Siemens thermostat rdh10rf
My heating comes on even when room temp is higher than target temp on stat
If this is battery operated it could be the batteries at fault.
Posted on Apr 18, 2014
Siemens, RDH10RF, thermostat, not turning my heating on
You likely lost the settings when the batteries died. Sound like you have to reprogram the tstat as to your application. Like switch heat type FROM GAS to ELECTRIC.
Dec 18, 2016 | Heating & Cooling
The heating comes on even when room tempreature is above that set on thermostate
Boiler make & model? Go on, knock yourself out and supply some info!
In the absence of this, I assume you have wired your thermostat wrongly.
Apr 17, 2014 | Heating & Cooling
My girlfriend has a forced air Goodman furnace in her house. Her furnace has been not running well. Whenever the filter gets dirty the furnace does not run right which it to be expected. The problem is...
where is the thermostat located? i should be on a inside wall in a comon room and not around lights, computer or heat vent or air return. a thermostat is just a switch and will operate in its enviroment. does the fan cycle off before the heat starts blowing again? the fan on these are on a timer that the t stat will have to "brake" open on reaching temp to shut off. not knowing where your at look this over and i hope it helps. i dont think i would let someone sell me a control board for this problem.
Feb 08, 2011 | Goodman GMS90703BXA Heater
DT92E room stat appears to be very inacurate with its room tempreture, our normal room temp is about 22c we have to set the stat at 25c to get heat and the stat cuts out after a temp rise of 1c
All thermostat is calibrated @ difference of 2 degree.to cut in and cut off.
In heat mode, if you keep 25 and your room temp 23. it will start at the end of 24 or beginning of 25 degree.Cut off also @27 degree beginning. Please check Tips & how to do's in Fixya
Jan 11, 2011 | Honeywell Heating & Cooling
I had my 3 year old mid-efficient furnace serviced a few months ago. I have a 4 room small bungalow. The Honeywell thermostat is set to say 72 and it says it reached 72. However, an independant...
Sounds like the switch that controls the blower is faulty. It should heat up then come on at preset temp. As for the stat where is it located. It should be located 60" off the ground not in any direct sunlight and make sure it is insulated behind the stat. You could have more heat loss in those rooms too. IE poorly insulated windows air penetrating through outlets do those walls face the wind? Is the stat located next to a heat supply?
Dec 16, 2010 | Honeywell Programmable Thermostat Heater
Honeywell CT500 Electronic Thermostat showing 73 deg room temp when room temp is actually 77 degs. Can thermostat be calibrated?
Yes,
Most all the Honeywell t-stats can be calibrated...
check out this tip to find the manual for your t-stat and then how to get into the installer setup program...
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
Aug 13, 2010 | Honeywell CT500 Digital Heat / Cool Manual...
The thermostat is not shutting off boiler when the
on electronic stats check that the temp is in sync with the room temp on touch pad push the menu button the two temps should be the same if not touch temp till reads correct
Oct 18, 2009 | Honeywell Electronic Programmable...
I have a 3 ton Coleman heat and air pump and when I turn the air condition on the heat strip comes on at the same time
If you are calling for heat and the thermostat is set for 2 degrees higher than room temp, the heat pump and strips come on.
When the room temp and stat temp are less than 2 degrees the strips turn off.
That is, unless the installer wired the t-stat for the strips to stay on.
If they are coming on in the air/cool mode then you have a bad heat relay or a t-stat wire shorted.
Mar 11, 2009 | Coleman Heating & Cooling
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
