Question about Miele W2240 Front Load Washer
Waterproof system activated. close stopcock. The water system protection has reacted how can this be fixed?
Waterproof system activated. Close stopcock. The water system protection has reacted due to water coming out the detergent dispenser how can I fix this problem?
2 Suggested Answers
tunde007
  • 2382 Answers
SOURCE: waterproof system activated. close stopcock. The
Hi, it's caused by a leak of water into the tray at the bottom, which activates a sensor to shut the water in flow off and thus prevent a flood. The fix is as for a posting by halldor to a question about the w4146 - ie. Turn off and unplug, drain by the filter plug, lean the machine forward - the water flows out the bottom, plug in and it should work. You do need to establish the cause of the leak first. Mine was a draw cord on some trousers dangling out of the door, thus preventing a proper seal, the water dribbled down the front and into the tray. Miele stated it could only be fixed by their service mechanics
Posted on Mar 05, 2011
My miele front loader beeping and display saying activated close stopcock.
Defective door lock switch Manual release in side back of door lock
may have pull wire near drain clean out.
Jul 05, 2016 | Miele Washing Machines
What is that mean "waterproof system activated Close the stopcock 'Where is stopcock located?
as there is no make listed we really have no idea what to look for
Nov 24, 2015 | Washing Machines
Display shows 'fault waterproof'. what is wrong?
I have been trouble shooting my own Miele issue and may have found your answer, which seems to be easily fixed. Apparently one can reset the water fault sensor by tipping the machine forward at 45 degrees. If water comes out the bottom pan, then you will have reset the sensor. You should check for leaks especially in the door gasket. However if it comes on again, you probably have a leak that you need to address.
Aug 31, 2015 | Miele W5877 Edition 111 Washing Machine,...
How do I fix problem F3 and spray arm faulty on my KO FAVORIT 8080
F3 - The anti-flood protection system has activated.
When in operation the fault message F3 appears in multi dispay:
  • First close the water tap.
  • Pull out the power plug.
  • In the case of hard-wiring: turn off the electricity supply, remove the fuse and disconnect.
  • Check float microswitch and float of styrofoam.
  • Find and remedy water lakeage in the bottom of dishwasher.
Dado
Jan 22, 2015 | AEG Dishwashers
Dado
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
The waterproof door Fuju fine-pix Z33 WP has broken
This might be of big help logged on to this link : http://www.fujifilmusa.com/support/ServiceSupportContact.do
they do have the repair options and where you can sent that item for repair.
ERNZ
Feb 11, 2010 | Fujitsu Cameras
Water protection system activate - how can i deactivate?
how do you fix machine when waterproof fault comes up even after draining machine?
thanks Linda
Aug 23, 2009 | Miele W4840 Front Load Washer
Wps code
Simply disconnect it. Water completes the circuit - so you want to make sure it is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 26, 2009 | Washing Machines
MIele waterproof system reacted
That means that there is a leak that passed throught the waterproof system, and the water protection system had reacted putting the machine on error mode, as the water can damage electric parts, and cause serious hazard.
Sometimes you can reset the error by unplugging power cord, however you should call immediately a technician, as using the appliance when there is a problem with the waterproof system, you can be seriously injured by electric shock.
Operating instructions for Washing machine W 3923 WPS
Nov 16, 2008 | Washing Machines
Miele W2240 Front Load Washer Logo
83 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
