Question about Duraflame Electric Fireplace Stove DFS-750
Where is the eye for the remote on a duraflame dfs 750
How to remove cover
https://www.meijer.com/assets/product_files/pdf/duraflame_large_electric_stove_red_owners_manual.pdf
Dec 09, 2015 | Duraflame DFS-550-0 Black Metal Electric...
Thermostat does not work. where can I get it fixed. I am elderly and cannot take it anywhere. I live in Arvada Colorado.
The thermostat at my husband's business didn't work last winter and neither did a lot of the electrical outlets. We called in an industrial electrician. Perhaps you can find an electrician online who you could call to help you? I think that would be best. They would do the job for you and you wouldn't have to go anywhere. Industrial Electricians and More in Lethbridge Coaldale
Aug 25, 2015 | Duraflame DFS-550-0 Black Metal Electric...
NO FLAME
There are little light bulbs (like large Christmas lights) that have probably burned out.
remember to replace with only the same wattage and type.
Apr 12, 2014 | Duraflame Electric Fireplace Stove DFS-750
Blown fuses
a popped breaker is a short in circuit, first check cord for damage, second it could be heater shorted to block. best checked with multymeter on ohms scale, circuit through block heater is usually 25 to 45 ohms.
Mar 13, 2014 | Duraflame DFS-550-0 Black Metal Electric...
Fan doesnt come on
Two items, check the thermostat is not set too low.
If it is not, then check the fuses.
Feb 14, 2014 | Duraflame DFS-550-0 Black Metal Electric...
DFS-550-29 REDUCED EFFICIENCY
sounds like the heating element is going bad..its probably intermittant..
Jan 08, 2014 | Duraflame DFS-550-0 Black Metal Electric...
Does this use a lot of electricity? My bill went up after using this for the first month.
It does use a lot of electricity, all stoves do. You can reduce the amount it uses by turning it off.
Dec 20, 2013 | Duraflame Electric Fireplace Stove DFS-750
My Duraflame heater model dfs-550-0 , heats well but my flames no longer work . is there anything I can do to fix this problem? someone please help!
Actually, it could just be a burnt out light bulb. Open the back. The light bulb is easy to get to and easy to replace.
Aug 27, 2013 | Heating & Cooling
Duraflame Electric Fireplace Stove DFS-750 Logo
Top Duraflame Home Experts
Donni Steen
Tom Chichester
Are you a Duraflame Home Expert? Answer questions, earn points and help others
