Lamp replacement procedure for LG MW60SZ12
I have a replacement lamp and require procedure for replacing.
3 Suggested Answers
  • 308 Answers
SOURCE: Replacing LCD Lamp
The lamp may not be the defective part as the ballast board has been known to cause problems with this model - Part#6913v00002c You didn't mention how long you have used the set, and I believe the lamp should last at least 4000 hours. The lamp is usually replaced by opening a door by taking out one or two screws in the back or side of the set.
Posted on Dec 29, 2006
Wolfman304
  • 720 Answers
SOURCE: hello, i would like to
Quick answer = NO.
As projection TV lamps generally have a life somewhere between 3,000 - 6,000hrs (depending on lamp quality/type), the lamp timer is simply there to assist you in determining when the current lamp is due for replacement.
Resetting the lamp timer has no effect what so ever, on the longevity of the lamp.
The Lamp Timer Reset function is hidden within the Service menu and as such, technicians are usually the only ones who are authorised to reset the timer.
However, the following procedure has been known to reset LG lamp timers:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
5. While holding that button, press and hold the MUTE button on the remote.
6. Press and hold the ENTER (or OK) button on the TV front panel.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm
"If this has resloved your problem, please be kind enough to rate this solution and/or leave a testimonial"
Posted on Sep 19, 2011
Hello, i would like to know if resetting the lamp timer on an LG MW60sz12 will allow you to get more time out of it?? also if it is possible, how do you reset it???
Quick answer = NO.
Sep 19, 2011 | Televison & Video
Replacing the lamp in Sony projection t.v. KDF-37H1000
Lamp replacement procedure is written in user manual with exploded views, please check page-39
Click Sony Support link to download user manual copy, if required.
Required lamp in tv part number is as follows:
F93089000 ... LAMP BLOCK ASSY XL-2500
Available in Sony Accessories Store for $199
Thanks.
Nov 09, 2010 | Sony Televison & Video
Replacing lamp
Lamp replacement procedure is written in user manual,check page-17
Click Sony Support to download free copy of user manual of KDF-60WF655 if required.
There are two thumb screws at lower corners if you see tv from rear, remove these screws and take out lower front panel, in center of that space, you will see lamp cover, remove it and unscrew old lamp, pull it out and put new lamp then put things back in reveres order.
Required lamp of KDF-60WF655 is available in Sony Accessories Store for $200 under part number XL-2200
Hope these info will help you.
Thanks.
May 13, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a lg 60in tv mw-60sz12 that has blue lines across the screen.i change the lamp and it still has the blue lines.
I have same Lg Mw60sz12 that had blue lines.. I found out it was the box that we plug all the different cables in for surround sound, dvd etc. The connection was loose and caused the blue lines.. as soon as I got a new box the lines went..
Feb 16, 2010 | LG RU-60SZ30 60" Rear Projection...
GOES OFF AND ON
Did you replaced lamp recently in tv?
Symptom shows lamp is getting weak in result and tv requires replacement.
Lamp replacement procedure is easy and would be written in user manual.
Thanks.
Jan 20, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Lamp light is on. TV wont turn on?
Lamp light is On that means lamp is dead and requires replacement.
How old is this TV and did you replaced lap recently?
Lamp replacement procedure would be written in user manual.
Thanks.
Nov 26, 2009 | Samsung HLP6163W 61" Rear Projection...
Mu bulb has blown on my LG rear projection tV model RT-52SZ60DB
The hours reset procedure is outlined in the owner's manual. Also, the lamp usually includes these instructions as well. If you could post the model number, I should be able to get you that procedure. Also, why are you replacing the lamp? Is there a problem? These should only be replaced when required. They are not cheap. Also, when replacing the lamp, make sure that the access door is seated properly or the set won't turn on. There are safety interlocks that prevent the set from turning on if a door is open.
Dan
May 05, 2009 | Zenith D52WLCD 52" Rear Projection...
Blue screen
it is the optical engine i have just replaced mine for $800au, its a common problem for this model the polarised filters wear out but good luck finding the filters and fitting them it took me 6mnths to find them and i gave up
Apr 20, 2009 | LG RU-52SZ51D 52" Rear Projection...
Hitachi 50V500A Lamp
Lamp replacement procedure is written on page 69 to 72 in user manual of Hitachi 50V500A TV.
Lamp cover is at front of TV, requires to unscrew it then lamp needs to unscrew and pull out lamp.
If you need user manual copy, please download it from Here.
Oct 03, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
