Question about Sony KP-57WS500 57" Rear Projection Television
Two Red Lights Sony KP-57WS500
My Sony KP-57WS500 has two red lights on- Timer/Standby and Stereo on. Tried turning it off for 5 minutes, didn't do anything. The TV obviously has power, but will not turn on. What should I do?
SOURCE:
welcomejee
  • 10594 Answers
SOURCE: KP-51WS520 wont turn on - standby & timer lights on constantlly
You need to check supply volts on main micro IC702 on main board of Sony KP-51WS520 TV.
If you have experience of big TV repair then I would recommend to get service manual of TV from any online store and check above said IC supply volts. TV must give error by blinking light in case any problem in drive circuits and if main micro fried, no error signal will be there.
Posted on Dec 05, 2008
SOURCE: I have a Sony KP-61HS10 that will not turn on.....
hello read my comment on shadie333 i just posted the problem i had, my tv is a kdp65ws550 which is also the same as the kdp57ws550 and kdp51ws550 mine was doing the same thing... ours is fixed... please read it
Posted on Dec 17, 2008
welcomejee
  • 10594 Answers
SOURCE: KP-57WS500 turning green or red and then off
Green and Red guns seems defective and requires replacement.
Both guns (CRTs) are no longer available so TV has no worth to repair.
Posted on Apr 19, 2009
SOURCE: The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
you must change ic reg.(ic mcz 3001db)
Posted on May 06, 2009
  • 51 Answers
SOURCE: sony kp-57ws500 flashes blue, green, red then turns off
Re-insering the flyback wire is usually very easy. Push in and give a slght turn and check to see if grabbed. It sounds as if there is more issues than flyback wire. TV should turn on without one crt connected
Posted on Dec 15, 2009
Testimonial: "very quick response "
Sony kp-57ws500 flashes blue, green, red then turns off
Dec 14, 2009 | Sony KP-57WS500 57" Rear Projection...
Apr 19, 2009 | Sony KP-57WS500 57" Rear Projection...
no the 6 blinks indicates a missing voltage. If your talking about a sony lcd KD or KE model you probably have a bad thermal fuse. You must also clean or change the Lamp fan so it won't blow again.
Apr 16, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
My sony KP-57ws500 flashes green then turns off.
YOU HAVE A BAD GREEN CRT. UNIT IS NOT WORTH REPAIRING SINCE YOU WOULD HAVE TO REPLACE ALL 3 CRTS FOR THE UNIT TO SET UP PROPERLY.
Jan 12, 2009 | Sony KP-57WS500 57" Rear Projection...
Tv comes on for a few minutes then goes off
If you take off the front bottom panel of the tv wich is easy. Then you will see 6 tuning knobs at the bottom middle of the tv .the top 6 control contrast for the lights dont mess with those. the bottom 3 are the power to each light.red is bottom left if your screen went blue it makes sense that the red is starting to go but if you turn down the power to it left 1/8 turn it should fix it for awhile .Its easy.
Jan 01, 2009 | Sony KP-57WS500 57" Rear Projection...
Major problem with sony kp-57ws500
BTW if you appreciate the help I have given you, please rate me! Thanks!
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony TV KP-51HW40 solid red lights [timer/standby+stereo]
if the main board by chance got wet you will need to use a blow drier to try and dry it out..it may already be beyond fixing if water goi into it
Aug 17, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-57WS500 TV FADES TO SOLID RED W/ LINES A FEW SECONDS AFTER I TURN IT ON
Red CRT is doing short circuit in the neck. You can try to open the front panel and to hit easy the neck with wood or something and to decrease the red screen a bit. If doesn't work then replace the CRT.
Jan 04, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
35 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
