Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
I had the same problem-- machine stopped and wdnt drain
I checked the lid switch like others suggested, and it did the trick. Thanks so much for the help!
  • 15,935 Answers
You're welcome.
Thanks for using FixYa!!
Posted on Sep 11, 2010
Why wont my philco washing machine drain or spin
Many washing machines won't spin or drain if the lid isn't closed. It could be that the switch detecting the lid close position isn't working or the tang that presses the switch isn't depressing the switch enough. Check to see if the lid is closing all the way, if so, then locate lid close switch and pressing on the switch with a Q-tip. If other functions stop when the lid is opened and work when the lid is closed then you have another problem. The problem could be in the wash cycle switch, try spin and rinse all the different settings.
Nov 21, 2011 | Washing Machines
Tip
The washing machine will not spin or drain?
First of all check if the motor is running or not when you turn on the motor. If the motor is not turning on then this problem is due to fault in the motor. But if the motor is getting on and running properly then most probably this problem relates to stuck up or cracked drain pump pulley. It needs to be checked but if the pump pulley is functioning properly then check the drain pump belt. If the drain pump belt is worn out or loose or cracked/broken then it needs to replace. But if the motor is not running then before replacing the motor check the lid switch. There is a lid switch in the washer. The washing machine will not start spinning till the lid is closed. In some cases it has been seen that lid is closed still the washer does not spin. in this cases the lid switch has to be checked. if the lid switch is faulty then the closed lid will not be detected by the washing machine, and it will not start spin cycle. And this faulty lid switch can stop the motor from running.
The switch is located near the door frame in the washing machine.
This will help.thanks.
on Mar 18, 2010 | Washing Machines
My washer fills and agitates, but when it gets to the rinse/spin cycle it stops and makes a loud grinding noise. Thanks for your time
If it doesn't drain the water after the wash cycle and the sound is more like a buzz then the first thing that I suggest you check is the lid switch. If the lid switch is damaged then the machine will not pump the wash cycle water out and it will not go into the subsequent cycles. The "grinding" or buzzing sound can be caused by an intermittent signal reaching relay switches or solenoids.
Feb 03, 2011 | Kenmore Washing Machines
My Kenmore Super Capacity Plus washer will not drain. I have looked at the hose, I don't think it is the lid close switch and I can hear the timer ticking and then stop right as it should be draining I...
Follow the drain hose inside the machine to the pump, the pump could be clogged. Could have clog in drain hose too.
FYI - Drain hose must be raised in order for it to drain
Nov 12, 2009 | Kenmore Washing Machines
Washing machine stops mid-cycle, water doesn't drain
Sounds like you have a bad lid switch, or the plastic plunger on the lid that engages the lid switch is broke. if the plunger is broke, it is cheap, and only 2 screws to remove and put new one on. if that is not broke, check the lid switch. This model is a lid switch, and lid lock in one. You can test it before replacing it if you have a meter. you need to hinge the lid up to check and replace the lid switch. use a putty knife, on each side between the top and top of the front panel. slide the putty knife in one side, it will hit a bracket if your in the right spot. press in, and lift on that side of the top. do the same on other side, just don't let go of the first side or it will latch again. then swing the top back, the back side is on hinges. the lid switch is on the right side attached to the top. unplug washer, remove the 2 wires on the switch and check continuity. there should be continuity, or "open" when the lid is closed, and no continuity, or "closed" when you open the lid. if it is "closed" even when lid is closed, replace the lid switch. let me know if you have any further questions, shane.
Sep 12, 2009 | Washing Machines
I have a Kenmore Washer that stops in the middle of the washing cycle. The water doesn't drain or anything. I have to take all of the clothes out and scoop out 90% of the water and than turn the washer to...
Hi
Thanks for using FixYa. Please check the belt and lid switch or a broken lid switch plunger. Also check the lid switch actuator and the timer. Please replace whichever is required to be replaced.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 11, 2009 | Kenmore Washing Machines
Kenmore machine stopped spin. Checked the
Check your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If not activated by a lid strike, other models have the lid switch located under the washer casing next to one of the lid hinges. It is activated by a rod contacting an actuator. The mounting scews for this type are located under the operator console.
If you determine the switch to be defective, the following link explains how to access the washer interior and replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of a replacement is $25 to $35.
If you have questions, please let me know. I hope this helps you.
Key Symptoms:
If the Motor Coupling were bad the washer will not agitate or spin, but WILL drain.
If the Lid Switch fails, the washer will fill, but stop before the spin cycle and WILL NOT drain.
Aug 23, 2009 | Washing Machines
Ge washer won't stop draining water even before
Try these
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
Pls rate my suggestion...
Jul 23, 2009 | GE Washing Machines
WSSH300G0 won't spin - filter is clear
Check your lid switch, and the strike, which is the other half of the switch, and is attached to the lid (the switch is on the machine).
Regards!, --W/D--
Jul 20, 2009 | General Electric WSSH300G Front Load...
9 cycle heavy duty 2 speed washer machine
Buba, check the lid switch for proper operation, on a lot of models if the lid switch is bad, no spin, no drain. You said you had the pump checked out. Im assuming that it was removed to check for a sock or other garment lodged in the pump. Other things you can check would be the hose from the pump to the tub, make sure it's clear and the drain hose where it exits the washer. Hope this solves the issue..
Jun 11, 2006 | Frigidaire FWS445RF
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
64 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
