Question about Sharp AR-M205 Copier
A dark line appear on the paper during the printout arm 205
IR 3035 black copy
<Cause>
On some types of paper (especially those with a high calcium carbonate content), toner offset to the fixing film can
start to cake, moving from the fixing film or the pressure roller to the face or back of paper.
<Field Remedy>
Use the following service mode item to change the timing at which the fixing pressure roller is cleaned:
COPIER>OPTION>BODY>FIX-CLN
0: disable cleaning (default)
1: execute cleaning during last rotation every 500 printouts
2: execute cleaning during last rotation every 200 printouts
3: execute cleaning during last rotation every 100 printouts
Feb 14, 2017 | Canon imageRUNNER 3035 Black and White...
Every 10th line of print is fuzzy. We have tried all the usual fixes, head clean, nozzle check. What next
What should I do if my printout is blurry or smeared? - Epson ...
https://www.epson.com/cgi.../supDetail.jsp?...
EpsonSep 18, 2012 - Epson WorkForce WF-2530 All-in-One Printer ... If your printouts areblurry or smeared, try these solutions: ... If you print on both sides of a sheet of paper, smudges may appear on the reverse side of heavily saturated or dark ...Missing: every ‎10th
What should I do if my printout has lines running ... - Epson
https://www.epson.com/cgi-bin/Store/.../supDetail.jsp?...
EpsonSep 18, 2012 - Epson WorkForce WF-2530 All-in-One Printer ... If you notice white or dark lines in your prints (also called banding), try these solutions before ...Missing: 10th ‎fuzzy
FAQs for this Product - Epson WorkForce WF-2530, Top ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid...
EpsonThis link provides access to Top FAQs for the Epson WorkForce WF-2530. ... [ Answer ]; I see the message Printer is Offline when I try to print with a ... [ Answer ]; What should I do if my printout has lines running through it? .... When printing in Windows, how can I prevent an extra page from being ejected after every print job?
Jan 19, 2016 | Epson WorkForce WF-2530
Printing vertical green lines on photos
The troubleshooting section for banding below was taken from the user manual found at this web link:
https://files.support.epson.com/pdf/wf3520/wf3520ug.pdf
White or Dark Lines in Printout
If you notice white or dark lines in your prints (also called banding), try these solutions before you reprint:
• Run a nozzle check to see if any of the print head nozzles are clogged. Then clean the print head, if necessary.
• Make sure the paper type setting matches the type of paper you loaded.
• Make sure you loaded the printable side of the paper correctly for your product.
• Turn off any high speed settings in your product software.
• Align the print head.
• You may need to replace the ink cartridges.
Hope this helps...
Dec 21, 2014 | Epson WorkForce WF-3520 All-in-One Inkjet...
DARK LINES/SHADES APPEARING ON BACK OF PRINTS
when the print-out shows lines or streaks on the back of the paper when printing single sidedly, this usually means that the fusing unit is dirty or broken. another possible broken part may be the photoconductor unit.
Apr 20, 2010 | Canon iR 2016i Black and White Copier
Dark print out
check the fuser... to see if one of the rollers has toner all over it... then check your paper path... to see if you see any obvious signs... then try printing 20 pages and opening the copier at various times during the printout process... you want to see if you can catch it where the dark starts appearing... chances are where it starts... is right next to the bad part... you are looking for a print out with one half no dark and the other half real dark...
Dec 16, 2009 | Canon NP 6035 Copier
Makes dark line on paper
if you are using your doc feeder check and see if there is anything on the small glass the one that is about an inch wide other then that could b fusing or drum issue
Jun 21, 2009 | Konica Minolta DiALTA Di200 Copier
Striped line down right hand side of printout
all parts are ok just clean the printer it will work
Dec 02, 2008 | Samsung CLP 300 Laser Printer
Poor fax printout quality
I would say you have a bad drum / toner cartridge.
Stuff you receive with vertical lines is probably the sender's dirty scanner.
Nov 04, 2008 | Canon LaserClass 2060P Plain Paper Fax
Sharp AR-M205 Copier Logo
22 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
