Question about Epson CX7800 Stylus Color All-In-One Printer
Paper jammed-cleared by pulling paper up& backwards Got a "E-90
After the paper pulled in the paper sota one side first, I went & pulled the paper (all in the paper holder) backwards & then it wouldn't work at all. It had a message come into the little display - it said "E-90 -call for service" I talked to Epson on the web & the phone. They had me unplug from computer to printer, then from the power. Wait & try turning it on again. I did this 3 times & no correction of the code E-90 nor running. Is there something I can fix myself or is it unrepairable by me?
    Scholar:
  • 124 Answers
Pulling paper out of a printer "backwards" will usually break a gear that is made to feed the paper in one direction.
Epson should be able to sell you the new gear and also when you order it - ask for the installation information or Service Manual to cover the replacement of the broken gear!! It helps a lot in putting the new gear in.
Posted on Jun 18, 2009
My microwave stopped working all of a sudden. Heard a pop sound and it stopped.
Could be a capacitor or a diode and I imagine the fuse blew too.
Does the clock work? If not the fuse has blown. You have to take off the cover. Take the screws out of the back and sides and pull backwards on the cover until it comes off then there should be a fuse in a holder near where the power cord comes in. Don't forget to unplug the unit. Some microwaves have the fuse in a plastic holder right in the wire. the fuse will look like a small tube with metal ends and only replace with the same type of fuse, about 15 amps. the amps will be on the fuse, look close on the metal ends.Put in new fuse and try again if it blows again you need to have someone with experience look at it.
Oct 13, 2014 | Sharp Microwave Ovens
Printer head going one side and given beep
IF the jammed paper tears and you cannot remove the paper either from the paper output slot or from the transport unit, or the jammed paper remains inside the machine, remove the paper following the procedure below. 1. Turn off the machine, and unplug the power cord of the machine from the power supply. 2. Open the paper output cover. Remove the paper on the front tray if any.
Important:
    Do not touch the clear film (A). If the paper or your hands touch these parts and blot or scratch them, the machine can be damaged.
3. Make sure that the FINE cartridge holder does not hang over the paper. If the FINE cartridge holder hangs over the paper, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper. When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it slowly to the right edge or the left edge.
4. Hold the jammed paper with your hands.
If the edge of paper is jammed near the paper output slot, pull the edge of paper to the position where you can hold it with your hands.
5. Pull the paper slowly not to tear it, then pull the paper out.
6. Make sure that all the jammed paper is removed. If the paper is torn, a piece of paper may remain inside the machine. Check the following and remove the piece of paper if it remains.
7. Close the paper output cover, then reload the paper.
All print jobs in the queue are canceled. Reprint if necessary.
Jul 21, 2014 | Epson LX-300+ II Matrix Printer
My hp pavilion dv6-3025dx disc tray is jammed.
bad drive
replace it
or remove it, and service it.
things do break, and when that happens we replace them.
May 01, 2017 | HEWLETT-PACKARD HP Pavilion dv6-3025dx...
How do you put the adding paper into the machine? My machine is a EL-1197iv
Never insert paper roll if torn. Doing so will cause paper to jam.
Always cut leading edge with scissors first.
1) Insert the leading edge of the paper roll into the opening. (Fig. 1)
2) Turn the power on and feed the paper by pressing . (Fig. 2)
3) Insert the paper roll to the paper holder. (Fig. 3)
DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
DAMAGE TO PRINTING MECHANISM.
Jan 03, 2011 | Sharp EL-1197PIII Calculator
Will not feed paper
PAPER ROLL REPLACEMENT
jam.
(Fig. 1)
2)
3) Lift the attached metal paper holder up and insert the paper
Dec 19, 2010 | Sharp EL-1801AII Calculator
Epson Photo Stylus R300 paper error
Please replace holder shaft & Roller ******
Sk. Abdus Sabur
Jan 01, 2010 | Epson Stylus Photo R300 InkJet Printer
How do I fix a paper jam? I have a piece of paper that went in slightly sideways, and now its jammed. It's almost halfway in, so I'm afraid to pull on it in case it rips and pieces are left. Is there way...
You won't be able to make the printer work backward and push the paper out. Start by powering OFF the printer (unplug it if necessary). Then look to open up the front/top/back as appropriate to clear the paper jam. Frequently, if you pull straight and carefully (slowly), the paper will come out in one piece and solve your problem. If any pieces are left inside, remove them all before attempting to power ON the printer. If in doubt as to clearing, read the user manual - troubleshooting section on clearing paper jams. Good Luck!
Aug 13, 2009 | Brother HL-2040 Laser Printer
Replacing the sand paper
Ok on the front and rear of the sander you will see metal wire holders. These extend each side of the sander and form a loop to which you can release them from their holder. Release each side ring and then that will lift the wire holders up at the front and back of the sander. This releases the sandpaper sheet. Now cut or add a new sheet that is long enough to fit over the sander base and fold up under the wire holders. Then clip the rings from the wire holder back in place while holding the sandpaper under the wire holder to hold the sandpaper in... same process for each holder (one front and back). That's it!
Jun 13, 2009 | Black & Decker QS800 2.0 Amp 1/4 Sheet...
Brother MFC3360C paper drawer will not open
remove the paper tray
remove the jam clear cover in the back.
Lift the Pull In Roller
Holder Assembly with a
credit card.
be careful not to lift too much
While lifting the Holder
Assembly, pull the tray
free from the machine
lubricate the right side with a little bit grease where the vshape is located on the tray
Apr 16, 2009 | Brother Multi-Function Center MFC-3360c...
Paper is jammed half way out on HL 2070N model
open the rear access door and pull the paper backwards through it then firmly and smoothly pull the paper free ofrom the fuser. pull the paper straight. should be easy.
Apr 08, 2009 | Brother HL-2070N Laser Printer
Epson CX7800 Stylus Color All-In-One Printer Logo
121 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
