Question about IBM DS3400 (172641X)
Incompatible drive due to invalid configuration on drive
Hp dc5800 microcode update
This is due to the wrong incompatible CPU in the board.
There s a possible fix by HP listed here, where you can apply some code via a USB stick, if you want to try it.
how to fix 1801 Microcode Update Error in HP Compaq dc7800 Convertible...
Aug 24, 2014 | HP Compaq DC5800 Small Form Factor PC...
Error messages: translators were not loaded due to errors on Dreamweaver8
Dear Sir,
the only solution to this , logon with administration user and reinstall the software in differnt directory , I REPEAT IN DIFFERENT DIRECTORY. select custom settings and change directory
thanks
Gizmo
Dec 19, 2007 | Computers & Internet
Invalid configuration information-please run setup program. Performing automatic IDE configuration...... how to solve this problem.. tq..
Did you install a new hard drive, CD drive or DVD drive?
When a new drive is installed it needs to be configured in the BIOS. If so you need to go into the setup (BIOS) menu and then hold down the and keys and the press the and key to re detect newly installed IDE drives.
IDE (Integrated Drive Electronics) refers to the interface circuit that the motherbrd uses to communicate with your hard drive, CD drive or DVD drive.
Feb 17, 2011 | Dell Optiplex G240 (OPTIG240) PC Desktop
Err:invalid
Your message is not complete, so I will assume you got the most frequent message "ERROR: INVALID DIMENSION."
The solution for this problem is simple. When you use the calculator to create statistical graphs, it is configured to accommodate the specificities of the problem. However that configuration remains set after you terminate the problem. So when you try to use the calculator to do other problems it uses the stored configuration parameters, which may be incompatible with the new problem.
In particular, list of paired-variables must have the same dimensions: There must be the same number of elements in each list.
To make a long story short, you should make it a habit to reset the Ram every time you want to do a new problem. If for reasons of you own you do not want to reset the Ram, you can prevent this type of errors from occurring. This is how you do it.
  1. Press [2nd][Y=] (STATPLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
  3. Press [2nd][0] (CATALOG)
  4. Press [PGRM] (C) to jump to first command that starts with c.
  5. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  6. Calculator displays Done
  7. Start the new problem
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
Jan 26, 2010 | Texas Instruments TI-84 Plus Calculator
ERR: INVALID DIM displayed on graphing calculator
The solution for the problem is simple. When you use the calculator to create statistical graphs, it is configured to accommodate the specificities of the problem. However that configuration remains set after you terminate the problem. So when you try to use the calculator to do other problems it uses the stored configuration parameters, which may be incompatible with the new problem. In particular, list of paired-variables must have the same dimensions: There must be the same number of elements in each list.
Jan 16, 2010 | Texas Instruments TI-83 Plus Calculator
Invalid memory configuration detected. In my powerEDGE 1600SC I want solve now. please help me Email: sujon@applezonebd.com
In many machines the larger memory module needs to go in the first slot.
Make sure that is not your problem. Otherwise you may have an incompatible memory module.
Jan 09, 2010 | Intel AC450NX Server
How to remove "err: invalid dim".
The solution for the problem is simple. When you use the calculator to create graphs, it is configured to accommodate the specificities of the problem. However that configuration remains set after you terminate the problem. So when you try to use the calculator to do other problems it uses the stored configuration parameters, which may be incompatible with the new problem.
To make a long story short, you should make it a habit to reset the Ram everytime you want to do a new problem. If for reasons of you own you do not want to reset the Ram, you can prevent this type of errors from occurring. This is how you do it.
Hope it answers your questions.
Thank You for usibg FixYa.
Nov 24, 2009 | Texas Instruments TI-83 Plus Calculator
Invalid card
This could be two things. The sdmicro min mem card may be incompatible or, the internal sim card in invalid or not activated.
Feb 28, 2009 | Pantech Matrix Cell Phone
Using Dragon Speak, 8: Blocked access due to, "Vocabulary General-Large is incompatible"???
The issue is likely caused by a Windows System Restore. You have a couple options to resolve. If you backed up your user training files, restore them, if not, then Create a new user training profile. CLICK HERE for easy-to-follow directions for creating a new user training profile.
As for installing it to a USB drive, I'm not sure, but the application make numerous writes to the windows registry, so I would not recommend installing to a removable drive.
Apr 25, 2008 | Dell Inspiron 6000 Notebook
IBM DS3400 (172641X) Logo
186 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
