Yea, this happened to me as well. It keeps pressing a series of 0'1 and 1's and then it dials the number. I just received this phone and it hasn't been damaged by any sort of circumstances.
Well if anybody else has this problem, I've managed a solution but haven't confirmed if it fixes it permanently. It turns out the main cause for this is due to water damage but it can be from either direct contact or sweaty fingers of some sort. The solution is to take the battery out and leave the RAZR opened up to dry out for 12-24 hours. That way the keypads can return to normal under little contact/use the next day. The water damage may be slight so I recommend staying out of contact with the RAZR for a long period of time afterwards (presumably a day).
Autodial? You're going to use one of the 8 buttons for autodial or are you trying to put system speed dialing in? The phone buttons are easy if you dial "9" to get an outside line. You press PROGRAM a button, and dial 29 plus your number and STORE.
Now, obscurely, you can program one of the 8 buttons to SAVE a number. Thats done by PROGRAM the button 5 STORE. When you dial a number that you want to save, you press Autodial and SAVE (the button you programmed) and it will save that number under the button.
Now, grab a line and press the SAVE button and it will dial your saved number.
Last, if you're not totally bored, you can store 10 Personal speed dial numbers on your phone. They program by 2* (0-9) number # and are dialed by pressing # (0-9).
Yeah. BTW this is an instruction set for a TA-624, common for the type of phone you have. I think it applies to most of the TA series KSU's.
Press the STORE button, "Location?" appears in the dispaly screen, dial one of the digits 0 through 9 on the dialpad or press one of the 3 memory buttons:A, B, or C. Press the STORE button, enter the phone number using the dialpad, press the STORE button.
There are two ways to use the stored numbers. With the phone idle, press the DIAL button, press the memory button(A, B, or C) or one of the dialpad numbers 0 through 9, then lift the handset or press the speaker button and the stored number will be dialed. The other way is to first lift the handset or press the speaker button, press the DIAL button then choose the memory location by pressing one of the A, B, or C memory buttons or dial one of the digits 0 through 9 on the dial pad and the stored number will be dialed . I have included a link where you can download the manual.
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
* by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone. Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone. Step 3 Listen for three beeps followed by a continuous tone. Step 4 Dial the telephone number to which the calls are to be diverted. Step 5 Listen for two short beeps, confirming the diversion. Step 6 Replace the receiver
Turning Call Divert Off
* By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone Step3 Listen for two short beeps to confirm removal of the diversion Step4 Replace the receiver.
Other Call Divert Options - Selective Calls With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
* Turning On or Off Selective Call Options
Step1 Lift the receiver and listen for the dial tone Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial *63 for Selective Call Divert Dial *68 for Selective Call Accept Dial *60 for Selective Call Reject Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again. Step 4 The feature is now on/off. Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Which system do you have? Below are the Panasonic systems. Be sure you find yours.......
Panasonic
XDP 824/1232 All programming is done at ext. 101
1) Press the program button, followed by *#1234
2) Dial 000, then follow the prompts on the LCD
KX-T308, KX-T616
Use phone with intercom number 11. It will change the
time for all phones.
Keep handset down and press INTERCOM button.
Dial 77.
Dial the hour, with two digits (e.g. 03 for 3 o'clock).
Dial the minutes, with two digits (e.g. 07 if it is now
7 minutes after the hour).
Dial 0 for AM or 1 for PM.
Press #.
Press SP-PHONE
Panasonic
KXT Series Telephone System
Setting
the time must be completed from an LCD Display phone at Extension 11, using the
telephone keypad. This system type requires "Easa-phone" series
or a 7000 series model telephone (the model number is listed on the bottom of
the phone) that has one or more small switches located at the rear of the phone.
Digital "XDP" phones can not be used on this
system type!
To
set the time:
Lift
the handset or press "SP-Phone" button on Extension 11.
Dial
"77"
Enter
the hour with 2 digits. (01 through 12)
Enter
the minute with 2 digits. (00 through 59)
Dial
(0) for AM or (1) for PM.
Press
the "#"
Wait
for confirmation tone. (Instantly after pressing the # button, new time
counting will start).
KX-TA624
Use phone with intercom number 101. It will change the
Move MEMORY switch on rear from SET to PROGRAM.
Dial *#1234
Dial 000
Press NEXT ("Sp-phone")
Press Right Arrow ("FWD/DND") four times
until you see the time displayed
Change the hour with the keypad
Press Right Arrow ("FWD/DND") to reach the
minutes field
Change minutes with the keypad, if necessary
Press AUTO DIAL/STORE
Press HOLD
Move MEMORY switch on rear from PROGRAM to SET.
KX-TAW848
Press PROGRAM (or PAUSE, if you don't have a PROGRAM
button.)
