Question about Ovens
Rational cpc service 4 - Ovens
RATIONAL CPC GAS
Hi, does the oven work okay on hot air? Steam function uses the steam burner and hot air burner so there is alot of possible causes.
Mar 21, 2014 | Combi Ovens
LOOKING TO BUY A SECOND HAND RATIONAL OVEN CPC 61, BUT WANT TO KNOW HOW OLD IT IS. ANY IDEAS OF WHERE TO FIND THIS INFORMATION? I HAVE THE SERIAL NUMBER: E61CD0208107
E for electric
61 for model/size
CD ummm, control type?
02/08 I think is feb 08, but I would like someone else to confirm that please?
Also, what is service history, did it have a good water filter? was the tank flushed daily and descaled annually?
Oct 17, 2013 | Ovens
Rational SCC 202 service 34-6
34-6 is a service code associated with both the upper and lower oven fans not operating. Check the fan motors. there is a green LED. they should be on steady. If they are blinking, watch and count how many times it blinks before starting over. that is the error code associated with the fan motor. If there is no LED lit, then the fan power supply has failed. The fan failure is a hexadecimal code. "2" is the master fan failure, "4" is the slave fan. "6" is both fans. data to and from the fans is via the I/O PCB. There is a data cable from the operator pcb to the I/O PCB, then on to the fans. The problem can lie anywhere. Fans, PCB's, or data connections.
Jul 09, 2013 | Ovens
Scc-101 rational fault codes
Rational SCC error code service 100
Aug 27, 2012 | Ovens
My rational selfcooking center says service34-2- no function please help
You really need a specialist repairer to resolve this but this generally relates to a main fan motor defect or a failure elsewhere in the bus circuit.
Sep 03, 2011 | Ovens
Rational combi oven service manual
Alarm beeping control board not working
Apr 28, 2010 | Ovens
Rational combitherm electric service codes
service 3, you have a cpc type oven yeah? if so then service means your meat probe needs replacing
Mar 13, 2009 | Ovens
Error " service 34 -6-
check polarity means you have the live and neutral to the oven swapped over, you need to change the live and neutral. service 34-6 means there is a communication problem with both the fan motors but this will probably be cured when you swap the live and neutral
Mar 01, 2009 | Bakers Pride CO11-G2 Gas Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
