The heating comes on even when room tempreature is above that set on thermostate
My heating still comes on even when the room temp is above that set on the stat
    New Friend:
  • 19 Answers
Boiler make & model? Go on, knock yourself out and supply some info!
In the absence of this, I assume you have wired your thermostat wrongly.
Posted on Sep 07, 2014
Remote is inaccurate
did you change the batteries ?
Dec 07, 2013 | Mitsubishi Heating & Cooling
I cannot get my thermostat althc014 to turn down by its self when room tempreature is reached
How To
Set The Temperature
The reason the stat is coming on during the night/ always
being on is setting number 5, there are 5 settings on the Salus
is the time you want heating on eg, 07.00 and set the temp (20)
is the time you want it to go off eg, 10.00 and set the temp (10 this
will turn it off)
3 is the time to come on an evening eg. 17.00
4 is the time you want it to go off eg,
23.00 and set the temp (10 this will turn it off)
5 the problem
many people have is that they do not set number 5 correctly, this is a
night/ frost stat and if you don't set the time and temperature same as 4
ie, 23.00 and 10*c then the heating will stay on.
How To Set The Time and Date On Salus Programmer?
1.Press the
Set and Select buttons simultaneously to enter the clock setting mode.
2. By using
the "UP" and "DOWN" arrow you can select between 12Hr or 24Hr clock.
Once selected press "SELECT".
3.The "HOUR"
will now be flashing. Adjust with the "UP" and "DOWN" arrow keys to the
desired time. Press "SELECT".
4.With the
"MINUTES" now flashing adjust with the arrow keys to the correct
minutes. Press "SELECT".
5.Now the
"YEAR" will need adjusting. Again use the arrow keys to change and press
"SELECT".
6.Now adjust
the "MONTH" with the arrow keys and press "SELECT"
7.Next to
change will be the "DAY OF THE MONTH" again with the arrow keys change
and press "SELECT"
8."dLS" will
now appear. This is the "DAY LIGHT SAVING" mode to turn "ON" or "OFF"
use the "UP" and "DOWN" arrow keys. Now press "SELECT"
Hope this information is what you need to operate your unit.
Oct 01, 2013 | Computers & Internet
I have Lux DW 1100 ver 2.2 Thermostat,and set temp to 20 C but last few days thermostat do not turn off furnice even tempreature is over 22-23C what usually did turn off. Tempreature get to 25-28C and I...
i have never liked the LUX brand due to faults that i seen you can replace due to having a long warrentee and possibly not have this problem again but a honeywell t-stat would be my recommendation to replace also white rodgers is a good brand
Mar 05, 2011 | Heating & Cooling
Heatpump r-22 rudd system,unit runs starts out heating then compressor stops in middle of heating ,this unit has a out side air temp. sensor just wondering if possible bad board or not
If compressor stops in middle, check the following.
1.Thermostat setting must be minimum +3 degree than your room temp
2. Check it's in heat "mode"
3. Check indoor and outdoor coils are clean.
4. Check fan motor is working alright.
5. Outside sensor and room air sensor is placed correctly.
6. Gas pressure is o.k
7.Check compressor is overheated, even all the above is o.k.
Jan 12, 2011 | Ruud UAPA024 Air Conditioner
Deart All: Thanks alot for your kind answer but do you had been ever heard about a maintenance guide or a fixing manual for the Hitachi RUA-30 AT3S package units . Actually the compressor did not worked...
Dear friend!
I think, you keep cool mode and temp setting above 30 degree C. Definately it will not work. If you need cool or heat follow this step and if still problem write there.
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Jan 10, 2011 | Heating & Cooling
Have a 1004fa model to heat a room. temp on
You may have a bad circuit board. Depending upon the age of the heater it may still be under warranty. Contact Rinnai (in US) 800-621-9419 with your serial number and installation date. Ask if they can offer a solution. Good Luck!
Jan 13, 2010 | Rinnai Heating & Cooling
Installed a honeywell rth7500 series thermostate, no air
Heat/cool wires crossed. RC- is red cool make sure the batteries are good and room temp is higher than cool setting. good luck
May 29, 2009 | Honeywell Electronic Programmable...
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
TB8220U Commercial Thermostat keeps running when temp is right
the temp coming out of the vent should be 20 to 25 deg more then room temp and if AUX heat kicks in the temp should be even more.
Jan 08, 2009 | Honeywell Electronic Programmable...
We have an InterTherm heating system. The bedroom thermostat will not shut down when it reaches tempreature. This system is about 30 years old. Do you believe the problem is the thermostat or at the...
you have a bad thermostat,there must be a 3-5 degree difference between set point temp and actual room temp,is this a boiler or forced air furnace
Nov 16, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
