happening when printing and copying then the problem is most likely your drum unit (MK-410) or possibly the fixing unit (FU-410), the fixing unit is the one that gets hot.
As the drum gets old it can cause print/copy issues and the cleaning blade that cleans the drum gets to the point it doesn't clean the drum properly causing streaks.
The heat roller has a teflon coating on it and as the roller gets older the teflon starts to come off and can effect prints/copies.
The drum unit should be replaced every 150,000 pages and the fixing unit every 300,000 pages on the KM-2050.
I hope this is helpful,
Shawn
Nov 15, 2010 | Kyocera Mita KM-2050 Printer
Kyocera Mite KM-1510 printing on half pages instead of full pages
It sounds as if the paper size at the machine is set incorrectly. Try checking to ensure you cassette or bypass if that is where you are printing from is set correctly.
Feb 16, 2010 | Kyocera Mita KM 1510 Laser Printer
HOW TO GET PAGE COUNTER IN KM-1510
Just hold down the stop/clear button for 3 seconds..
It will flash F24 then 3 increments then 3 more.. eg; F24>063>123
It means you have done 063123 copies/prints..
Sep 18, 2009 | Kyocera KM-1510 Copier
Kyocera Mita KM-2530 Laser Printer will only print the first page not the rest.
Try changing print driver and switch emulation to kpdl auto if not already there. If this doesn't work go to properties on driver under font and switch to bit map. Don't do this step unles yo have to it really slows down your printer.
May 29, 2009 | Kyocera Mita KM-2530 Laser Printer
We produce a small magazine of 20 pages (A5) using open office writer. The problem is that when we print 200 copies on the Kyocera 3035 it seems to send each copy to the printer in sequence taking well...
for printing 4000 pages in a hour or hour-and-a-half, that is not bad. it could be better.
the changes in the open office not in the printer. Try to send the print job to the printer with spool on and uncheck the print the last page first.
Feb 26, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera FS-1118MFP Laser Printer Logo
27 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
