Got a samsung wa80v3 washing machine it just stopped draining after checking it out I found the drain pump was burned out I replaced it with a new one my proplem is as the water comes in its drained out again so now I can't use the washer at all there is nothing in the pipe system its clean what's the problem please
    Champion:
    Habit-Forming:
  • 210 Answers
Did you replace the pipe correctly? The thing you should be asking though is why was the first one burnt out? Is there a connection problem? Maybe the replacement pipe has burnt out as well.
Elisa Jed ' http://www.lanzaplumbing.com
Posted on Jul 15, 2014
  • 6 Answers
SOURCE: aeg 72630 update will not rinse during rinse cycle
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
Posted on Jan 14, 2008
Krazytech
  • 725 Answers
SOURCE: I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Posted on Apr 05, 2008
  • 38 Answers
SOURCE: machine can't get rid of the water gives no drain message
The motor is burnt out. When it is cool it will pump water out, but as it heats up and the insulation on the windings break-down is short-circuits and stops.
Posted on Jun 01, 2008
  • 1531 Answers
SOURCE: Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Posted on Jan 31, 2010
  • 35 Answers
SOURCE: washing machine not draining the water
the weater pump is bad replace....
Posted on Apr 13, 2010
My wa80v3 washes then wont drain unless the outlet pipe is left level with the floor and then it drains.we have to pick the pipe up again to refill or spin.please help
check the pump impeller for obstruction stopping it from spinning.
could be a coin, bra wire bobby pin anything
if it is clear , check fro power to the pump on spin cycle
if no power check the program board for progressing the cycle
Dec 07, 2016 | Washing Machines
Got a Samsung Diamond Drum WA80V3 after I put in on quick was and start it goes 22 minutes and when at 15 it goes toe rinse but then the machine just stop doing anything. Water still inside drum. Maks n...
The drain pump is either blocked or failed. Check the filter if it's clear then you are most likely up for a new drain pump. Here is a link to the part you need and a video on how to do it. Samsung DC31 00030E DRAIN PUMP B20 3 120V 60 NEW ORIGINAL
Mar 15, 2015 | Samsung Washing Machines
Why does my Samsung washing machine wa80v3 not wash, spin or drain. ?
There are a few things that could cause this, first of all check the lid switch. That is a safety thing that makes sure the lid is closed before it allows it to start washing or spinning. Some other culprits could be a clogged filter, or a broken belt ( if your model has a belt) does the machine sound like its trying to wash? or does it just turn off and do nothing like its dead? if it seems dead its more than likely the lid switch, they are about $40 and simple to replace.
Jul 15, 2014 | Washing Machines
Samsung wa80v3 does not drain water
check the drain pump isnt blocked. there is a panel at the bottom front of the machine. remove this and unscrew the round cap and look for a jam. turn off machine first! move the propellers with you fingers. if its ok it should turn a quart of a turn then race forward some
May 17, 2014 | Washing Machines
Samsung automatic WA80V3 does not drain water
the pump maybe jammed or the filter could be blocked.
if you need advise on how to check, let me know
Intermittent Draining and Burning Smell
The water will not run in the machine.It will for a few second then stops. What could be the problem?
Aug 15, 2012 | Fisher and Paykel GWL11 Top Load Washer
Water is continuously draining from my samsung washing machine . due to this unable to keep washing the clothes .why the problem come & what is the remedial measure to rectify?
Possible that the drain value is half blocked and so is not able to block the water in the tub. Remove the connection to the valve and check if this drains , if so it is confirmed. Remove, clean the dirt and reset. If the leak stays then the valve is faulty.
Also it can be due to partial voltage to the drain valve to keep it open which means that the program controller is faulty. This is confirmed when the drain stops as the connection to valve is taken off.
Jan 13, 2011 | Washing Machines
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
