Question about GN Netcom GN Jabra BT620s Bluetooth Stereo Headset - Wireless, Cable - Stereo Output - Behind-the-neck Headset
Ox81000015 error with Moto BT dongle and Moto DC800
The DC800 shows on my laptop but will not connect...error 0x81000015
I found the DC800 by the first pair function, ie; just power it up,having not put it in pair mode, as pair mode was not working...
Now it is in my BT folder but unconnected....and not connecting....WTF, how about developing this before releasing it...?
I hate being the investor in development...! This is Moto we are talking about...?!?
I cannot get ethernet connection from BT hub 3.0 on my dell inspiron 5160
try connecting through an ethernet cable. see what happens. Install the appropriate modem driver and network driver from support site.
post your comments if solved/not solved
Hope this helps
Dec 22, 2012 | Dell Inspiron 5160 Notebook
I have hp laptop and a lg cell phone i try to connect using bluetooth.i found that my device manager dont have the icon bluetooth what would i do
I f the laptop has BT Capability it may be that yo need a Dongle that little thing that plugs into a USB to connect BT to a computer you have to buy one made just for that.
Sep 16, 2011 | Microsoft Windows Vista Ultimate Edition
MY COMPUTER DO NOT HAVE A BLUETOOTH. HOW TO ENABLE A BLUETOOTH?
If your computer is not equipped with bluetooth and you want to have bluetooth on it, the simplest and cheapest way is to buy a bluetooth dongle which you can connect to your computer via USB.
Examples of bluetooth dongles
Hope this helps.
May 20, 2011 | Computers & Internet
Can i put a Internet dongle on my home PC and connect to the Internet i don't have a bt line.
If you have a wireless router then yes you can use a wifi dongle. The only reason BT users can is that BT comes with a free wireless router (bt homehub) Max
Feb 11, 2011 | Dell Dimension 3100 PC Desktop
How can i connect my bluetooth to my pc?
on pc side
1. give your host bt name
2. find bt COM port
My Computer->My Bluetooth Places->right click my device->Local Services->Bluetooth Serial Port
on phone side
1. give your phone bt name
then install pc suite and modem tool (if necessary)
restart computer
pairing
1. add device
host: go to My Bluetooth Places->Add new connection
phone: go to bluetooth, choose Paired Devices->add
2. provide passkey (4-digit, 0-9 only) on both
Check mRouter
check bt COM port that you found
Start bt serial
if you see mRouter turns green and blue, you got it
start pc suite
Oct 19, 2009 | Nokia 5000 Cellular Phone
Acer aspire 4730z bluetooth problem
Yes your Machine got WPAN: Bluetooth® 2.0+EDR (Enhanced Data Rate).
If its not working then you need the drivers, you can download them free here
If you problem was solved, Kindly do Rate!
Jul 31, 2009 | Sony MEX-BT2500 CD Player
Device only has COM port services
use blue tooth software and see the device settings.
there you can see the bluetooth audio devices.
then you will configurative access to those devices
Jul 24, 2009 | Motorola Mobility DC800 Wireless Adapter
Belkin wireless G router and MicroNet Realtek RTL8187B USB
I got the answers (for free) from Belkin's excellent technical support.
Many thanks.
Jun 18, 2009 | Belkin (F5D7230-4) Router (587009)
No music out of stereo when using Mororola DC800 and Sony Vaio FW
It's a lot simpler than you think..
1. make sure the cables to your stereo are in the LINE OUT of the dc800, and on the LINE IN or AUX IN of your stereo (trust me, double check them)
2. make sure your DC800 is PAIRED with your computer. this is different with each different "STACK" read the help files on your particular bluetooth stack to help you with this is you need more help. Remember, you have to hold the big "M" button in the front of the DC800 to pair it.
3. when you want to send audio to the DC800, make sure you CONNECT the DC800 using your particular stack. Once the DC800 is paired with your computer, you can often set up a link or icon on your desktop to connect or disconnect the device from your computer.
This should take care of it. If you are still having problems, make sure to check your audio properties to see if the audio is sending to the Bluetooth device. This is USUALLY changed automatically, but sometimes you have to tweak your settings to make sure it's sending to the Bluetooth.
Nov 15, 2008 | Motorola Mobility DC800 Wireless Adapter
Bluetooth
I have never seen a laptop that had a button to turn the Bluetooth on or off - usually the button is to turn the wireless network connection (802.11b/g, or WiFi) on and off. When you turn it on, it tells you there are no networks available since you do not have a wireless router or access point. But if you were someplace where a wireless connection is available, like Starbucks, it would show the connection and offer to allow you to connect.
The Bluetooth is normally turned off and on by software, probably some icon in your tray (next to the clock) on the taskbar.
Mar 04, 2008 | Acer Aspire 5500 5570-2609 Laptop
Open Questions:
GN Netcom GN Jabra BT620s Bluetooth Stereo Headset - Wireless, Cable - Stereo Output - Behind-the-neck Headset Logo
151 people viewed this question
Top GN Netcom Radio Communications Experts
Tom Chichester
MrFixitSTTL
techmncpa
Level 1 Expert
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