Dial programming access code (probably *#1234)
Press NEXT (SP-PHONE, if you are not using the
programming template).
You'll see "Date & Time Set" on your
phone's display
Press STORE
Press NEXT to see hours and minutes.
Use your keypad to change the hour
Press STORE.
Press HOLD.
Press PROGRAM
KX-T123211D
Use phone with intercom number 101 (probably the
receptionist's phone). It will change the time for all phones.
Move MEMORY switch on back of that phone to PROGRAM.
Keep handset down and press 0 on touch-tone dial.
Dial year with two digits (e.g. 97 for 1997).
Dial month with two digits (e.g. 01 for January).
Dial date with two digits (e.g. 03 if today is the
third day of the month).
Dial day with one digit (1 for Monday, 2 for Tuesday, 3
for Wednesday, 4 for Thursday, 5 for Friday, 6 for Saturday, 0 for Sunday).
Dial hour with two digits (i.e. 01 for 1 o'clock).
Dial minutes with two digits (i.e. 07 for 7 minutes).
Dial 0 for AM, or 1 for PM
Press either AUTO DIAL/STORE or AUTO/MEMORY, depending
on your phone.
Move MEMORY switch on back of phone to SET.
Panasonic DBS 824, 40, 72 & 96 - From the Attendant's display
phone.
Press "On/Off"
Press "Prog"
Press " ##"
Press "FF1 key"
Dial 1#, 2#
Dial the time in 24 hr format.
Press #
Press "On/Off"
- From any display phone in the
system.
Press "On/Off"
#98 + Password
Press "Prog"
Press " ##"
Press "FF1 key"
Dial 1#, 2#
Press #
Press "On/Off"
Panasonic DBS 576 & 576 HD From any display phone in the
system;
Which system. See below. BUT make sure you find your system first....
Panasonic
KX-T308, KX-T616
Dial 77.
Press #.
Press SP-PHONE
Panasonic
Setting
system type!
To
set the time:
Lift
Dial
"77"
Enter
Enter
Dial
Press
the "#"
Wait
KX-TA624
Dial *#1234
Dial 000
minutes field
Press HOLD
KX-TAW848
button.)
phone's display
Press STORE
Press STORE.
Press HOLD.
Press PROGRAM
KX-T123211D
on your phone.
phone.
Press "On/Off"
Press "Prog"
Press " ##"
Press "FF1 key"
Dial 1#, 2#
Press #
Press "On/Off"
system.
Press "On/Off"
#98 + Password
Press "Prog"
Press " ##"
Press "FF1 key"
Dial 1#, 2#
Press #
Press "On/Off"
system;
1. lift the handset and listen for the dial tone.
2. press the store button
3. dial the number that you wish to store
4. press the store button a second time
5. press one of the numbers on the phone [0-9] and that will become the speed dial number.
6. make a record of the speed dial number and the name of the person it will call.
Then when you want the person on speed dial number 5, just pick up the receiver, get a dial tone and push 5. Thats it!
ps - kindly rate my answer as helpful. thanks
I can think of only two reasons it doesn't work. What "Code" are you dialing? If you can't dial 600-699, then you are not at extension 10 or 11. If you're trying 80-99 you don't press FEATURE again.
To add an ExtensionKey: - DONT lift handpiece, enter [*91] then press a vacant memory key and then choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
To dial an ExtensionKey: -
Lift handpiece.
Press the memory key you programmed.
Storing a personal speed dial number: - Lift handpiece. Dial [*92] Dial memory number. (*0 - *9 for personal numbers) Press the [ü] key. Dial 0 then the number to be stored. Press the [ü] key. Hang up.
How to dial speed dial numbers: -
Lift handpiece.
Dial [*7]
Dial memory number.
(001-999 for system numbers) For Example: [*7*0 ü] will call the personal number stored under position *0. [*7001 ü] will call the system speed dial number stored under position 001.
ok, the link isn't working properly, so I'll try to explain:
step 1 press "program" button, then **1234
step 2 enter 000
press next (or spkr phn button) for date
press next (or spkr phn button) for time
press fwd/dnd button
press fwd/dnd button again
press sel (or auto answer/mute button) to change am/pm
press store (or auto dial/store)
press end (or hold button)
press spkr phn button or pick up hand set and hang up to leave programming mode.
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works) To program: 1. press speaker or lift handset. 2. press STORE 3. dial the number to be stored 4. press MEMORY DIAL 5. press location (0-9 on keypad or 1 of the 3 emergency quick dial) 6. press speaker or hangup. To dial emergency numbers: 1. press speaker or lift handset. 2. press any of 3 emergency quick dial To dial stored numbers: 1. press speaker or lift handset. 2. press MEMORY DIAL 3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
