Question about Evolis Pebble Color Card Printer
Doesn't print color around the edge of card.
I've tried print full color card but around the edge of card won't be printed color and the begin of card got shade color.
My fargo hdp600 keeps printing a white edge in the front of the card
please go to the print preferences and card there you will the card adjustment card size print width print length and card type are all there you can make your ajusment there and also patriot or lanscap
Mar 22, 2014 | Fargo Office Equipment & Supplies
Won't Print Color Ink
INK PROBLEM
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Jul 13, 2011 | Brother MFC 490cw Color Inkjet...
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
Only prints red - changed color cartridge, still only prints shades of red. tried to clean and prime and still only prints red
did you cleaned golden contacts on print head and cartridges with alcohol? if no, try it, other option is, that new cartridge is bad, I had similar problem, bad shades of colors, replaced cartridges and it works now
Jul 10, 2009 | HP DeskJet 882c InkJet Printer
Printing problem in Microsoft Word 2003
Does the bottom border show up in Print Preview? Some printers will not print the full page, to include the border if it is too close to the papers edge. If you adjust the border to be further away from the pages edge, it should print. Instead of applying a page border, you may have to draw a border using a rectangle shape and apply the desired line style.
You can also try to adjust the border margin to measure from "edge of page" instead of measure from "text". This setting is on the options button located on the page border tab under the Borders and Shading window. This may allow you to adjust the margin enough to be able to print the border.
Apr 09, 2009 | Microsoft Word 2003 for PC
Ribbon is breaking constantly in every print of card
in order of most likely
1 edge to edge settings in printer tool box are off.
2. print ribbon carriage (blue part you put the ribbon on is bad)
3. Bad ribbon
4. dealer needs to service to calibrate print head temp
tulsabiz.net for more info
Mar 27, 2009 | Datacard SP35 Printer
Paper comes out looking a shade darker, almost dirty.
9 out of 10 times this is caused by dirty contacts. It can also be caused by some electrical charge getting to the paper as it goes through the printer or a faulty (weak) power supply board. Your first check should be to remove all of the consumables and clean all metal contacts with an alcohol wipe or similar. Hope this helps.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | HP Color LaserJet 2600n Printer
Diagonal shading problem on monochrome print
I would try cleaning the lasers with the brush inside the door. If that fails, you might try looking at the developers.
Mar 20, 2008 | Ricoh Aficio CL7200 Laser Printer
Evolis Pebble Color Card Printer Logo
19 people viewed this question
Top Evolis Office Equipment & Supplies Experts
Safe-Card ID...
Fred Block
Fred Block
k24674
Are you an Evolis Office Equipment and Supply Expert? Answer questions, earn points and help others
