Question about Sony KDS-55A2020 55" Television
LG model MW60SZ12 Lamp replacement procedure
How do I replace lamp
SOURCE: Lamp Replacement on Sony Wega TV
Please explain the location of the lamp for a sony kf-50we610 50 inch tv. Note same problem as above.
Posted on Sep 13, 2008
mighty thor
  • 51 Answers
SOURCE: replacing the projection lamp
heres a link to the manual
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDF55WF655&LOC=3
I did not see s specific procedure for the lamp reset. General reset would be to hold reset amd press power while on. You might try that.
Posted on Dec 05, 2008
  • 4234 Answers
SOURCE: Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Posted on Mar 09, 2009
mastertech49
  • 8 Answers
SOURCE: Sony KF-50XBR-800Replacement Lamp blew after 1 minute
Although this is rare, the problem is the lamp driver board, commonly called the ballast board. Follow the leads back from the lamp an you will find a smallish rectangular board with one large connector and one small one (besides the two wires going to the lamp). If you feel confident, they can be ordered from a Sony parts distributor such as Vance Baldwin or Union Electronics Distributor for about $115 - $150
www.ued.net
Just search under the parts for "Sony" "ballast" and the model number of your TV. Or just call them at their 1-800 number.
If you dont feel confident, you can have a shop repair it for about $450
Posted on Mar 20, 2009
shajanrs
  • 890 Answers
SOURCE: How much is it to replace the lamp and how do I do
I'm sorry that the LAMP light flashing. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the TV flashes, it indicates that the lamp of the TV needs to be replaced. Based on the information you have provided, it is the time to replace the lamp with a new one. XL2100 is the replacement lamp for the TV.
The Original Replacement LAMP costs $199 from Sony. Please click hear to order it online.
Please refer page # 16 of the Instruction Manual of the TV to get the instructions to replace the lamp.
Click hear to download the Operating Instructions if you don't have one handy.
I hope the information helpful. Thanks for understanding. Please let me know if you require any additional help/clarifications.
Posted on Aug 01, 2011
How to reset the lamp meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
Hello, i would like to know if resetting the lamp timer on an LG MW60sz12 will allow you to get more time out of it?? also if it is possible, how do you reset it???
Quick answer = NO.
As projection TV lamps generally have a life somewhere between 3,000 - 6,000hrs (depending on lamp quality/type), the lamp timer is simply there to assist you in determining when the current lamp is due for replacement.
Resetting the lamp timer has no effect what so ever, on the longevity of the lamp.
The Lamp Timer Reset function is hidden within the Service menu and as such, technicians are usually the only ones who are authorised to reset the timer.
However, the following procedure has been known to reset LG lamp timers:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
5. While holding that button, press and hold the MUTE button on the remote.
6. Press and hold the ENTER (or OK) button on the TV front panel.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm
"If this has resloved your problem, please be kind enough to rate this solution and/or leave a testimonial"
Sep 19, 2011 | Televison & Video
Hi have an error call service 6000:0085594 My printer is Kyocera Fs-2000D If you can help me pls
Code: 6000
Contents: Broken fuser heater lamp wire
30 ppm model:
The temperature does not rise 1×C after
the fuser heater lamp has been turned
on continuously 5 s.
35/45 ppm models:
The temperature does not rise 1°C after
on continuously 10 s during waming-up
or at standby.
Causes:
- Poor contact in the fuser thermistor M connector terminals.
Check procedures/corrective measures:
- Reinsert the connector
Causes:
- Fuser thermistor M installed incorrectly.
- Check and reinstall if necessary
Causes:
- Thermal cutout triggered.
- Check for continuity. If none, replace the thermal cutout
Causes:
- Fuser heater lamp installed incorrectly
Causes:
- Broken fuser heater lamp wire.
Check procedures/corrective measures::
- Check for continuity. If none, replace the fuser heater lamp
Jan 31, 2011 | Kyocera FS-2000D Laser Printer
I have a lg 60in tv mw-60sz12 that has blue lines across the screen.i change the lamp and it still has the blue lines.
I have same Lg Mw60sz12 that had blue lines.. I found out it was the box that we plug all the different cables in for surround sound, dvd etc. The connection was loose and caused the blue lines.. as soon as I got a new box the lines went..
Feb 16, 2010 | LG RU-60SZ30 60" Rear Projection...
Replacing the lamp module on a LG Projection TV, model 44SZ61D
Vacuum out any dust that is in the Lamp compartment.Do not touch the lamp with your hands or fingers. Use a cloth or gloves. The oil from your skin will cause the lamp to prematurely burnout.Similar to handing a Halogen Lamp.
Aug 02, 2009 | LG RU-52SZ51D 52" Rear Projection...
Mu bulb has blown on my LG rear projection tV model RT-52SZ60DB
The hours reset procedure is outlined in the owner's manual. Also, the lamp usually includes these instructions as well. If you could post the model number, I should be able to get you that procedure. Also, why are you replacing the lamp? Is there a problem? These should only be replaced when required. They are not cheap. Also, when replacing the lamp, make sure that the access door is seated properly or the set won't turn on. There are safety interlocks that prevent the set from turning on if a door is open.
Dan
May 05, 2009 | Zenith D52WLCD 52" Rear Projection...
Projector
Check that you replaced the lamp in the right way, and also that the unit is well reassembled, you may also need to reset lamp counter from menu on some model.
Mar 07, 2009 | Dell 2300MP Multimedia Projector
HOW TO REPLACE LAMP IN REAR PROJECTION TV AND RESET HRS
hi for the lamp replacement ,you have to undo lamp cover from right hand side and then slide out thelamp case .to reset the lamp time,you have to press 'mute' on your remote and press 'ok' at the same time on front panel.
Aug 08, 2008 | LG RU52SZ30 52" Television
Sony KDS-55A2020 55" Television Logo
19 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
