Question about Amana NTW4750YQ HE Top Load Washer
How do I reset the machine
We did a diagnosis on the machine the only problem is the sensing cycle. I read that with the newer washers sometimes something as simple as an unbalanced load can make them act up. That is exactly what happened the washer was fine until my son washed his linens for his bed (a blanket specifically) and then it started to make different sounds and will not move pass the sensing cycle.
  • Amana Master
  • 5,323 Answers
Usually unplugging maching for a few minutes then plug back in if not then try opening and closing the lid slightly 6 times within a 12 second period
Posted on Apr 11, 2015
fanny
  • 146 Answers
SOURCE: Amana Top Load Washer model# LW3502W
Sounds like the water seal is damaged and the leaking water has damaged the top bearing which is just below the water seal. You will need to have the hub & seal kit replaced.
Posted on Oct 31, 2007
jumptrout51
  • 3361 Answers
SOURCE: amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Posted on Mar 12, 2009
localwonder
  • 6784 Answers
SOURCE: TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
Posted on May 23, 2009
  • 330 Answers
SOURCE: The washer fills up but
it is probably just a belt i would get someone to have a look before buying new
Posted on Jan 05, 2011
Biggdex35
  • 333 Answers
SOURCE: My washing machine starts a wash cycle and in 5 minutes it starts beeping and stops washing. Why? I should not have to babysit the machine. Then I have to start over and the same thing happens.
Does it say on the display why it stops? Check and make sure that the start button isn't sticking in when you push it. Clean your filter? Im not sure about these new washers. There is toooo many things that can go wrong with them. I like the plain old top loaders myself. Most of them I have delt with will give an error code or something.
Posted on Dec 11, 2011
Washing machine will not start the cycle
Hello Teresa,
+What type of washing machine are we talking about here?
If its a newer electronic model... try unplugging the power cord for
a few minutes or consult your owners manual for a possible reset
feature.
If it is a older mechanical model then it's likely component failure.
Apr 19, 2017 | Washing Machines
Won't stay on wash cycle I select
I appreciate your post, Sandy!
I understand that your Frigidaire washer, ATF6000ES, will not stay on the wash cycle you select. This could be a faulty control panel, wiring harness, or keypad. Have you reset your washer? You can perform a reset by disconnecting the power from your washer for at least ten minutes. If the reset does not help to correct your issue I would recommend seeking a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Aug 07, 2015 | Frigidaire ATF6000ES Front Load Washer
My electrolux front loading washer won't go past sensing mode. What is wrong? What do I do?
Thank you for your inquiry, Sarah!
I see that your Electrolux washer will not go past sensing mode. This sounds like a possible issue with your sensor or door latch and I would recommend performing a reset on your washer to help clear out any miscommunications. You can reset your washer by disconnecting the power cord for roughly ten minutes.
I would check your door latch and door strike for any physical damage that could halt the progress of your washer. If you continue to have issues with your washer I would suggest having a professional out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Mar 17, 2015 | Electrolux Washing Machines
LE error on washer. What can I do without a tech?
The *dreaded* "LE" error is overwhelmingly caused or triggered by incorrect type detergent **OR** too much *HE* detergent (a special low sudsing detergent).
In all LG washers-when too much detergent has been used-this will cause the "LE" error to be displayed & the wash cycle will be interrupted. Unplugging the washer for more than one minute will cause the MAIN BOARD (computer) to power down and re-boot when the washer has been plugged back in.
On LG washers built *before* 2008-after several "LE" error events-the error *cannot* be reset by unplugging the washer. This indicates that the HALL EFFECT SENSOR has failed and will need to be replaced.
On all LG washers built during and after 2008-a more robust resistor was used in the HALL EFFECT SENSORS-which eliminated damage caused by higher electrical loads placed upon the sensors due to oversudsing. HALL EFFECT SENSORS virtually never fail in 2008 and newer LG washers but the "LE" error will still occur if too much or the wrong type of detergent is used. This will be "resettable" by unplugging/replugging the washer.
The CORRECT amount of HE (High Efficiency) detergent to be used is as follows:
HE : (2) Tablespoons Per Wash Load
HE 2X : (1) Tablespoon
HE 3X : (1) Teaspoon
USE THESE AMOUNTS RELIGIOUSLY-NO EXCEPTIONS-IN ALL FRONT LOAD WASHERS WITH 3.0 cu ft DRUMS AND LARGER
Read more: The Dreaded LE Error Code in LG Washing Machines: Diagnosis / Troubleshooting, Root Causes, and Repair ' Washer Repair ' Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2010/08/03/the-dreaded-le-error-code-in-lg-washing-machines-diagnosis-troubleshooting-root-causes-and-repair/#ixzz2nlabX1Gv
Follow us: fixitnowsamurai on Facebook
Dec 17, 2013 | LG WM2233H Front Load Stacked Washer /...
Wont start. I soaked a shower curtain in bleach, ran the machine to add water and then hit pause to allow the fabric to soak in the bleach before washing. I pushed the pause buttonn to continue thewash...
I would unplug the washer to reset it. if you have already hit the power button to turn the unit off and it failed to respond. Newer washer machines are like computers, and smart phones these days. you have to reboot them because they do sometimes lock up. Pull the cord for about 5 minutes and see if that resolves your issue.
Dec 03, 2013 | Maytag MAH6500 Neptune Front Loading...
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
Whirlpool WTW4950XW Washer won't go past the sensing cycle.
It may be as simple as a defective door switch or even a clogged drain hose (the hose between the tub and drain pump. Here are some videos that may help you more than i can. This guy knows:
http://www.youtube.com/watch?v=Aq7a3j7pFUM&playnext=1&list=PL5258B1D98A50745F
Jan 12, 2013 | Whirlpool WTW4950XW Washer
I just rehooked up my washer and I only have cold water going to it. It will go for a while and then reads F-20. What do I do?
he F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Newer washers sense and control the incoming water temperature. If you select cold wash and cold rinse you may think that it will not ask for hot water so you don't need it hooked up but you can't do that on this washer.
Even on a cold wash the temperature sensor will read the temperature of the incoming water. If your cold water is 60 degrees then the control will sense this and it may cycle the hot water on to bring the temperature up to 70 degrees.
This temperature monitoring is something all the newer washers do. Both water valves must be hooked up to water.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code F20
The F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Jan 11, 2011 | Whirlpool WFW9400S
"Spin" cycle won't operate
you have been reading some of the bad stuff.. there not so bad. you should look at the duet problem/s ( all have there problems . ) now your machine could have a spin enable sw out( cost about 15.00 / and it may be a motor controller . / the 5500 haven't been a big problem but 3000 and the 4000/ were.. so don't panic . I own a neptune myself . and after serviceing for many years this was my choice . mm .
Dec 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Amana NTW4750YQ HE Top Load Washer Logo
195 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
