Question about Kenmore 63942 Dryer
Kenmore 70 Series - 2 years old. Won't dry clothes, but there is definitely heat. Had a similar problem a year ago and ended up being a bird nest in the vent piping. I took off the vent piping nearest the opening to the outside, but found nothing. Can anyone help?
  • 1,305 Answers
Check for lint build up in the flex pipe connecting the dryer to the vent pipe..
While it's disconnected clean the duct on the back of the dryer..
A great lint cleaner is a "webster duster" on a pole...you can get alot of lint out with one of these..
k
Posted on Jun 19, 2009
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
My Kenmore 80 Series gets hot, but it takes 2 or 3 cycles to dry clothes. What should I do?
If its getting hot and cycling and your drum is turning than the problem is a clogged or kinked vent hose or maybe a bird nest in the exterior defuser.
Sep 27, 2012 | Dryers
The clothes are taking way to long to dry. The dryer could be on high and has to run 2-3 cycles.
make sure the dryer vent is not plugged, ( you would be amazed at how many bird nests are cleaned out of the vent this time of year ) after checking the vent and making sure you have good air flow threw the dryer, and it still will not dry, then replace the heater assembly.
Apr 12, 2011 | Kenmore Dryers
My Kenmore 600 is not even 2 years old. It spins and appears to have heat but the clothes do not dry. I cleaned a ton of lint from the flex pipe/elbow joint in the rear of the dryer but this has not...
You are on the right track by cleaning the vent elbow.
Also check:
The entire vent line to the outside diverter (the little thing that looks like a hood). Depending on your dwelling, the vent line can also become obstructed with lint and sometimes other things like bird's nests, especially near the discharge outlet. This can happen when the flapper valve at the outlet sticks.
Make sure the lint screen is always kept clean
Another thing to try - empty the dryer and pull it away from the wall until you can get behind it. Disconnect the vent line and turn the dryer on air only. The air velocity coming out of the dryer air exhaust line should feel pretty strong. If it doesn't, the fan could be full of lint as well or there could be an issue with the exhaust fan itself. If the fan is plugged or bad, the back of the dryer will have to be removed and the fan checked.
The dryer should not be overloaded and be sure the clothes being dried aren't too wet (possibly indicating a washer spin cycle issue).
Jan 01, 2010 | Kenmore 62602 Electric Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
Jul 06, 2009 | Washing Machines
Takes too long to dry
Check the following ares carefully to combat this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 18, 2009 | Kenmore 63942 Dryer
Kenmore dryer only heats on delicate
how to install rubber belt on kenmore gas dryer number 110.72712101 ?
Jun 14, 2008 | Kenmore Dryers
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Kenmore 70 series? Not heating to dry clothes.
i am a retired appliance engineer of 20 years, and in basic language, no heat = check heater element for open circuit (has it blown) also there are thermal cut outs like you say, sometimes about 3 located (2 near the element) and another elsewhere normally near the air outlet, these can be triggered so the element doesn't work, if any one of these are triggered this could be caused by overheating / overloading / or just a vent or air flow blockage, all are easy to rectify with basic common sense and a multimeter work safe and unplug before checking if i have helped please rate me, best of luck
Sep 18, 2007 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
144 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
