Question about Vehicle Parts & Accessories
Battery going dead while sitting on 96 dodge ram 1500
  • 53 Answers
Can you supply more info?
What more do you know?
If you disconnect the battery does it still go flat over night?
Posted on Apr 17, 2014
I have a 2000 dodge ram 1500, everyday i go out in the morning the battery is dead. bought new battery and put in a new alternator, truck still is dead each morning. anyone have a clue what would be...
Check your convience and vanity type lighting to be sure they are shutting off( underhoodlight, glove box, back sun visor mirror lights, etc...). Next you can use a clamp on amp draw gun and follow the draw thru the harness to the problem. This tool is available at most auto parts stores. Also, just because a battery is new doesn"t mean it Good!
Jan 27, 2013 | 2000 Dodge Ram 1500 Truck
Free dodge ram 1500 trouble shooting
I had the same problem...I changed the battery ..took it to a mechanic...started fine all day for him ...He still said he changed 2 relay switches and charged me 300...He just said they were in the engine ..I think it had alot to do with the battery...
May 30, 2012 | 2001 Dodge Ram 1500 Truck 2WD
96 Ram 1500, 5.9 litre. code PO138 sensor circuit
it will be the o2 sensor after the cat.. check the connections. the first bank should be the right side of the engine while sitting in the car. look at that side of the exhaust.
Jul 20, 2010 | 1996 Dodge Ram 1500 Club Cab
Firing order diagram for 96 dodge ramp 1500 van v6 3.8 engine
Note this information, about Dodge RAM 1500 have 3.9 engine... 1996 Dodge 1500 Pickup 3.9 liter V-6 VIN "X"
This is for one 3.8L V6 1996 Dodge 3.8 liter V-6 VIN "L"
Hope helps (remember rated this).
Jul 04, 2010 | 1996 Dodge Ram 1500 Club Cab
Where is the sensor for the temperature guage on 1999 Dodge Ram 5.2?
i gota 96 dodge ram 1500 5.9L and it shold b behind the altiantor it sits kinda down in ther in the block and its on the left of the top radiator hose idk if these years are the same way but i figured id try help u out a little bit
Dec 20, 2009 | Dodge Ram 1500 Cars & Trucks
Random dead battery with 2003 Dodge Ram 1500 4.7 ltr QC
The starter solenoid has a bad contact inside in delivering current to the starter. When it is cold the battery weaker than normal so it can not provide enough current to the starter since there is big resistance path from the bad solenoid preventing enough current to turn the starter to crank up the engine. Replacing the starter solenoid will take care of this problem.
Oct 27, 2009 | 2003 Dodge Ram Maxi
2003 dodge ram 1500 abs & brake light came on. also cruise does not work. any suggestions
Problem: I have a 2004 Dodge Ram 1500 5.7 L HEMI. My ABS and Parking Brake lights were illuminated, and my speedometer needle would "bounce". Also when sitting at a stop sign or just sitting idle, the engine would stall, and often times stop running.
Solution: After long research on this problem, I decided to dig in and try to find the problem myself. I replaced the Rear ABS Sensor
($35) that's located on top of the rear differential. Still no fix. I then unplugged the ABS Controller (or Module) that's located directly behind the battery (You should see the metal brake lines running into the top of it.) When I unplugged it, I noticed LOTS of moisture in the plug. Using an air hose, I blew out the water and let it dry good. When I plugged it back in, and hooked the negative battery terminal back up THE PROBLEM WAS SOLVED!! Simple fix. Hope this helps.
Sep 30, 2009 | Dodge Pickup Cars & Trucks
Will a 5.9 from a 99 durango fit a 96 Dodge Ram 1500?
Sure,just make sure you get the wire harness & a diagram. Go to town!!
Jun 22, 2009 | 1996 Dodge Ram 1500 Club Cab
96 Dodge Ram 1500 wiring diagram for headlights.
Here's a link to a pdf file containing the headlight wiring diagram for your year model Dodge Ram 1500..
I can't help but notice that you say you've replaced the headlight relay? That's quite odd, because there is NO headlight relay on this vehicle- only a 40 amp fuse located in the power distribution box that sits behind the battery inside the engine bay.
The switch is notorious for burning out because there is NO RELAY on this vehicle, and there is a recall (#819) but this only affects 3500 models even though the headlight wiring is the same for 1500,2500 and 3500 model Rams.
Here are two more links that will help you troubleshoot your headlights problems.
HereInformation on Putting a Relay in the Wiring System
Mar 07, 2009 | 1996 Dodge Ram 1500 Club Cab
Vehicle Parts & Accessories Logo
29 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
