Question about MGE UPS Galaxy 3000 UPS System
NO VOLTAGE ON YELLOW PHASE
While attending to this unit I discovered that load supported through yellow phase had no power on static bypass and after resetting the unit it kept switching off after 10 minutes. What could be the problem?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
What caused the UPS to transfer to Bypass? could be inverter fault, would you please check your battery set, maybe the input power is outside the tolerance and causing UPS to discharge the battery set , as well when battery set reaches the end of discharge it is causing the UPS to transfer to bypass and there is something missing on the input yellow Phase.
if the above is not true check the load type that is connected to the UPS output that is causing UPS to switch off in 10 minutes time.
Posted on May 12, 2014
  • 21 Answers
What`s the nominal voltage of this unit?? 208v?
what voltage are you having at the input of the ups?
are there any alarms shown at the screen?
what LED`s are lit?
Posted on May 08, 2014
3 Suggested Answers
  • 3 Answers
SOURCE: case 1: 220 V, 50Hz applied
Did you measure with a true RMS meter?
If yes,the results are normal,but your ground connection is not very good.
The case has 110v potential (exactly half of the input&output 220v) because of the input and output capacitor filters (a capacitor is conectet from phase to casis and an other from neutral to chasis,thus resulting a 1/2 voltage divider). Because of this,the earthing is necessary.
Posted on Jan 16, 2011
epettingill
  • 175 Answers
SOURCE: when switched the bypass to
You didnt start the UPS correctly because the static switch was not on. The Static Switch has to be on to get a clean transfer of power. Check your static switch
Posted on Oct 27, 2011
Trying to wire a single phase 1HP motor to a standard hot, neutral, ground plug. J10 Black ----] 2 White----] low volt line T4 Yellow---] P2 Brown----] T3 Orange---] T5 Red--------] P1 P
didnt specify to much --generic answer -- sounds like hooking up a heating or cooling unit black and white should be your line voltage use a meter to test your black and white line for 110v if motor is 110v the low voltage lines are control or switch lines that dont go to motor they usually go to a thermostat or transformer
May 04, 2017 | Cars & Trucks
How do we measure the voltage at each phase in a three phase wiring system using a multimeter or voltmeter?
If you Google your question you will discover a great deal of information including the theory and practice of 3-phase star and delta power generation with and without neutral and some youtube videos about measuring the voltage.and some valuable safety information.
Safety is paramount due to the high voltage available between phases.
Briefly, the voltage is measured with reference to neutral or ground on all three phases and averaged to discover the supply voltage.
Next the voltage between phases L1, L2 and L3 are checked and these should be identical or within a few percent of being identical.
Apr 22, 2016 | Cars & Trucks
Need wire color diagram
Black = AC hot
Red = switched AC hot
Yellow = AC hot from a another source - another control panel as an example.
White = neutral
red w/white tracer = switched neutral
Green or green w/ yellow tracer = ground/earth ground
blue = DC voltage, ie, 12vdc, 24vdc
white w/blue tracer = dc common
Brown = AC 3 pahse - phase A
Orange = AC 3 pahse - phase B
Yellow = AC 3 Phase - phase C
shileds: think of current loops
2 cond
clear or red = +
black = -(neg)
3 cond
red = power (24vdc typically for transducers)
clear = + (signal output)
black = - (signal common)
Hope this helps, oh, and any panel I have design and wired this way is easily understaood by 99% of all service and electrical people I have worked with.
Apr 15, 2015 | Cars & Trucks
why don't you check the output fuses of the UPS if are ok than fix or replace the power module.
Apr 17, 2014 | MGE UPS Galaxy 3000 UPS System
Model 9155 display says: "UPS
bypass is not available because your input is going in one phase rotation and the bypass is going another. Both input and bypass needs to be a clockwise rotation. A cheap phase rotation meter will fix this. Call me at Gruber Power Services for free tech. support 800-658-5883 x256 ask for Eric
Aug 23, 2011 | Eaton Powerware 9155 UPS UPS System
How to reverse rotation on type k4120 3 phase motor?
hello
make note of positions of wires and colors before moving and wires so can be put back if need to
in general 3 phase motors can be reversed by reversing only one of the phases that come in
as far as i know forward rotation sequence would be red, yellow, blue , (these are the 3 phase wires and could also have a black wire nuetral if the motor is a unbalanced load motor
but think that phase color blue is now white according to electricity regs for 3 phase motors
if the motor is a balanced load motor it may not have a black wire
(the function of the nuetral conductor is to to carry the out of balance current if the loads on each of the 3 phases is diffenent ) and of course has a earth wire as well ( which is yellow/ green )
you should reverse either red and yellow position only or yellow and white position only
but if in doubt check with your local electrcian to confirm
always check electrcity regs before altering
cheers
May 29, 2011 | Garden
HELLO , i have a Powcon 300 SM i have understood how to change from 460 volt to 230 volt three phase but i can not figure out how to change the whole machine over to single phase 240 ...
Look for a "Phase Converter" at Harbor Freight or look in You Tube for info on building one. If you have a lot of welding to do, I would get a better quality converter than they have at HF.
Nov 29, 2017 | Computers & Internet
A new Generac Centurion 36kW unit is producing 350 volts across phase A & B and 175 volts from each phase to nuetral/ground. I need 120/240 volts.
Hello, seeing how this is a new generator, I would have the company either replace the unit or have a certified tech (factory) set the voltage. My first check would be that the voltage regulator is not functioning, or is set incorrectly. I have worked on generac for 30 years. My suggestions are because of warranty issues. You might void your warranty if you try to set the voltage. Just curious, when you discovered this, was there a load connected? Also, I would make sure by checking line voltage with my multimeter to verify it is functioning properly. Sometimes a Digital Meter can give false readings. Do not put a load on the generator, I would connect a 100w light bulb to a phase - neutral connection as not to damage household equipment. Please feel free to contact again if there are more questions.
joe
Jan 14, 2011 | Electrical Supplies
How can i get single phase power from my 3 phase generator
I have not wire this myself
Wiki says under heading of single-phase:
http://en.wikipedia.org/wiki/Three-phase_electric_power
Single-phase loads may be connected to a three-phase system in two ways. A load may be connected across two of the three phase conductors or a load can be connected from a live phase conductor to the system neutral. Single-phase loads should be distributed evenly between the phases of the three-phase system for efficient use of the supply transformer and supply conductors. Where the line-to-neutral voltage is a standard utilization voltage (for example in a 230 V/400 V system), individual single-phase utility customers or loads may each be connected to a different phase of the supply. Where the line-to-neutral voltage is not a common utilization voltage, for example in a 347/600 V system, single-phase loads must be supplied by individual step-down transformers.
So it sounds like you take 2 legs of the 3-phase.
or
Take one leg of the 3-phase and connect to neutral ... neutral could be a ground rod.
I would put a meter on that circuit before hooking up my power saw.
Nov 17, 2010 | Electrical Supplies
Blue and yellow convergence? problem...power light blinks 6 times
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 28, 2010 | Sony KP-51WS510 51" Rear Projection...
MGE UPS Galaxy 3000 UPS System Logo
110 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
