Windows 8.1 crazy enough has different hardware requirements than Windows 8. This has not been recieved well as it has left many people stranded on window 8 without being able to update to 8.1. here are the following requirements for Win 8 for both 32 & 64bit versions. Just remember if your machine does meet these it may not meet requirements of 8.1 so I would suggest you look up the requirements for 8,1 before you do anything. Processor 1 GHz Memory (RAM) 1GB 2GB Graphics Card DirectX 9 graphics device with WDDM 1.0 or higher driver HDD free space 16GB 20GB
SOURCE: HP Quick Play not working
in the software backups there will be the installations for "HP Quick Play" Re install it from There ... if You dont have the back up ... Download it from here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-45931-1&lc=en&cc=us&dlc=en&product=1817074&os=2093&lang=en
SOURCE: Installation of Windows XP Pro on Hp Pavilion laptop
what is the error message that you're getting.. usually windows vista will not downgrade your operating system to windows xp. You may need to remove vista before you can load xp.
make sure to save a back up of all of your important files before you do that.
SOURCE: how can I install Winxp on HP pavilion DV5 laptop ?
You're Hard Drive may be dead. If XP is starting to install and then it goes to the Blue Screen of Death, that's most likely your problem. There's a slight chance that you're power inverter has a fluctuating power level that is causing a disruption, but that's very unlikely. Have you done any tests with any boot CD's to check the hard drive's function?
SOURCE: Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
ara baba pleas go in bious abd change sata settings it will solve your problem
SOURCE: Not installed os in my loptop
http://www.computerworld.com/s/article/9040318/FAQ_Giving_up_on_Vista_Here_s_how_to_downgrade_to_XP
http://www.computerworld.com/s/article/9108198/Microsoft_offers_free_Vista_to_XP_downgrade_help
Obviously, the most convenient way to downgrade is to do so without reformatting. In order to do that, you need to have a real retail CD of Windows XP. If all you have is a recovery disk that came with your computer, you’re not going to be able to do it this way. You will need to reformat.
To downgrade, use the following as a guide:
fixmbr
cd \
ren windows winvista
exit
